PS Audio PerfectWave AC-12 Power Cord
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited November 2012
    Hi, DarqueKnight,
    Hi Paul. Welcome to the forum.
    Have you tried the following setup:
    wall---> AC-12 ---> power amp. (int. or monoblock)
    Yes.
    wall ---> AC-12 ---> preamp.
    Yes.
    wall ---> AC-12 ---> DAC
    wall ---> Premeir SC ---> CDTransport
    With my SACD player, not with a separate transport or DAC. The AC-12 sounded better between the wall and the SACD player. The Premier SC sounded better between the SACD player and the AC regenerator.
    Do you think too many AC-12s will sound bad?
    I don't know. The only bad experience I have had with the AC-12 was when I put it between the wall and my AC regenerator.
  • Paul J Wright
    Paul J Wright Posts: 13
    AC-12 On Turntable Motor Power Supply
    Apparently, the over 1000 hours of use of this Premier SC made a world of difference. I left it in place because it was providing Such Good Sound. :)
    Hi DarqueKnight, thank you for your reply.
    Do you think the "after-1000-hrs.-Premier SC" can outperform AC-12 generally?
    thank you!:rolleyes:
  • DarqueKnight
    Generally...no.
  • Paul J Wright
    DarqueKnight, thank you!
    you help me to save $$$...
    I will focus on AC-12 only.
  • Paul J Wright
    Generally...no.
    thank you!
  • DarqueKnight
    The AC-12 is a much better power cord for much less money. However, there may be situations were the Premier SC will sound better. The only time I experienced this was comparing the AC-12 and Premier SC between a component and an AC regenerator. I forwarded this result to PS Audio and they said they could not duplicate it. I also posted my results on the PS Audio forum and no one there said they experienced this.
    Please be aware that PS Audio power cords, especially the AC series cords, are widely counterfeited. Make sure you buy from a trusted source.
  • Paul J Wright
    "could not duplicate it."
    what do you mean?
    could not use both Premier SC and AC-12 at the same time in one system?
    thanks
  • DarqueKnight
    what do you mean?
    In my 2 channel audio system, when I used AC-12 power cords between a PS Audio Power Plant Premier AC regerator and audio components or when I used AC-12 power cords between a PS Audio P10 AC regenerator and audio components, there was a loss of sound quality. I experienced the same thing in my home theater system when I tried to use AC-5 power cords between either a PS Audio AC Power Plant Premier AC regenerator or a PS Audio P10 AC regenerator and audio components.
    PS Audio said they did not experience a reduction in sound quality when AC series power cords were used between an AC regenerator and audio components.
  • Paul J Wright
    thank you DK's reply!
    did you try the below setup?
    wall ---> AC-12 ---> AC Regenerator
    AC Reg. ---> AC-12 ---> CD player/Dac/Preamp etc.
    wall ---> AC-12 ---> power amp.
    thank you!
  • DarqueKnight
    Yes to all three questions. All three have been previously addressed either in my review or in answers to your questions.
    This is what I have now.
    I have already answered this.
    Yes. This is what I have now. This is discussed in the review.
  • Paul J Wright
    thz for DK's reply and insightful review.
    .....another issues.....
    I am using P-1000 (PS Audio AC regenerator)! I found it will distort the sounding and diminish a bit of dynamics of sound. Do you think so?
  • DarqueKnight
    The P-1000 has a continuous current rating of 7 amps and a peak current rating of 10 amps. Therefore it is highly likely that some high current power amps will experience compression of dynamics when connected to the P-1000. In comparison, the PS Audio P10 AC regenerator has a peak current capacity of 70 amps and even this is not enough for some power amplifiers.
  • Paul J Wright
    DK, wow, you really know everything about PS Audio's products....! I can't believe it!
    In fact, I didn't connect the power amp. to P-1000. P-1000 serves the CD transport and the Dac only.
    Thank you!
  • DarqueKnight
    No, I don't.
    I am surprised that the P-1000 was stressed by only two source components.
