Pioneer vsx 1019 ah-k Ipod issue
Marzz13
Okay, just got the Pioneer a couple of days ago, so still trying to figure it all out. My issue is, the first day my ipod worked no problem. But now it doesn't. It just says 'Connecting...' and won't connect.
Anybody have this problem or know what to do?
Post edited by Marzz13 on
Never had this problem on my Pioneer connecting my ipod. Does the ipod work fine otherwise? I've had mine lock up a couple of times where it wouldn't connect to itunes to sync. And did you try a different cable?Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Connect to Itunes and update your firmware. I connect Ipods to Pioneer receivers on a daily basis. This is your fix.Dan
Thanks, Quad. I tried a few a new cable, and then I rebooted my ipod. This has now fixed it. I am loving the Pioneer again.:D
