burn in time for MIT Shotguns?
Norm Apter
Norm Apter Posts: 1,036
I picked up a second set of MIT Shotgun S-3s on A-gon today. Unlike the pair I got last week, it appears that this pair will not be fully burned in. The seller informed me that he is the first owner and has put about 30-40 hours on them.
Anyone know of a ballpark figure for the number of hours for complete burn in for these cables? I did a brief search on MIT's website but couldn't find anything.
Norm
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • Face
    Face Posts: 14,340
    edited February 2009
    2 days=75%
    2 weeks=100%
  • Norm Apter
    Face wrote: »
    2 days=75%
    2 weeks=100%
    Just to clarify -- when you say 2 days, do you mean 2 days continuously playing (i.e. 48 hours), or -- if not -- based on how many hours per day?
    2 Ch.
    HT
    Denon 2808ci AVR
  • hearingimpared
    hearingimpared Posts: 21,136
    Face wrote: »
    2 days=75%
    2 weeks=100%
    Mine took at little longer more like 2 1/2 weeks.
  • hearingimpared
    Norm Apter wrote: »
    Continuously running.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    yes, but.........
    they continue to burn in until they are...........well, burnt.
    RT1
  • ben62670
    ben62670 Posts: 15,969
    The best way to burn cables is to install them between a CDP, and a pre. The CDP puts out full voltage, and you need not have to have the pre truned on;)
    Enjoy.
    Ben
    Ben
  • hearingimpared
    Don't forget to play a full range piece of music repeatedly.
  • zingo
    zingo Posts: 11,258
    ben62670 wrote: »
    Enjoy.
    Ben
    I like this idea Ben! I'll have to try that with my next pair.
    F1nut Posts: 51,723
    200 to 400 hours to reach full burn in.
    Is he sellling them because he didn't like the sound?
  • dorokusai
    dorokusai Posts: 25,576
    I would say 2-3 months.
  • Norm Apter
    No, it doesn't appear so.
    In an e-mail exchange we had yesterday, I asked the seller about his equipment. Though he didn't confirm his next move, I am assuming that he is simply moving higher up in the MIT food chain. Here's what he listed as the components of his system. Shoot, I'm totally unaware of this kind of gear but I'm thinking it must be some top notch stuff:
    "Wilson WP 7's, Pass Labs XP-10 preamp, soon to be Pass Labs XA 30.5 amp, Meridian G08 CD, and MIT Magnum M1 cables"
    Magnums are higher up than Shotguns, right?
    2 Ch.
    HT
    Denon 2808ci AVR
  • Norm Apter
    By this, do you mean something symphonic in quality? In other words, music that has both high highs and low lows?
    2 Ch.
    HT
    Denon 2808ci AVR
    F1nut Posts: 51,723
    Ok, if he's running Magnum M1 speaker cables, then he'd want to run M1 IC's to get the full benefit.
  • hearingimpared
    Norm Apter wrote: »
    That would be ideal but it doesn't have to be symphonic it could be anything that covers a wide spectrum.
  • inspiredsports
    inspiredsports Posts: 5,502
    48 hours for 75% and 336 hours for 100%, driven by dynamic range source like music or an IsoTek System Rejuvenation and Enhancement Disc. Matching IC's and Cables by product line and number is the best solution.
    In my opionion, the IC's probably yield 60% of the improvement, and Speaker Interface Cables 40%.
    I just finished burning in AVt-2's and they actually got sweeter up to 500 hours, and they are truly amazing and I believe, underated Cables. I'm moving to the next level and just bought new Shotgun S2's that should arrive on Tuesday. I bought extras to get at what I wanted and will be listing used AVt-2's and brand new extra S2's in the forum late next week.
    I can't wait until the Shotguns arrive !! : ):) :)
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Yoko Ono maybe? ;)
  • hearingimpared
    erik tracy wrote: »
    yoko ono maybe? ;)
    waaaaaaaaaaaaaaaaaaaaaaaaaaaa!!!
  • Norm Apter
    Matching IC's and Cables by product line and number is the best solution. In my opionion, the IC's probably yield 60% of the improvement, and Speaker Interface Cables 40%. I can't wait until the Shotguns arrive !! : ):) :)
    Are you using, or do you plan to use, MIT Shotgun speaker cables as well?
    2 Ch.
    HT
    Denon 2808ci AVR
  • Norm Apter
    That question goes for the rest of you Shotgun owners, too....is it Shotguns all around (i.e. speaker cables also) if you have the ICs, or do you mix it up?
    2 Ch.
    HT
    Denon 2808ci AVR
  • polkatese
    polkatese Posts: 6,767
    Norm, I do Shotgun 3 IC and speaker cables. If you have the budget, you should try it.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • hearingimpared
    I use Shotgun 3 IC's but the Shotgun 750 biwire speaker wire. I'm hoping to get a pair of Magnum speaker wires in the near future.
  • Solumnus
    Solumnus Posts: 48
    So, are you gonna pay more for those 30 to 40 hrs of break in? The cables HAVE to be worth more if some work is already done on them? Or am I being skeptical about speaker wire break in?
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
    F1nut Posts: 51,723
    That's a nice way to put it.
  • ben62670
    Good wires do require time to burn in period.
    Ben
  • inspiredsports
    Norm Apter wrote: »
    I'm matching Shotgun S2 Speaker Interface Cables with Shotgun S2 IC's.
    MIT recommends using the same model number of the same product line. I'm not sure why. If I have it right, I guess the theory is that Shotgun 3 Cables with the next higher step up model Shotgun 2 IC's would not be as good as using the Shotgun 3 Cables with matching (but lesser) Shotgun 3 IC's.
    NAD SS rigs w/mods
    GIK panels
  • ben62670
    I was just kidding. All cables are the same:D
    Ben
  • hearingimpared
    ben62670 wrote: »
    Here we go.:p
  • Face
    Face Posts: 14,340
    I spoke to MIT's VP a while back, I believe he mentioned that as long as the series are the same(Shotgun, AVt, etc...), you should be fine.
  • inspiredsports
    Face wrote: »
    Got it. With that said, I have 2 rigs and am using AVt-2 IC's with both AVt-2 and EXp-1 Cables. I've swapped several combinations of speakers, wires and components, and both have delivered excellent results. I wonder if the matching becomes more and more important with the higher series cables?
    NAD SS rigs w/mods
    GIK panels
  • dorokusai
    If you hear changes within the same MIT lineup, e.g. Shotgun S3 vs Shotgun S1....you're borderline retarded. I'm an MIT subscriber but the model lines make no sense.
