Hello to all Polk Members
Amherst
Amherst Posts: 695
edited January 2010 in Speakers
I am obviously new to this forum. Hello To everyone!
I have been running Polk speakers for the last ten years or so and really enjoy my home theater.
Could really use some expert advise on my setup.;)
Recently have been upgrading everything including my Polk's.
I am about to swap out my Monitor 40's for some LSi9's for the fronts.
My center is being served by a CSiA6. I love the center, it has some very natural sound in movies.
Question Is: How much of a soundstage mis-match will I have pairing this center with the LSi's?
A little concerned because things seem to blend so well now and the center is only a few months old.
Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
Post edited by Amherst on
  • Pycroft
    Pycroft Posts: 1,961
    edited January 2010
    Hello and welcome to club polk! I can't answer your question about the soundstage, but I'm interested what AVR/Amp you will be using to power LSI9's. They will require much more power than most standard AVR's can handle!
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • Amherst
    Amherst Posts: 695
    edited January 2010
    Pycroft wrote: »
    James
    Hello James, I am also located in South Jersey.
    The power will be provided by a B+K AVR5000II. The amp is conservatively rated at 125 w/per channel. Not a ton of power but should suffice.
    I found that my Monitor 40's were difficult to drive with a Yamaha receiver, hence the purchase of an outboard amp.
    The processing is being handled by a new Pioneer VSX23TXH. :)
  • bluecomet
    bluecomet Posts: 1,118
    edited January 2010
    Pycroft is right. The Lsi speakers are 4 ohm. Not many AVR's can handle 4 ohms. If you have pre outs on the back of your receiver you are going to have to use an external amp to handle the Lsi 9's. Also you should really use a LsiC with the 9's to have sonic balance.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • Amherst
    Amherst Posts: 695
    edited January 2010
    Lasareath wrote: »
    Welcome to Club Polk!!
    Thank You, Lasareath. Lot's of Jerseyian's around here!
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2010
    Welcome to the club!!!
    The LSI 9's and CSI a6 are two totally different sounding series. The lsi's are very laid back (good for music) while the csi's are more of a bright forward speaker( good for HT).
  • Amherst
    Amherst Posts: 695
    edited January 2010
    bluecomet wrote: »
    Yes, I fully understand.
    The deal on the LSi's I could not pass up. So now I know I have a mis-match.
    Question is how much of a mis-match? The well has run dry for more purchases!
  • packetjones
    packetjones Posts: 1,059
    edited January 2010
    Welcome to the club.
    I have never heard the LSi9's so i can not say for sure how they will sound. In regards to the mismatch, the monitor 40's and the CSiA6 is not a match now. I would say that if it sounds good to you now then the LSi's will sound fine as well.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Amherst
    Amherst Posts: 695
    edited January 2010
    The 40's and the A6 work really well together if you feed them well.
    Without the outboard amp it was weak sounding like something was missing and distorted at decent volume.
  • Amherst
    Amherst Posts: 695
    edited January 2010
    leroyjr1 wrote: »
    Hi Leroy, The reason I was seeking a pair of LSi's is for music.
    I found the 40's to be a very good performer but did not put me at the place I really wanted for two channel music.;)
    Thanks for the welcome!
  • jimmydep
    jimmydep Posts: 1,305
    edited January 2010
    I've used a CSI-a4 with LSi-15's, and it didn't sound as mismatched as I thought it would, actually I thought they sounded pretty good together. I did replace the A-4 with an LSIC and it does sound slightly better, although I had to increase the gain on the LSI center about 6db in order to hear the dialog better.
    I don't think you'll need to rush out and replace the A-6 if your using it primarily for HT, but if you listen to music in surround then you'll notice a big difference.
    BTW... Welcome to the Club.
    Jimmy
  • Amherst
    Amherst Posts: 695
    edited January 2010
    jimmydep wrote: »
    Jimmy
    Thank You for the welcome and insight, Jimmy.
    The A6 is awesome with dialogue, and my setup has it set flat (no gain), and the soundstage sounds proper to me. That is why I was concerned.
    Your post helps the worry factor.
  • Pycroft
    edited January 2010
    So...what AVR/amp do you use?
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • Amherst
    Amherst Posts: 695
    edited January 2010
    We're pushing the setup with a B+K AV5000II.
    The processing is handled by a Pioneer VSX23THX.
    This seems so far to be a good combination, nice and smooth.
    Pycroft, Did you get the reply message?
  • Amherst
    Amherst Posts: 695
    edited January 2010
    Have been looking at the specs on the LSiC, and because of driver size and especially cabinet depth, leaves me wondering if that is why Jimmy has to boost DB for proper dialogue. Or, is this due to placement?
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    I'd say get the LSiC; generally, front sound stage mismatch is a no-no. Keep your eye out on eBay, CL and the flea-market here; they pop up from time to time on the (relative) cheap.
