SDA question/problem
vmaxer
vmaxer Posts: 5,120
edited October 2009 in Troubleshooting
I have a set of SDA SRS 1.2tl's...and am looking for help to correct an issue:
If I hook the speakers up without the interconnect and set the levels using the preamp's calibration function, the speakers outputs are the same on my SPL meter. I then connect the interconnect and the right one runs about 3db louder than the left one?? I can't seem to figure this one out. I swapped the crossovers between the speakers and it had no effect??
Any ideas??
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
  • kcoc321
    kcoc321 Posts: 1,788
    edited September 2009
    Did you follow the "SDA balancing" procedure? I think it is posted in the Vintage speaker/ SDA thread.
    I seem to remember several ppl reporting that the "balanced" location turned out to be 11oc or so..I don't remember exactly...So I think you have no worries...but check it out.
    http://www.polkaudio.com/forums/showthread.php?t=85837
  • vmaxer
    vmaxer Posts: 5,120
    kcoc321 wrote: »
    Thanks,
    I can do some of these tests, but not the ones that require a balance knob....don't have one:(
    Additionally, if I unhook the interconnect cable, all eight drivers still function:confused: I just talked to Ken at Polk Audio and have some things to test out... But welcome all the advise I can get as these have about whipped me!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    nooshinjohn Posts: 25,890
    If all 8 are functioning with the interconnect removed, someone may have bypassed the SDA functions... I would begin by looking at both crossovers and the terminal plates to make certain no mods have been done.
  • vmaxer
    vmaxer Posts: 5,120
    I have completed a couple quick tests...had to take a time out and mow the yard...
    If I remove the neg cables from both speakers and plug the interconnect in all eight drivers work, the volume is very low, but they all work??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    Lasareath wrote: »
    Are you sure all 8 drivers functioning per speaker or are 4 playing and you just think sound is coming from the other 4?
    No doubt, I have pulled all drivers out and know which ones are being powered..
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • DarqueKnight
    DarqueKnight Posts: 6,765
    With the interconnect cable disconnected, the dimensional drivers will still move due to two reasons:
    1. Air coupling within the cabinet (which is also how motion is transferred to the passive radiator).
    2. There will still be a small amount of signal reaching the dimensional drivers, even if you remove the 7 other drivers, passive radiator, and tweeters so that there is no air coupling.
    If you look at the crossover schematic, you will see that the dimensional drivers are not electrically disconnected from the crossover, and therefore the input signal, when the interconnect cable is disconnected. However, the dimensional drivers should never play as loud as the stereo drivers.
    Bear in mind that speaker crossover circuits are more like traffic conductors rather than "brick wall" barriers. Even with the interconnect cable removed, there are certain frequencies that will make both the stereo and dimensional drivers move, just as there are certain frequencies that will make both the bass and midrange drivers move and again, the same with the tweeter and midrange drivers.
    With my preamp's balance control set on "0", my right 1.2TL plays a 1 kHz test signal 1 dB louder (dB-C) than the left. With a 60 Hz test signal, the right 1.2TL is 1.5 dB louder than the left. I don't know how much of the disparity is due to electronics and how much is due to room interaction. The left speaker is 3 feet from a side wall and the right speaker is 15 feet from a side wall.
    vmaxer wrote: »
    This seems to indicate a channel imbalance in either your amp or preamp. Do you have another amp and preamp that you can swap out?
  • vmaxer
    vmaxer Posts: 5,120
    DarqueKnight,
    Thanks a lot for your reply, I do feel a lot better. I have had a long day at work and just don't feel like testing tonight. Hopefully tomorrow will be better and I will try a few things.
    Over the weekend I did connect an old Onkyo TX-SV535 receiver, that has a balance control!!! First, it suprised me, the sound wasn't half bad.... Anyway, the speakers did function as they should per the quick tests - SDA functions procedure. The best balance was with the knob set to just before 11 o'clock.
    I do have one question, when you state:
    "With my preamp's balance control set on "0", my right 1.2TL plays a 1 kHz test signal 1 dB louder (dB-C) than the left. With a 60 Hz test signal, the right 1.2TL is 1.5 dB louder than the left. I don't know how much of the disparity is due to electronics and how much is due to room interaction. The left speaker is 3 feet from a side wall and the right speaker is 15 feet from a side wall."
    Are you unhooking one speaker or moving in front of each one to test them...since you say your balance knob is on 0??
    Thanks again!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • DarqueKnight
    I left both speakers connected. Measurements were taken standing 2 feet in front of each speaker.
    room acoustics would play a big factor in that result...
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    Well, I've not been to do much lately, bot my daughter and I have bee sick a couple of times, she's just getting over the flu....
    Quick question, when I am installing the crossover back onto the mount does it matter how the inductor is connected?? 2 wires, both black, same size connectors??
