Audio out?
NoObTecH
NoObTecH Posts: 22
edited February 2010 in Troubleshooting
Hi,
I'm trying to play music on my receiver from my computer through digital output (optical) which is an on board feature. However, I do not hear anything at 192k hz or 96 khz, only 48 khz and lower. Is this because of my my receiver not being able to play 192 khz?
Thank you,
Nathan
Post edited by NoObTecH on
  • mantis
    mantis Posts: 17,201
    NoObTecH wrote: »
    Hi,
    Thank you,
    Nathan
    Correct.
    Dan
  • NoObTecH
    NoObTecH Posts: 22
    ahhh... Thank you. I really need to fix my htr-5280 then... it's rated at 192/24 bit DAC... That should work, right?
  • fbm211
    fbm211 Posts: 1,488
    Yes,probably
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Phil Dawson
    Phil Dawson Posts: 288
    You might also check to see what resolution your computer is outputting.
    Phil
  • adam2434
    adam2434 Posts: 995
    Phil
    +1
    What media program are you using?
    PC or Mac?
    If PC, you might want to check your supported formats in the control panel (see attached screen shot).
    sc.jpg 58.6K
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
