digital coax cable suggestions
gidrah
gidrah Posts: 3,049
With the AA dac coming soon I am needing of a decent cable that is fairly inexpensive. I may just pick up an AR cable, but was also looking at Signal Cable. The Signal is about $30. This would be about the most I'd spend at this time.
Any suggestions?
Make it Funky! :)
Post edited by gidrah on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2003
    Signal for sure. Check Audioadvisor for entry level Straight Wire and Audioquest too.
    Cheers,
    Russ
  • mantis
    mantis Posts: 17,570
    edited July 2003
    What length do you need?I have a couple Monstercable Digital coax cables.High quality.1 meter and 2 meter is what I have
    Dan
  • gidrah
    gidrah Posts: 3,049
    edited July 2003
    Thanks guys. I just remembered I have one somewhere around. I'll probably upgrade it in the future.
    I'd be looking at a 1 meter max. .5 meter would be better.
    Make it Funky! :)
  • STUFFMD
    STUFFMD Posts: 381
    edited July 2003
    Monster Silver Coax has been on sale for about $53@ Audio Advisor. I found it to be an outstanding addition....picked up a lot of detail on all channels that wasn't there before.....sounded substantially clearer more datailed that toslink.
    Stuff
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
