Record Cleaning Machines
SolidSqual
SolidSqual Posts: 5,218
edited March 2009 in 2 Channel Audio
I'm looking at VPI 16.5 and the Nitty Gritty 1.5 or 1.5Fi. Can anyone tell me their experiences with either and perhaps which they prefer.
Thanks,
Mike
Post edited by SolidSqual on
«13
  • ben62670
    ben62670 Posts: 15,969
    edited February 2009
    Joe had both and he kept the VPI. I need to make something for myself. I am tired of having just the felt wiper, and solution;)
    Ben
  • TroyD
    TroyD Posts: 13,124
    I've had the NG and the VPI. The VPI is superior.
    BDT
  • SolidSqual
    Thank you for your comments. I was leaning toward the VPI, but . . .
    Do you have several mats for the VPI? When you flip a clean record over aren't you just putting the record back on a dirty mat? To me, I thought this is where the NG was superior.
  • TroyD
    TroyD Posts: 13,124
    I have two mats...one to put a dirty side on, one to put a clean side on.
    The other advantage of the NG is that it sucks down and not up...but, for whatever reason, the VPI still works better. I like having the platter to scrub on.
    BDT
    F1nut Posts: 51,860
    TroyD wrote: »
    The other advantage of the NG is that it sucks down and not up...but, for whatever reason, the VPI still works better. I like having the platter to rub my dingus on.
    BDT
    Fixed it for ya. :D
    treitz3 Posts: 20,035
    I have been using the NG Mini pro for some time now and I have not one complaint when using the steam cleaner to compliment the cleaning procedure. I don't think [running off of memory here] that my model is the same as the 1.5 as it is the dual sided model but it does a fantastic job for me. No complaints here.
    I apologize but that's all the information I have to offer as I have never owned a VPI. I can say this, I have heard both and both are rather loud. Minor complaint for what it does but still, they both are loud to the point of having to raise your voice to right below shouting level to hear from 5' away.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    VPI--16.5, be happy.
    RT1
  • dkg999
    dkg999 Posts: 5,647
    RT1
    +1 on what RT1 said
    DKG999
    billbillw Posts: 7,657
    Most prefer the VPI models. The entire record is supported by a platter so it has more torque to spin while you are exerting pressure with a brush. You also don't have to flip them to vacuum. You clean the top side with a squirt of solution, a few spins and a cleaning brush, then drop the vacuum tube and suck it dry. The Nittys are only held in the center and on the edge with a little roller. I've heard that the roller keeps the lead in from getting cleaned as well.
  • Fongolio
    Fongolio Posts: 3,516
    I've been using a NG 1.5Fi for the better part of a year and have no complaints except it is quite loud on the vacumn cycle. I've cleaned hundreds of records with it.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • hearingimpared
    hearingimpared Posts: 21,136
    On my 16.5 I use two mats and three different vacuum tubes for the three different solutions I use. I also use three different scrubbing brushes.
    Ya can't be too careful with cross-contamination.
    Edit: once a record has been treated the first time with all three (sometimes 4 solutions) I only use VPI record cleaning solution to clean the record before each play.
  • dkg999
    dkg999 Posts: 5,647
    Now that's a cleaning process! Mine pales in comparison. I think I need to enter a 12 step program to regain audiophile status :o
    DKG999
  • hearingimpared
    As far as steam cleaning is concerned in conjunction with the 16.5 it really gets down deep in the groove. My problem with it is that I am very heavy handed and have a propensity to scald the record. So I stopped using the steam cleaner.
    Wow, I thought I'd never hear that. So long as I keep the nozzle above the 3-4" threshold, I'm golden with the steam cleaner cleaning method in conjunction with the NG.
  • SolidSqual
    I just bought a VPI 16.5. Thanks for the advice guys.
  • hearingimpared
    treitz3 wrote: »
    I just happened to scald too many records so that told me I was not meant to use the steamer. Like I said I am heavy handed so I sometimes push too hard on the scrubbing brushes too but I seem to have more control over them.
    I still use the steamer on the occassionally grungy used records I might come across but I feel the dirt somehow protects the vinyl from this heavy hand.
  • hearingimpared
    SolidSqual wrote: »
    Great decision.:) You won't be sorry.
    SCompRacer Posts: 9,116
    ....and have a propensity....
    I had one of those the other day. The doc gave me some meds and it cleared up.
    I'm still getting by with your old, refurbed, NG Joe.
  • hearingimpared
    SCompRacer wrote: »
    I bought that thing back in 1985 from The Tweak Shop. I bet they would never guess that it would still be seeing action lo these many years.:eek::cool:
    Heck, I'm old and still see action.:D I have tried to snag a used 16.5 here and there with no luck. Maybe someday.
  • pearsall001
    pearsall001 Posts: 5,306
    Amatures...here's what you need. http://www.kenmore.com/shc/s/p_10154_12604_02213742000P?keyword=kenmore+13742&sLevel=0
    Perfect water temp, low suds, cleans out all those pits & grooves. Dry cycle that'll have you shaking your head in disbelief.!!!:confused:
  • ben62670
    You can boil your records to save time too.
    Ben
  • hearingimpared
    amatures...here's what you need. http://www.kenmore.com/shc/s/p_10154_12604_02213742000p?keyword=kenmore+13742&slevel=0
    perfect water temp, low suds, cleans out all those pits & grooves. Dry cycle that'll have you shaking your head in disbelief.!!!:confused:
    waaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    Toolfan66 Posts: 18,114
    VPI 16.5. it is taking everything i have to not pull the trigger on this.
  • hearingimpared
    Just do it. You won't be sorry.:)
  • reeltrouble1
    do it do it do it do it do it do it do it
    od ti od ti od ti od ti od ti od ti od ti
    sounds much better than on a clean record though.
    RT1
  • hearingimpared
    RT1
    Send me up some of what you are smoking.:eek::p
  • reeltrouble1
    I have gas and my hemorroids hurt, its on the way in a bucket of steam to you.
    RT1
  • hearingimpared
    RT1
    :eek:Yuck-a-rooney!:eek:
  • pearsall001
    RT1
    Sounds like a typical record skipping...gotta love vinyl!!!:D
