Sda Crs +
har_navalta
SDA CRS+ for $600?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3023953817&category=32861
What do you think?
What do you think?
Post edited by har_navalta on
Where is the attachment go? I will try it again...
Still doesn't take the pic? weird...
Bank for a pair that retailed for $800."The only way to get rid of a temptation is to yield to it."
The surround rubber looks a little crusty.
Har,
Some of the "walnut" finish CRS+'s were actually vinyl with an imitation walnut pattern. I know how much you like real wood, so I would email the seller and ask if his speakers are real wood veneer or vinyl with a walnut pattern.;)Proud and loyal citizen of the Digital Domain and Solid State Country! -
I wouldn't be worried about the surround rubber. A little "armor-all" and it'll clean right up.
Hey Ron that's my secret; to clean all my drivers and it will restore them so that they look new.
You should keep it a secret;)
Har -
amor all cleans everything...leather couches to shoes. Its the tool of tools!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I thought the CRS+ had the interconnect cable receptacle molded into the input plate. This looks like it may be a blade blade connection. Something to think about.
There were two versions of the CRS+:
The 1986 version of the CRS+ has the blade/blade SDA interconnect cable with the jack in the back of the cabinet.
The 1989 version of the CRS+ has the pin/blade SDA interconnect cable with the jack in the binding post plate.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Thanks for the clarification raife1.
