dvd-a question
chemical
chemical Posts: 100
edited February 2009 in Music & Movies
can dvd-a play on a blu ray player.....or does it need a special player?.....complete rookie here.....thanks
Post edited by chemical on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Not unless it says specifically that it can play DVD-A. I'm going to guess not...there are only a few BR's out there that play SACD or DVD-A at this point...and they're fairly expensive.
    What Blu-ray player do you have?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • chemical
    chemical Posts: 100
    What Blu-ray player do you have?[/QUOTE
    thanks for your reply....its a sony blu ray 350
  • comfortablycurt
    Nope, unfortunately that player won't play either SACD or DVD-A. The Blu-spec CD's should be coming around soon though if you're looking for some higher quality music formats.
  • chemical
    chemical Posts: 100
    bummer......thanks for the info
  • danger boy
    danger boy Posts: 15,722
    DVD-Audio is dead anyways.. ;)
    PolkFest 2012, who's going>?
