Repair RT25?
3dmdlr
Greetings! I am new to the group and hope someone can help me. I have searched but couldn't really find what I was looking for. First of all I am pretty speaker illiterate so I will probably get the terminology wrong, please don't hold that against me
I have a set of RT25's i have had since 1998. They rock and I have always loved them. Some say too bassy but I likes me some bass. Anyway, one of the tweets stopped working a while back(years) and i have just decided today to dig into it and see why. I disassembled the cabinet and removed both speakers and the board(driver? crossover?). I've hooked up the speaker to just speaker wire and it works just fine. I've also hooked up the bass wire from the board and it worked just like the other speaker. So I have decided it is one of the few components on the board and they look easy enough to solder so can some one give me some insight on how to fix this? Thanks!!
Post edited by 3dmdlr on
Since you isolated the problem to the crossover board, do the following:
- check if there are any cold solder joints on the board (poor soldering). Ideally, quick run with a soldering run over all joints usually helps.
- check if the electrolytic capacitors are bulged at the top (the little cans). Sometimes they "pop" and you have to replace those.
Unless the speaker was dropped, the inductor and the resistors usually wouldn't be the first ones to fail.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
As was already mentioned, with high frequency signal (tweeter) you should suspect the capacitors first. Have you tried connecting a different speaker to the tweeter wires? Any sound that way? Most likely a poor solder joint somewhere would be my guess too.
JimInfinity QLS1, Polk SDA-1A, OLAdvent Econowave, Yamaha RXV-1300, CDC-685, P2200, AB International 9220A, Rane ME15B, Cambridge Audio 640P, Grant Fidelity B-283, Luxman PD277-AT7V, Pioneer PL707-Denon DL-207, DL-160....And projects on the bench!
