Audio Art Speaker Cables?
Jetmaker737
Jetmaker737 Posts: 1,118
Can anyone comment on these cables?
http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1268501097&/Audio-Art-Cable-SC-5---SC-5-bi
I'd be interested in any input on these 14 AWG silver coated copper stranded cables versus, say, the AQ Type 4 with solid conductors.
Post edited by Jetmaker737 on
  • fbm211
    fbm211 Posts: 1,488
    edited January 2010
    Good cables at a budget price.Those are probably DH Labs T-14 cables sold under a different name.Audio Art works with them and I bet thats where they get thier raw cable.
    I use T-14 cables in a shotgun config.
    If you like your sq a little tipped up, go with them.Other wise the AQ Type 4 are a solid choice too.
    Right here is a very good speaker cable for the price.I may have to try these myself>>http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1268374784&/Monarchy-Speaker-Cable
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • mopar paul
    mopar paul Posts: 277
    edited January 2010
    I wouldn't worry about it, all speaker cable technology is just a myth. Just get ya some 12 gauge zip cord at Lowes, it's as good as anything else out there.;) Sorry, I couldn't resist!
  • Jetmaker737
    edited January 2010
    fbm211 wrote: »
    Interesting... thanks for the link. What do you think about those compression fit nanners compared to soldered?
  • fbm211
    fbm211 Posts: 1,488
    edited January 2010
    That could start a debate.Compression,soldered or set srew.I wouldnt worry to much about that.Just use some deoxit gold to protect the copper or silver.
    If I were to DIY another set of speakers cables I would use Xhadow nanners.>http://www.cryo-parts.com/banana.html
    There very expensive though.Overpriced IMO
  • Zitro
    Zitro Posts: 864
    edited January 2010
    fbm211 wrote: »
    Hmmm..if anyone does give these a try, let me know what you think. I'm interested in a good, cheap cable.
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • fbm211
    fbm211 Posts: 1,488
    edited January 2010
    You cant go wrong with monarchy audio products.Great value for great products.Probably the best value in this hobby.
  • markmarc
    markmarc Posts: 2,309
    edited January 2010
    Been using AudioArt speaker cables for two years. Very flexible, far more than most at this price. Very neutral sound.
    Former Staff Member TONEAudio
    2 Ch. System
