Record Cleaning Machines
SolidSqual
I'm looking at VPI 16.5 and the Nitty Gritty 1.5 or 1.5Fi. Can anyone tell me their experiences with either and perhaps which they prefer.
Thanks,
Mike
Thanks,
Mike
Post edited by SolidSqual on
Joe had both and he kept the VPI. I need to make something for myself. I am tired of having just the felt wiper, and solution;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I've had the NG and the VPI. The VPI is superior.
Thank you for your comments. I was leaning toward the VPI, but . . .
Do you have several mats for the VPI? When you flip a clean record over aren't you just putting the record back on a dirty mat? To me, I thought this is where the NG was superior. -
I have two mats...one to put a dirty side on, one to put a clean side on.
The other advantage of the NG is that it sucks down and not up...but, for whatever reason, the VPI still works better. I like having the platter to scrub on.
The other advantage of the NG is that it sucks down and not up...but, for whatever reason, the VPI still works better. I like having the platter to rub my dingus on.
BDT
Fixed it for ya.
President of Club Polk -
I have been using the NG Mini pro for some time now and I have not one complaint when using the steam cleaner to compliment the cleaning procedure. I don't think [running off of memory here] that my model is the same as the 1.5 as it is the dual sided model but it does a fantastic job for me. No complaints here.
I apologize but that's all the information I have to offer as I have never owned a VPI. I can say this, I have heard both and both are rather loud. Minor complaint for what it does but still, they both are loud to the point of having to raise your voice to right below shouting level to hear from 5' away.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
VPI--16.5, be happy.
RT1 -
reeltrouble1 wrote: »VPI--16.5, be happy.
RT1
+1 on what RT1 saidDKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Most prefer the VPI models. The entire record is supported by a platter so it has more torque to spin while you are exerting pressure with a brush. You also don't have to flip them to vacuum. You clean the top side with a squirt of solution, a few spins and a cleaning brush, then drop the vacuum tube and suck it dry. The Nittys are only held in the center and on the edge with a little roller. I've heard that the roller keeps the lead in from getting cleaned as well.
I've been using a NG 1.5Fi for the better part of a year and have no complaints except it is quite loud on the vacumn cycle. I've cleaned hundreds of records with it.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
On my 16.5 I use two mats and three different vacuum tubes for the three different solutions I use. I also use three different scrubbing brushes.
Ya can't be too careful with cross-contamination.
Edit: once a record has been treated the first time with all three (sometimes 4 solutions) I only use VPI record cleaning solution to clean the record before each play. -
hearingimpared wrote: »On my 16.5 I use two mats and three different vacuum tubes for the three different solutions I use. I also use three different scrubbing brushes.
Now that's a cleaning process! Mine pales in comparison. I think I need to enter a 12 step program to regain audiophile status
DKG999
As far as steam cleaning is concerned in conjunction with the 16.5 it really gets down deep in the groove. My problem with it is that I am very heavy handed and have a propensity to scald the record. So I stopped using the steam cleaner.
Wow, I thought I'd never hear that. So long as I keep the nozzle above the 3-4" threshold, I'm golden with the steam cleaner cleaning method in conjunction with the NG.hearingimpared wrote: »So I stopped using the steam cleaner.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I just bought a VPI 16.5. Thanks for the advice guys.
I just happened to scald too many records so that told me I was not meant to use the steamer. Like I said I am heavy handed so I sometimes push too hard on the scrubbing brushes too but I seem to have more control over them.
I still use the steamer on the occassionally grungy used records I might come across but I feel the dirt somehow protects the vinyl from this heavy hand. -
SolidSqual wrote: »I just bought a VPI 16.5. Thanks for the advice guys.
Great decision.:) You won't be sorry. -
hearingimpared wrote: »....and have a propensity....
I had one of those the other day. The doc gave me some meds and it cleared up.
I'm still getting by with your old, refurbed, NG Joe.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »I had one of those the other day. The doc gave me some meds and it cleared up.
I bought that thing back in 1985 from The Tweak Shop. I bet they would never guess that it would still be seeing action lo these many years.:eek::cool: -
Heck, I'm old and still see action.:D I have tried to snag a used 16.5 here and there with no luck. Maybe someday.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Amatures...here's what you need. http://www.kenmore.com/shc/s/p_10154_12604_02213742000P?keyword=kenmore+13742&sLevel=0
Perfect water temp, low suds, cleans out all those pits & grooves. Dry cycle that'll have you shaking your head in disbelief.!!!
You can boil your records to save time too.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
pearsall001 wrote: »amatures...here's what you need. http://www.kenmore.com/shc/s/p_10154_12604_02213742000p?keyword=kenmore+13742&slevel=0
perfect water temp, low suds, cleans out all those pits & grooves. Dry cycle that'll have you shaking your head in disbelief.!!!
waaaaaaaaaaaaaaaaaaaaaaaaaaaaaa -
VPI 16.5. it is taking everything i have to not pull the trigger on this.
TOOLFORLIFEFAN wrote: »VPI 16.5. it is taking everything i have to not pull the trigger on this.
Just do it. You won't be sorry.:) -
do it do it do it do it do it do it do it
od ti od ti od ti od ti od ti od ti od ti
sounds much better than on a clean record though.
RT1 -
reeltrouble1 wrote: »do it do it do it do it do it do it do it
RT1
Send me up some of what you are smoking.:eek::p -
I have gas and my hemorroids hurt, its on the way in a bucket of steam to you.
RT1 -
reeltrouble1 wrote: »I have gas and my hemorroids hurt, its on the way in a bucket of steam to you.
RT1
:eek:Yuck-a-rooney!:eek: -
RT1
Sounds like a typical record skipping...gotta love vinyl!!!:D