  • Amherst
    Amherst Posts: 695
    edited January 2010
    This is the quandary. The well has run dry for purchases and am left wondering whether I would be trading good dialogue performance for weak on the LSiC?
    If the mis-match is somewhat minimal I may opt to keep the A6.
    Will find out soon.
    Wish Polk had a more stout offering for a center in the LSi line.
  • bluecomet
    edited January 2010
    The LsiC is not weak in dialogue, only if you have it underpowered. If you power your front mains and LsiC with a good 4 ohm amp the speakers are outstanding for music or HT. You can run different series rear speakers if you can't afford to have a complete Lsi system without hurting you too much sonically.
  • Amherst
    Amherst Posts: 695
    edited January 2010
    Kex wrote: »
    Welcome to Club Polk, and the potential for eternal poverty, Amherst.
    Thanks Kex, the poverty point has arrived,hope it's not eternal!
    If this were me, I would first try the LSi9 with a phantom center, if funds are too short for a new LSiC.
    I will try this idea.Think that with my layout it will be a problem, the fronts are tucked away in the corners.
    For music, you may want to use two channel only anyway, or 2.1, depending on how musical a subwoofer you have.
    Yes, 2.1 for music is the whole idea. I am using the DSW Micro Pro 1000.
    This sub sounds very musical IMHO.
    For your power, I'm assuming you meant the B&K AV5000 Series II (not AVR, as you stated above).
    The "AVR" is a typo. I'm definitely in agreement about quality amplification.
    I didn't hesitate when I was offered to buy this amp, it is very clean sounding and powerful.
    I don't think you mentioned what surrounds or subwoofer you are using. These could easily contribute to the overall performance factors to consider.
    Well, the surrounds are a work in progress. Currently a pair of Monitor 30's are doing the duty. A friend is letting me use a pair of OWM 3's to try to see what they sound like. This is all a compromise as I'm up against the WAF, and have to loose the 30's or suffer consequences.:(
    Would love to think about a pair of LSi7's for that duty but as with the 30's there is no chance. Had half a war to get the Monitor 40's and stands into the living room.:p
    Ahh, for the love of money!
  • domflane
    domflane Posts: 653
    edited January 2010
    If you already have the CSiA6, try it out with your LSi's. For HT, I think youll be more than satisfied. The center is the star in HT, the others are more like effect speakers so IMO it will be hard to really notice the mismatch. The A6 is a phenomenal speaker, I cant wait until there's one under my TV. I would not mix the LSi's and the CSi for music however, stick to 2 channel and let the LSi's shine. Thats what they're really made for. My center and mains don't match and I really have no complaints except that I want the front to match. Good luck and welcome to the club.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • Amherst
    Amherst Posts: 695
    edited January 2010
    domflane wrote: »
    Thank You Domflane,
    I am definitely going to find out what this combination sounds like.
    Guess I am simply in a paranoid mode with this move, just have to do it as the deal is that good. The system sounds really fine now and I don't want to break that.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    A warm Welcome to Club Polk Amherst!
  • danz1906
    danz1906 Posts: 5,144
    edited January 2010
    Welcome to the Club!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • McLoki
    McLoki Posts: 5,231
    edited January 2010
    Welcome to Club Polk.
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited January 2010
    Oh God another Jersey guy!!!!!!!!!!
    We hate Jersey guys here, well I know I do. One in particular that lives down your way.
    Welcome to the forum. Get ready for an interesting adventure and a costly one too.
    Advice, use the search function and read/study a lot for starters. The guys as you can already see are extremely helpful. They do a real nice job spending money and do even better at spending yours.
    Good luck and again welcome.
  • hearingimpared
    edited January 2010
    NJPOLKER wrote: »
    Oh God another Joysey guy!!!!!!!!!!
    Fixed it for ya!:p
  • Pycroft
    edited January 2010
    I think he was tryign to reflect the Jersey accent :)
    ... And Amherst...I did receive your response PM. We are close! :)
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    Fixed it for ya!:p
    LOL, and I agree with the LSiC. Give your center a shot, but as stated above the center is the "centerpiece" of any HT. IMHO, a mismatch is a no no. Welcome to the club form another right coaster (originally from CT.)
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Amherst
    Amherst Posts: 695
    edited January 2010
    Thanks everyone for the warm welcome!
    Note on beer here in this section of South Joysey:
    Haven't had any headaches since the last time we had.....
  • amulford
    amulford Posts: 5,020
    edited January 2010
    Where in SJ, bro? Welcome to the pit of destitution, BTW. Don't listen to these scrubs, they'll have ya broke in a new york minute...
  • hearingimpared
    edited January 2010
    amulford wrote: »
    pot, kettle, black!:D