    Thanks!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    vmaxer wrote: »
    Thanks!!
    Not sure about your SDAs but my 1Cs have the wire labed P on circuit board going to left connector and one labled R going to the right.
    Hopefully someone with more experience and knowledge will comment.
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    My boards are also labeled with a P and R, when you say right and left, what perspective, from top looking down with the connections at the top??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    I think the P and R connectors go to the large inductor.
    Ben
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    ben62670 wrote: »
    They do, but does it matter which way they are connected??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • thsmith
    edited October 2009
    vmaxer wrote: »
    yes, thats the way my 1Cs are
  • DarqueKnight
    edited October 2009
    vmaxer wrote: »
    No. The inductor is just a plain coil of wire.
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    Many thanks DarqueKnight...Care to look at thie thread as it has a few of us puzzled???
    http://www.polkaudio.com/forums/showthread.php?t=89204
    I need to know if my speakers are wired correctly or not...Is the thin or wide terminal on the tweeters positive??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • DarqueKnight
    edited October 2009
    The wide terminal is negative and should have the white wire connected to it.
    In some 1.2TL's, both wires going to the tweeters are white, but the positive terminal wire will have a colored band near the ends.
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    Thanks again, but I am getting a bit confused...Is the wiring connector correct?? Doesn't make sense to me....See photo, all white wires are on positive??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • DarqueKnight
    edited October 2009
    I don't think Polk meant for their customers to ever look inside their speakers. One can easily get confused if all the "family secrets" aren't known.:)
    If you compare the crossover schematics for the 1.2 and 1.2TL, you will see a lot of circuit layout similarities. One big difference is the polarity arrangement for the tweeter array.
    The polarity markings in your picture are the same as those of the 1.2, so I suspect that you have a 1.2 board with 1.2TL parts. Polk had a practice of using up old parts from a previous model.
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    I sometimes wish I hadn't "looked inside"...But then, I have learned a lot, and upgraded my crossovers and binding posts!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • DarqueKnight
    edited October 2009
    I sometimes wish I had never gotten into audio...but it's too late to turn back now.:)
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    If you ever decide you want out, I will come and pick up your equipment and care for it for as long as you want:o
    I have very reasonable fees........ :eek:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • RichCanDo
    RichCanDo Posts: 177
    edited October 2009
    vmaxer wrote: »
    Any ideas??
    In reply to your original question, my right channel also is louder than the left. I have my balance control just below the 12 o'clock position. This seems inherent with the model as others have noted the same thing. I thought it may be room acoustics, but have had my TL's in 2 different homes with same result. I now have both speakers 6'-8" from the side walls and 6'-8" apart on the long wall of a rectangular room. Still, right speaker plays louder than the left, hence the balance control setting not dead on at 12 o'clock. I set the balance by ear and not yet used my sound level meter.
    Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
    Pre-amp: DBX CX1
    Center: CS1000p Rear Surr.; f/x1000
    Parasound HCA-1205A amp; Center & rear
    Sub: SVS PB12-Ultra
    DVD: Denon 3910
    Tuner, FM: Onkyo Integra T-9090II
    Cassette: Onkyo Integra TA-2090
    VCRs: JVC HD4000U digital, HRS8000U SVHS
    Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
    Conditioning: Monster AVS2000, HTS5100MKII
    F1nut Posts: 51,698
    edited October 2009
    All 3 sets of my SDA's are perfectly balanced. The likely cause, if not room related, is your pre amp.
  • RichCanDo
    edited October 2009
    I have measured my pre amp outputs in the past and they are equal to 4 digits on a voltmeter. I have also swapped the right and left preamp outputs and the right speaker was still louder than the left. Maybe it has something to do with different values of xover components due to age or tolerance of the parts. I'll see what the volume levels are like after I upgrade my xovers with matched parts.
    Pre-amp: DBX CX1
    Sub: SVS PB12-Ultra
    DVD: Denon 3910
    F1nut Posts: 51,698
    edited October 2009
    Hmmmm, have you tried swapping the crossovers and/or the drivers?
  • RichCanDo
    edited October 2009
    No, I have not tried swapping xovers or drivers. I just had my drivers out and I weighed each one. A +/- .4 ounce difference in the weight of 4 drivers from the same cabinet, same model # drivers. (almost a 1/2 ounce difference) Weight difference can be several things such as magnet weights, etc. But if higher weight is from more coils of wire used on a driver, this could make one louder than another. Normally speakers or motors would be wound with the same number of turns of wire. Possibly more turns were used on a speaker to keep the impedance within specs.
    Less turns of wire would make one speaker louder than another due to less resistance and a lower impedance.
    Pre-amp: DBX CX1
    Sub: SVS PB12-Ultra
    DVD: Denon 3910
