dvd-a question
chemical
can dvd-a play on a blu ray player.....or does it need a special player?.....complete rookie here.....thanks
Post edited by chemical on
Not unless it says specifically that it can play DVD-A. I'm going to guess not...there are only a few BR's out there that play SACD or DVD-A at this point...and they're fairly expensive.
What Blu-ray player do you have?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »Not unless it says specifically that it can play DVD-A. I'm going to guess not...there are only a few BR's out there that play SACD or DVD-A at this point...and they're fairly expensive.
What Blu-ray player do you have?[/QUOTE
thanks for your reply....its a sony blu ray 350 -
Nope, unfortunately that player won't play either SACD or DVD-A. The Blu-spec CD's should be coming around soon though if you're looking for some higher quality music formats.The nirvana inducer-
comfortablycurt wrote: »Nope, unfortunately that player won't play either SACD or DVD-A. The Blu-spec CD's should be coming around soon though if you're looking for some higher quality music formats.
bummer......thanks for the info -
DVD-Audio is dead anyways..
PolkFest 2012, who's going>?
