Audio Art Speaker Cables?
Jetmaker737
Can anyone comment on these cables?
http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1268501097&/Audio-Art-Cable-SC-5---SC-5-bi
I'd be interested in any input on these 14 AWG silver coated copper stranded cables versus, say, the AQ Type 4 with solid conductors.
Post edited by Jetmaker737 on
Good cables at a budget price.Those are probably DH Labs T-14 cables sold under a different name.Audio Art works with them and I bet thats where they get thier raw cable.
I use T-14 cables in a shotgun config.
If you like your sq a little tipped up, go with them.Other wise the AQ Type 4 are a solid choice too.
Right here is a very good speaker cable for the price.I may have to try these myself>>http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1268374784&/Monarchy-Speaker-CableSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I wouldn't worry about it, all speaker cable technology is just a myth. Just get ya some 12 gauge zip cord at Lowes, it's as good as anything else out there.;) Sorry, I couldn't resist!
Interesting... thanks for the link. What do you think about those compression fit nanners compared to soldered?SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
That could start a debate.Compression,soldered or set srew.I wouldnt worry to much about that.Just use some deoxit gold to protect the copper or silver.
If I were to DIY another set of speakers cables I would use Xhadow nanners.>http://www.cryo-parts.com/banana.html
There very expensive though.Overpriced IMOSDA-2BTL with custom IC
Hmmm..if anyone does give these a try, let me know what you think. I'm interested in a good, cheap cable.- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
You cant go wrong with monarchy audio products.Great value for great products.Probably the best value in this hobby.SDA-2BTL with custom IC
Been using AudioArt speaker cables for two years. Very flexible, far more than most at this price. Very neutral sound.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
