Possible blown Rt7’s
iwantsomepie
iwantsomepie Posts: 5
edited August 2009 in Troubleshooting
So I just discovered that my parents were former Polk owners themselves at one point. While rummaging through the basement I stumbled upon these babies.
They are Polk Audio RT7 – 17300
Unfortunately they sound like they are blown, the sound they emit is very dull and silent, no bass whatsoever. The little speaker at the top is releasing a tiny bit of sound while the bigger one at the bottom isn’t turning out anything.
I’ve attached a video of the RT7’s playing music; hopefully someone can diagnose the problem from it!
http://www.youtube.com/watch?v=eRogl_cfV4s
The receiver is a HK3480 and the other speakers in the video are my own Polk RTi A1.
I am hoping there is a way to fix these puppies and get them playing again. Any help is appreciated!
Post edited by iwantsomepie on
  • iwantsomepie
    edited August 2009
    Well I unscrewed the driver and took a look inside, but I have no clue what I am suppose to be looking for. Personally it all looks fine.
    I took some pictures of the connections that are going onto the driver.
    I have no idea what is wrong with them, obviously I would like to fix them.
    Can anyone help me out, I am a total newb when it comes to speakers and would love some help!
  • Talweh
    Talweh Posts: 149
    edited August 2009
    Fear not, someone here (with more knowledge than me) will probably be along shortly! Until then I would try to gently push in on the drivers to see if they're stuck or not. For some reason, I am not seeing the pics you posted, but make sure all the wires are connected. That's about all I know :)
    treitz3 Posts: 20,119
    edited August 2009
    Does the cone move in and out on the woofer without any friction whatsoever when you manually push it in?
  • iwantsomepie
    edited August 2009
    treitz3 wrote: »
    Yes, I can easily push it in, offers hardly any resistance!
    edited August 2009
    Thought so. Check all connections [especially IC's] leading to and from the amp. Also from the amp to the speaker. The speaker sounds fine. You have another issue.
  • iwantsomepie
    edited August 2009
    treitz3 wrote: »
    Honestly, they are broke. There is no sound coming from the bigger of the two drivers. You might not hear it from the video. The same setup runs my A1's just fine. I am pretty stumped :-/
  • messiah
    messiah Posts: 1,790
    edited August 2009
    Where are you located?
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • iwantsomepie
    edited August 2009
    messiah wrote: »
    Columbus, Ohio.
    I'm even more bummed out now, after doing some more research on these speakers they turn out to be one of Polk's best 'old school' speaker per say.
    Would love to get these fixed, anybody have anymore ideas?
  • vc69
    vc69 Posts: 2,500
    edited August 2009
    My guess is something in the x-over is shorted/blown but I'm no expert either. Do these have two sets of binding posts to connect to for bi-amp/bi-wiring? Is it possible you are connecting to just the tweeters? If there are two sets of posts, there should be a "bridge" that connects the two sets together.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • vc69
    vc69 Posts: 2,500
    edited August 2009
    vc69 wrote: »
    Should have looked at the pic's a little closer. Doh!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
    edited August 2009
    Hello again. Try this, take the woofers and hook them directly up to the speaker cables and play at a low volume. You will be bypassing the x-over altogether. Do you hear sound? Does it still have that crackle type sound we hear in the video?
    If it doesn't the woofers are fine. Try the same thing I][U][B]AT A LOW VOLUME!!![/B][/U][/I with the tweeters. The same questions with the woofer will apply. Try that and get back to us please.
  • nguyendot
    nguyendot Posts: 3,594
    edited August 2009
    More than likely the drivers are blown. You will know once you do what treitz3 said about hooking up the drivers directly.
    Main Surround -
