Grills on or off?
BottomFeeder wrote: »Mine are usually on, until I sit down to do some real listening. Then I like to take them off. My speakers are absolutely gorgeous and taking the grills off reveals the beautiful wood. I like's 'em nekkid!
Same here. They're on all the time unless I'm listening to music. I love the way my 7A's look...so I like to be able to see them. I typically leave the grilles on when I'm watching movies though, because I have the lights off, and you can't see them anyway.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
You guys that take your grills off when you listen, try closing your eyes instead of staring at the drivers. You'll probably find yourselves more involved with the music.Political Correctness'.........defined
President of Club Polk -
I usually do have my eyes closed...but when I open them I like to see my drivers.
Currently a big deciding factor in the grilles being off though is the fact that all the clips on one of the speakers are broken off...so it won't stay on. I can lean it against the speaker and it'll stay...but I've noticed a difference in sound with the grille on it like that, because it's not straight, but leaning against it. Once I get my new clips the grilles will probably be staying on most of the time. Hopefully those new clips from Polk should be here in the next week or so.The nirvana inducer-
I think there may be a slight sound inprovement, I feel exposed parts may interest touching by my daughter and her friends. If I had no kids and associated traffic, I would go grill-less, but for now I will keep them on.Anthem D2v
NAD M50 Music Server
B & K Reference 200.5
Parasound A21
B & W 804 (Mains)
B & W HTM1 (Center)
Polk Rti4 (Surrounds)
PS3
Seaton Submersive HP
Pioneer PDP 6010FD Kuro -
...for the life of me can't think of how they could actually IMPROVE the sound.
it's not just the fabric that makes a difference, there is also the grille frame. the frame changes how sound travels across and leaves the front baffle and edge of the speaker cabinet.
when i have everything set up so that reflections from the room and its contents are not strong at the listening position, i almost always prefer the grilles off, mostly because i usually prefer a very sharp image. one drawback of a sharp image is that it makes flaws from, say, room reflections much more obvious. some times when i notice these problems, grilles on can soften the image and change how the speaker interacts with the room enough to hide and/or correct these problems.
Very Interesting point:cool:Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I usually keep my grills on because I'm unrealistically neurotic about the effects of dust on drivers? And I haven't quite figured out how to 'safely' remove that dust that 'always' settles and coats all your drivers, at least in my home, after a few weeks!
I can't imagine that extra dust is a good thing? But as I've said I may just be pulling my leg on this one.
I always take my grills off when I am doing critical listening. If I am just milling around, I leave them on.
cnh
It's odd that you should mention that. I've been wondering about the best way to clean the actual drivers on my Monitor 7's, and I got a few recommendations for using Windex. I finally tried it yesterday, and it worked great. I was amazed how much dust and dirt got lifted off of them.
I noticed after cleaning them that they actually sounded a little better. It wasn't a night and day difference by any means, but the mids warmed up noticeably. I wasn't really expecting there to be a difference in sound quality after cleaning them, but I wasn't complaining...lol Cheap mod I guess.:pThe nirvana inducer-
I like them off. My wife likes them on. I rule the house ,so they stay off untill she get's home :rolleyes:
Yeh, I run things around my houe too! The vaccumm cleaner, dishwasher, washer machine, and anything else that she wants done.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
off on Taylos monitors,,SDA's=onJC approves....he told me so. (F-1 nut)
I like them off. My wife likes them on. I rule the house ,so they stay off untill she get's home :rolleyes:Yeh, I run things around my houe too! The vaccumm cleaner, dishwasher, washer machine, and anything else that she wants done.
Bill
It takes a big man to admit who really wears the pants in the family. I too have learned it the hard way though.;) -
Dust? Your drivers should be shaking the dust off due to mucho loud playing. Just kidding. I like my lsi9 covers off b/c i think it lets the tweeter come through slightly better.
What about speakers that dont use grills???Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
comfortablycurt wrote: »It's odd that you should mention that. I've been wondering about the best way to clean the actual drivers on my Monitor 7's, and I got a few recommendations for using Windex. I finally tried it yesterday, and it worked great. I was amazed how much dust and dirt got lifted off of them.
I use an Air Blaster to clean my speakers, did this a few times already and zero harm done. Of course you dont put the blaster on top of the speaker, hold a few inches aways and blast. Works well.
http://digitalinnovations.com/Merchant5/merchant.mvc?Screen=PROD&Store_Code=DI&Product_Code=3010300&Category_Code=Electronics_CleaningShoot the jumper.....................BALLIN.............!!!!!
I don't have any problem with using Windex on the black finish of my LSi15s, but I would not use it on the speaker cones. If I did clean the speakers a damp cloth lightly applied would be my choice. Maybe I will try that this weekend since the grills have been off for ages.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
mine's off ..... sound better for me
It took a while to find some speaks our cats liked and wouldn't scratch the grills. They ended up being Polks - everyone happy.
:D Chris -
I have the RTIA5's in Cherry and I like to look at them so the grills are off."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
leave the grilles off for a few months and then try to clean the dust and lint off the drivers... leaving grilles on is betterELITE VSX-99 REFERENCE
ELITE PD-65
SDA-1C's with new RDO194-1 tweeters as MAINS
MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
PARADIGM REFERENCE CC-450 Center
MONITOR SERIES II... M10 REARS
2 POLK DSW-600PRO SUBS
"ROCKIN THE HOUSE" -
CowboyRJB2 wrote: »leave the grilles off for a few months and then try to clean the dust and lint off the drivers... leaving grilles on is better
Which way sounds better to you?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Thanks for the suggestion...that looks like it would work pretty well. Doesn't cost very much either...I might have to pick one of those up.The nirvana inducer-
I keep my drivers behind bars!!
"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Wow, those are pretty cool!"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
I have no preference either way but occasionally like watching my SDA mid drivers dancing to the musicThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
renowilliams wrote: »What crime did they commit??
Beating up too many other speakers. Can't seem to find a fair fight!!!
pearsall001 wrote: »Beating up too many other speakers. Can't seem to find a fair fight!!!
Thats a good-1:D:D:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Grills off! Much more bad-**** looking.
Get a Swiffer duster to clean the drivers (works great on the piano black too).SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
