RT3000P plays radio station without receiver on
dwjackman
dwjackman Posts: 3
edited December 2008 in Troubleshooting
I was ever so lucky to inherit a complete RT5000P set of speakers that had NEVER been out of the box. After installing the speakers using the best stuff I could afford I have a strange problem. At certain times of day I'm picking up what sounds to be a local A.M. radio station playing through the RT3000P subs at a low volume level. I've tried everything I can think of, including calling Polk's help desk. According to a supervisor (the only person that had been there long enough to have experience with these speakers) the problem is with the speaker amplifiers being sensitive to this type of broadcast. He said the best thing was to move the speakers around until the interference went away...not exactly practical since the whole room is the way it is just to house the darn things! Anyone have any ideas?
Post edited by dwjackman on
  • Fatbrando
    Fatbrando Posts: 275
    edited November 2008
    That's GOD talking to you...
    you better listen!
    FB
    Harman Kardon HK 3490
    Stanton STR8-100
    Polk SDA SRS 2.3TL (Proud newbie owner!)
  • ViperZ
    ViperZ Posts: 2,046
    Unplug the power from the amplifiers?
    The other thing - change the length of your speaker wires (make them longer / shorter).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • mantis
    mantis Posts: 17,207
    dwjackman wrote: »
    Try unplugging the Sub feed. Also try removing the speaker wire. You making something a antenna. Even the powercord if wrapped up the wrong way will become a antenna.
    If you are using cheap speaker wire or Sub cables, replace them with higher quality. If you need suggestions, I have many.
    Dan
    Dan
  • trubluluc
    trubluluc Posts: 2,067
    The same thing happened with my RT3000's.
    You probably have the older amps in them.
    If the green LED's on the front only come on when there is a signal...
    from receiver, and then shut off 5 minutes or so after you have shut down your system, you have the older amps.
    The new ones stay lit as long as they're plugged in.
    I was picking up a Mexican radio station on mine.
    Once I got the new amps installed, the problem stopped.
    -Luc
    F1nut Posts: 50,832
    Anything good?
  • ESavinon
    ESavinon Posts: 3,066
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • Fatbrando
    This is GOD Talking...
    ...since you live in So Cal, you shall now relinquish your SDA's to Fellow Polk forum brother FatBrando!
    That is all...
    Stanton STR8-100
  • dpowell
    dpowell Posts: 3,068
    Is it possible that your speakers could be picking up the radio signal through the ground wire in your house? You might try using a 2-prong adapter and eliminate the ground connection to the amp to see if the problem goes away.
    BTW, congrats on an awesome inheritance!
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • dwjackman
    dwjackman Posts: 3
    Thanks for the hints folks. Several of these things have already been tried but I didn't want to accidentally lead you, or myself, off in a specific direction. The speaker wire for the 3000Ps is Monster 10 gage and a different length from first set of 14 gage wires I started with. BTW, the noise plays on even with the speaker wire completely removed. At certain times of day the interference goes away. I like the Balun idea as that's something easy to try, as well as moving the speaker wire and power cords to different positions. Polk help desk supervisor also suggested that I try inserting aluminum foil between the speakers and the direction that I believe the station to be broadcasting from. He also said that this was a problem that he encountered several times with these speakers when they were being sold and that the problem was in the amplifier section. Also he as much as said that if after moving the speakers and trying the foil that I should be happy this isn't something that happens constantly...thanks...I think! I hope to get a chance to play with this on Friday or Saturday after the Thanksgiving company heads home.
  • zingo
    zingo Posts: 11,258
    Being a HAM, we have used EMI/RFI chokes for a long time to remove radio signals from equipment it's not supposed to be in. You could try putting them around the cables for the speakers, but if it does it even when they are disconnected, this may not work. You could try opening up the speakers and shielding the amp with some foil, or using a choke on the internal wiring between the amp and the woofers. Good luck.
  • dwjackman
    dwjackman Posts: 3
    Thanks for all the ideas folks. In the end I did several things at one time and one of them WORKED!!! No more aye yii ii music or La Cucaracha!!! I took back the power unit I purchased (Monster 1800) and replaced it with a Monster 3600 at half the price. I put baluns on the power lines AND moved both the AM and FM antennas...bottom line is NO MORE NOISE! Again, thanks for the help...and DAMN these speakers are GREAT!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    My friend was having that problem with a couple of 15" Cerwin Vega floorstanders for a while. He had been getting ready to upgrade all the wiring in his system anyway, so he replaced the wire with some higher quality speaker wire, and it fixed the problem.
    It was crazy when that first started happening...we're just sitting around hanging out, and we keep hearing the radio. We all thought we were going crazy until we finally tracked down where it was coming from...lol
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
