Bi-wire
bdtae5656
Im looking for some Bi-wire for my center channel speaker.....its not cheap the places I've looked, or where it is at a good price its way to long. Please give me some help on finding an awesome pair of Bi-wires that wont break the bank.
Thanks,
Thanks,
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Post edited by bdtae5656 on
Don't waste your time unless you plan to bi-AMP.
http://www.monoprice.com
has great wire/connectors/ICs/etc. at a great price.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
So to bi-amp i would need another amp (a matching one right? in my case XPA-3) another set of matching IC's, a matching set of speaker wire (same length) and Y connectors for the back of my receiver? Not that i am going to do this just curious if i understand this correctly.
correctSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I thought you could do this with the same amp as well, as long as you have the free channels to use.
Yes, basically. You need channels, doesn't matter if it's same amp or a different amp. It's still the same concept.TNRabbit
Sunfire TG-IV
There seems to be a lot of Bi-curious threads here lately.:p:D
So there's not much difference without the extra amp when Bi-wiring???? I was looking to buy a small/meduim size amp to hook up to the center channel along with my AVR354TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
Ok,I gotta ask.........why do you only want to amp the center?? You would be better off to amp the front 3 speakers for better sound,if thats the goal.HT SYSTEM-
lsi 9's -
Whats a good amp to use.....My front speakers are just bose cubes and the center is a Polk LSI w/ a HK AVR354 75 watts per channelTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
I didnt see any Bi-wire on this page???TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
LessisNevermore wrote: »There seems to be a lot of Bi-curious threads here lately.:p:D
Sounds like you are projecting yourself.:eek:KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
I bought wires and interconnects at monoprice (good stuff and good price) and you probably won't find any "bi-wire" or "bi-amp" speaker wire. Just buy a reel of speaker wire, some banana plugs (or whatever you want to terminate them with.... or just leave it as bare wire). If bi-amping just connect 2 channels from amp to the dual terminals on your speakers and make sure to remove the jumper. Bi-wiring is basically a waste of time and serves the same effect as increasing the gauge of speaker wire. If you are already using 14 or 12 gauge wire then its not worth it.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
So if i did bi-amp my A9's would i see a big change in the way they sound?
Is it worth it is what i want to know.
TOOLFORLIFEFAN wrote: »Is it worth it is what i want to know.
I see that you have an XPA-3 which already puts out a massive amount of juice. What would you bi-amp with?
The differnce won't be huge.... you already have great speakers and a great amp. With my UPA-7 and RTi10's i noticed a difference that was worthwhile but your speakers and amp are even better so who knows what will happen.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Well if i thought about doing it i would just add another XPA-3. -
TOOLFORLIFEFAN wrote: »Well if i thought about doing it i would just add another XPA-3.
I'll sell you mine!
lsi 9's -
You, sir, are insane
In a good way, though. KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
TOOLFORLIFEFAN wrote: »I am first in line.
I've seriously been debating on putting my XPA-3 in the classifieds for the past week. -
whats wrong with it? Does this have anything to do with the "EMOTIVA STORY" thread??KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Don't get your hopes up, I'll only break your heart.....;)
:p:p -
Nope, there's absolutely nothing wrong with it.
But this is my first Amp, and i sort of bought it on a whim.
I'm very interested in trying something else, specifically, a Sunfire Amp.
Don't get me wrong here, i think it sounds great. I'm just the type of person who doesn't settle easily so i need to hear something else. Plus, i enjoy buying new things!
LessisNevermore wrote: »Don't get your hopes up, I'll only break your heart.....;)
:p:p
Don't lie.... you know you're into bi-wiring even though you know it's a waste of time.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Feel free to send it my way.... i'll be sure to make good use of it
Feel free to send money first!
:cool: -
:cool:
this deal is looking less and less tempting as time goes on.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Haha...I'm not giving the freakin thing away! lol
In a word....no.
Then why do all these speakers have the option if NO? it has been done for years from what i understand. You would think if it was'nt worth it they would have done away with it. I just wish i had a way of tring it with out it costing so much.:p
