tweeter polarity
richta
richta Posts: 26
edited February 2009 in Troubleshooting
Which side of the RD0194-1 is positive?
Post edited by richta on
  • george daniel
    george daniel Posts: 12,096
    IIRC,, black/blue to positive.
  • richta
    richta Posts: 26
    Thanks.
    Which side of the RD0198 is positive.
    They're not marked.
  • george daniel
    do the wire/connectors size match the tweets,,IIRC one is a narrow fitting/blade and the other is wider,,I'm thinking that the wide blade is positive,,but don't hold me to it,,have you tried the search function? Good luck.Let us know.
  • richta
    richta Posts: 26
    No hits from searching.
    One terminal on the tweeter is colored red.
    Negative?
  • ShinAce
    ShinAce Posts: 1,194
    Red is positive.
    Usually when there's one smaller terminal, it is positive.
  • george daniel
    then,, the black or blue wire should connect to the red terminal--hook em up and burn those puppies in,,get that SDA groove going. Have fun.I know that your amp is powered off--yes,,;)
  • richta
    richta Posts: 26
    Affirmative.
    and thanks..
    RT
  • Face
    Face Posts: 14,340
    ShinAce wrote: »
    Red is positive.
    Both terminals are the same size on the RD0-198.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Face wrote: »
    No. The RD0198 has a small and a large terminal, like the SL3000 it replaces.
    The RD0194 terminals are the same size, like the SL2000 it replaces.
    The differences in terminal size are the only visual differences between the RD0194 and RD0198.
  • ohskigod
    ohskigod Posts: 6,502
    and that man would know.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Face
    Face Posts: 14,340
    Doh...had a senior moment.
