Bi-wire
bdtae5656
bdtae5656 Posts: 235
Im looking for some Bi-wire for my center channel speaker.....its not cheap the places I've looked, or where it is at a good price its way to long. Please give me some help on finding an awesome pair of Bi-wires that wont break the bank.
Thanks,
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Post edited by bdtae5656 on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2009
    Don't waste your time unless you plan to bi-AMP.
    http://www.monoprice.com
    has great wire/connectors/ICs/etc. at a great price.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    Toolfan66 Posts: 18,334
    edited March 2009
    So to bi-amp i would need another amp (a matching one right? in my case XPA-3) another set of matching IC's, a matching set of speaker wire (same length) and Y connectors for the back of my receiver? Not that i am going to do this just curious if i understand this correctly.
  • fbm211
    fbm211 Posts: 1,488
    edited March 2009
    correct
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • metal83
    metal83 Posts: 1,219
    edited March 2009
    I thought you could do this with the same amp as well, as long as you have the free channels to use.
  • TNRabbit
    edited March 2009
    Yes, basically. You need channels, doesn't matter if it's same amp or a different amp. It's still the same concept.
    TNRabbit
    Sunfire TG-IV
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited March 2009
    There seems to be a lot of Bi-curious threads here lately.:p:D
  • bdtae5656
    edited March 2009
    TNRabbit wrote: »
    So there's not much difference without the extra amp when Bi-wiring???? I was looking to buy a small/meduim size amp to hook up to the center channel along with my AVR354
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
    edited March 2009
    bdtae5656 wrote: »
    Ok,I gotta ask.........why do you only want to amp the center?? You would be better off to amp the front 3 speakers for better sound,if thats the goal.
  • bdtae5656
    edited March 2009
    tonyb wrote: »
    Whats a good amp to use.....My front speakers are just bose cubes and the center is a Polk LSI w/ a HK AVR354 75 watts per channel
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • bdtae5656
    edited March 2009
    TNRabbit wrote: »
    I didnt see any Bi-wire on this page???
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    Sounds like you are projecting yourself.:eek:
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    bdtae5656 wrote: »
    I bought wires and interconnects at monoprice (good stuff and good price) and you probably won't find any "bi-wire" or "bi-amp" speaker wire. Just buy a reel of speaker wire, some banana plugs (or whatever you want to terminate them with.... or just leave it as bare wire). If bi-amping just connect 2 channels from amp to the dual terminals on your speakers and make sure to remove the jumper. Bi-wiring is basically a waste of time and serves the same effect as increasing the gauge of speaker wire. If you are already using 14 or 12 gauge wire then its not worth it.
    edited March 2009
    So if i did bi-amp my A9's would i see a big change in the way they sound?
    edited March 2009
    Is it worth it is what i want to know.
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    I see that you have an XPA-3 which already puts out a massive amount of juice. What would you bi-amp with?
    The differnce won't be huge.... you already have great speakers and a great amp. With my UPA-7 and RTi10's i noticed a difference that was worthwhile but your speakers and amp are even better so who knows what will happen.
    edited March 2009
    BjornB17 wrote: »
    Well if i thought about doing it i would just add another XPA-3.
  • metal83
    edited March 2009
    I'll sell you mine! :p
    edited March 2009
    metal83 wrote: »
    I am first in line.
    edited March 2009
    In a word....no.
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    You, sir, are insane :D In a good way, though.
  • metal83
    edited March 2009
    I am first in line.
    I've seriously been debating on putting my XPA-3 in the classifieds for the past week.
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    metal83 wrote: »
    whats wrong with it? Does this have anything to do with the "EMOTIVA STORY" thread??
  • LessisNevermore
    edited March 2009
    BjornB17 wrote: »
    Don't get your hopes up, I'll only break your heart.....;)
    :p:p:p
  • metal83
    edited March 2009
    BjornB17 wrote: »
    Nope, there's absolutely nothing wrong with it.
    But this is my first Amp, and i sort of bought it on a whim.
    I'm very interested in trying something else, specifically, a Sunfire Amp.
    Don't get me wrong here, i think it sounds great. I'm just the type of person who doesn't settle easily so i need to hear something else. Plus, i enjoy buying new things! :p
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    :p:p:p
    Don't lie.... you know you're into bi-wiring even though you know it's a waste of time.
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    metal83 wrote: »
    Feel free to send it my way.... i'll be sure to make good use of it :)
  • metal83
    edited March 2009
    BjornB17 wrote: »
    Feel free to send money first! :p:cool:
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    metal83 wrote: »
    this deal is looking less and less tempting as time goes on.
  • metal83
    edited March 2009
    BjornB17 wrote: »
    Haha...I'm not giving the freakin thing away! lol :p
    edited March 2009
    tonyb wrote: »
    In a word....no.
    Then why do all these speakers have the option if NO? it has been done for years from what i understand. You would think if it was'nt worth it they would have done away with it. I just wish i had a way of tring it with out it costing so much.:p