  • DarqueKnight
    edited November 2013
    My initial trials in 2009 with AC-12 power cords in my two channel audio system were not entirely successful:
    To summarize: In my system, AC-12's between the wall and a component sounded good, but AC-12's between the [Power Plant Premier] AC regenerator and a component sounded bad.
    The Power Plant Premier AC regenerator was replaced with a P10 regenerator in November of 2011. I recently conducted trials with AC-12 power cords between the P10 regenerator and the source components and preamps. Those trials were successful.
    Figure 11. Cute! A "baby" 1/2 meter AC-12 was installed between the SACD player and its PowerBase
    isolation platform.
    Figure 12. I wasn't sure that a 1/2 meter AC-12 would work due to the stiffness of
    the cord and the bend radiuses required, but I wanted to try it because the 1/2
    meter AC-12s were on closeout for $199.99 and free shipping.
    Replacing the Cary Audio CD 306 Pro Version SACD player's 1 meter Premier SC power cord with a 1/2 meter AC-12 resulted in more tactile sensation, heavier images, and more "growly" bass. However, there was a small loss of overall clarity and detail, but not the severe veiling that was heard when the former Power Plant Premier was used.
    The new AC-12s were burned in on the JuiceCyclone power cable conditioner for 24 hours continuously at 10 amps, then burned in for another 24 hours continuously on the Audiodharma Cable Cooker.
    After burn in the replacement of the SACD player's Premier SC power cord with an AC-12 resulted in the following improvements:
    1. Apparently louder sound level.
    2. More overall clarity and detail, especially micro-details in the center.
    3. Enhanced depth.
    4. More image weight and tactile sensation.
    5. More bass articulation, weight, detail, and growl, especially micro-growls.
    6. More holographic imaging.
    These improvements increased as the Premier SC cords were replaced on the SACD player's PowerBase isolation platform and then the Pass Labs XP-30 preamp.
    For the analog source, I did not do incremental replacements because it would have required pulling my very heavy audio cabinet from the wall an additional three times to replace the power cords for the Pass Labs XP-25 phono preamp, turntable PowerBase isolation platform, and turntable motor power supply. A listening session, with detailed notes, was done with the analog electronics powered by Premier SC power cords and then another listening session was done with all the Premiers replaced with burned in AC-12s.
    In addition to listening evaluations, stroboscopic speed measurements of the turntable's motor speed were done with the Premier and AC-12 power cords. With each cord, there was no measurable plus or minus speed drift. With the Power Plant Premier and AC-12 trials in 2009, the turntable motor ran 0.08% slow. In the 2009 trials, when the motor was connected to the wall with an AC-12 the motor ran 0.08% fast.
    Replacing the three analog side power cords with AC-12s resulted in the all of the improvements cited above, with the addition of a slightly "hot" high end. There was a bit of added sizzle to drum brushes, ride cymbals and female voices. The hot high end took five hours of play time to settle down into silky smoothness.
    From most to least improvement by component with the AC-12 power cords:
    1. Pass Labs X600.5 power amplifiers.
    2. Pass Labs XP-30 preamplifier.
    3. Pass Labs XP-25 phono preamplifier
    4. Cary Audio CD 306 Pro Version SACD player
    5. PS Audio P10 AC regenerator
    6. PS Audio PowerBase for SACD player.
    I did not evaluate the power cord replacements for the turntable's motor power supply and PowerBase separately, therefore I could not rank them.
    While my audio cabinet was pulled out from the wall, I took the opportunity to place stiff foam blocks (just like the ones in figure 12) under the power cord plugs connected to the P10. That relieved a lot of strain off the plug and receptacle. I should have done that when I initially installed the P10 and I should have done it for the Power Plant Premier.
    F1nut Posts: 52,134
    Cute! A "baby" 1/2 meter AC-12 was installed between the SACD player and its PowerBase isolation platform.
    That cord is cute.
  • doctorcilantro
    doctorcilantro Posts: 2,028
    Where can one score a .5 AC-12. PS Audio has them but same price as 1m : (
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
