These any good?
MrNightly
MrNightly Posts: 3,370
http://kansascity.craigslist.org/ele/1091696201.html
I have no idea about HDMI stuff... I didn't want to pay 79 bucks at BB for Monster.
Thanks!
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
Post edited by MrNightly on
  • mantis
    mantis Posts: 17,629
    edited March 2009
    This is a place where spec's mean a lot. If the cable is HDMI 1.3a certified, then it's a good cable, you can spend all you want on a better cable and gain no performance. I have tested HDMI cables and have learned from HDMI, there is no difference. They don't care who made the cable, they care only if it can perform. Once it passes, it's good.
    I use all Binary HDMI cables.
    Dan
    Dan
  • Face
    Face Posts: 14,340
    edited March 2009
  • MrNightly
    edited March 2009
    Face wrote: »
    Ya but those aren't in town :D
    I can spend 20 bucks on a couple cables, and if i need to upgrade down the road no biggie I think. Unless they are total crap?
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • mantis
    edited March 2009
    http://www.snapav.com/snapav/LISTVIEW1.ASPX?TYPE=PROD&VALUE=20
    See if any dealers carry these, I use them myself and Install them everyday.
    Dan
    Dan
  • SolidSqual
    SolidSqual Posts: 5,218
    edited March 2009
  • MrNightly
    edited March 2009
    Well, I picked up two for 20 bucks just so I can get the PS3 hooked up. They did pretty good I thought. Obviously will upgrade down the road... but for now, they do the trick.
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
