digital coax cable suggestions
gidrah
With the AA dac coming soon I am needing of a decent cable that is fairly inexpensive. I may just pick up an AR cable, but was also looking at Signal Cable. The Signal is about $30. This would be about the most I'd spend at this time.
Any suggestions?
Any suggestions?
Make it Funky!
Post edited by gidrah on
Signal for sure. Check Audioadvisor for entry level Straight Wire and Audioquest too.
Cheers,
What length do you need?I have a couple Monstercable Digital coax cables.High quality.1 meter and 2 meter is what I haveDan
Thanks guys. I just remembered I have one somewhere around. I'll probably upgrade it in the future.
I'd be looking at a 1 meter max. .5 meter would be better.Make it Funky!
Monster Silver Coax has been on sale for about $53@ Audio Advisor. I found it to be an outstanding addition....picked up a lot of detail on all channels that wasn't there before.....sounded substantially clearer more datailed that toslink.
StuffYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube
