Music or Movies
Did you pick your Speakers for Music, Movies or Both?
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Post edited by danz1906 on
Both.
I use RTi A7's, CSi A6, and RTi A3's.
They sound great with Music and Movies, IMO. -
Both LS 90 in one and SDA SRS 2.3tl in the other
Sweet, now thats what Im talking about:cool:Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Both. If I had the money and space, a separate system
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50 -
Both.
I'm happy with the RTi's for HT, but just wanted something a bit better for 2 ch. I haven't heard the RTi A line, but my guess is I would still have done a seperate system.Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
I thought a visual might help.
Two nice looking systems. I also run two but I can't compare my second system to yours. That's a Primo set up! We're all envious of..?
cnh
thanks they all started out as fixer uppers except the ls90,s. What are you running?:) -
I thought I'd put down what Im running in my signature for my upstairs main HT. In the basement with the SDA's it a bunch of crap, Onkyo receiver Sony disc player Sansui eq but sure sounds sweet, looking to get a real good 2 channel for them but will have to wait for funds:rolleyes:
Nice looking systems:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Do you guys listen to Concerts on your systems?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Both for me - but biased more for music.
What is holding-up the center channel in your first pic?
Me?
B-Tech center mount - BT-15
Movies are fine but they show off on 2 channel.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
phipiper10 wrote: »Movies are fine but they show off on 2 channel.
Very nice musical speakers you have:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
How Musical is your system and why?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Music since HT was in it's infancy when I put together my first system. When I made the transition to HT my speakers sounded and continue to sound just fine.
Buy speakers that do music well & they will do just fine for HT as well. Get a beefy center channel as well, since 99% of movies go through your CC.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Well said,Get the Music right and the HT will follow:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
This is a question I now ask myself.
I now look for theater first speakers, then music. When you find speakers that do both for you , then it's a home run. Most of my life I looked at music first speakers.
So this really depends on your needs. I do about 50 50 in my system. But I use the system a lot for video games so thats like theater as well. So 60 40 would be the new split now.
DanDan
Purchased the LSi's and amps for both, although I listen to music about 90% of the time.
Sounds like your in the Music first Club:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I purchased speakers to perform both duties. In real-world application, however, the speakers see at least 80% movies and 20% music (lumping concerts into the music section).
That said, I auditioned speakers prior to purchase with only music I was intimately familiar with.Do you hear that buzzing noise? -
I started out thinking HT. Big mistake for me. Still back-tracking. If I could do it over I would focus on 2.1, then add a center, then move up to simple 5.1 by picking up some OWM3's or 5's. I just don't care whether the background matches perfectly. Now if I had a quiet room for two channel, then, well, I would be broke....MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
All depends on what you listen to more.Movies or music.Most times,picking a speaker for music first,will do well on HT also,not allways the case the other way around.HT SYSTEM-
lsi 9's -
i know when i bought my speakers that it will be used mainly for movies / tv .... but during audition i use music CD and concert DVD to check if the output sounds right for my taste
Any speaker that handles dynamics well is going to be just fine for HT, but some dynamic HT speakers aren't very subtle and struggle with various types of music. My system is a dual purpose rig and I've gone through various stages of development. I wouldn't put anything in the rig that couldn't pass the music first test, but they need to be extremely dynamic HT speaks too, for my satisfaction.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »Any speaker that handles dynamics well is going to be just fine for HT, but some dynamic HT speakers aren't very subtle and struggle with various types of music. My system is a dual purpose rig and I've gone through various stages of development. I wouldn't put anything in the rig that couldn't pass the music first test, but they need to be extremely dynamic HT speaks too, for my satisfaction.
Well said, very nice system.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
The Chris Botti-Live DVD concert is Very Musical:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I agree with Ron. Most speakers that are good with music should be very good for home theater as well. I purchased my speakers mainly for home theater but used music as my determining factor for the sound I liked.
The downside of that method - that I did not realise until after I purchased my speakers - is that many times, music sounds best (to me anyway) when presented in a detailed, but laid back way. For home theater - I still want the high level of detail, but laid back is not only less important, it can make the movie less engaging.
I am still happy with my LSi choice - but I have had to work hard and have made some mistakes in my electonics matching with them. Laid back electonics (like the typical NAD sound) does sound really good with music, but when combined with my LSi speakers - the system almost seems to laid back for really good home theater. (in my opinion) With some careful upgrades and modifications - I have gotten the sound pretty close to where I want it.
I have learned that for speakers - a good music speaker will be great for home theater. But when you put the entire system in place - you really need to taylor it to your preference and a good system for music is not always ideal as a good system for home theater. (i.e. - the buy good speakers and use your home theater rig as a 2 channel rig as well, will not always work out)
