Suggestions for Reciever for LSI System
tcdesaix
tcdesaix Posts: 2
edited November 2008 in Electronics
Hi everyone,
I am trying to sell my full LSI set to a buddy of mine but his current Yamaha receiver cant handle the 4 ohm load all the way around. I have been trying to find him a receiver for under $800 that can do 4 ohm and also is new enough to do HDMI 1.3 switching with at least a couple HDMI inputs. Does such such a receiver exist? Any suggestions?
for reference he is going to be using:
2x LSI15
1x LSI C
2x LSI FX's
1x powered 12" sub (dont know brand)
Thanks,
Todd
Post edited by tcdesaix on
  • Face
    Face Posts: 14,340
    Does his receiver have preamp outs? $800 can buy a multichannel amp that'll power LSi's.
    http://emotiva.com/shop/cart.php?m=product_detail&p=4
  • tcdesaix
    tcdesaix Posts: 2
    He has a lowly Yamaha HTR-5560 which does have 5.1 pre-outs. I suggested that exact amp to him, and for some reason he wasn't interested. I need to try to convince him of that route i guess.
  • mantis
    mantis Posts: 17,424
    tcdesaix wrote: »
    He can get a nice Rotel receiver. All Rotel receivers handle 4 ohm loads. Also check out NAD and B&K. Both make 4 ohm load stable receivers.
    Dan
  • curved
    curved Posts: 664
    I would be buying Lee's Rotel 1075 and some good interconnects with that kind of budget
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • cfrizz
    cfrizz Posts: 13,415
    If he is not interested in spending the money to make sure the speakers are properly amplified....find another buyer!
    There is no way in hell I would sell my gear to someone who doesn't appreciate it or respect it as much as I do.
    tcdesaix wrote: »
  • suprafantx
    suprafantx Posts: 249
    Yes, Fry's has TX-SR875 on sale for 799 plus shipping.
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
  • Pepi28
    Pepi28 Posts: 248
    tcdesaix wrote: »
    What is he not interseted in, a seperate amp or that brand? You are not going to find a receiver that can handle those speakers and do HDMI decoding for cheap, especially new.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • mantis
    Kex wrote: »
    I'm not sure that would be a good option, since the LSi will dip below 4 ohms frequently, by reputation:
    "Onkyo does not recommend nominal speaker impedances of less than 4 ohms under any circumstances. In fact if the nominal impedance is between 4 and 6 ohms, it recommends that the speaker switch in the setup menu be changed from 6 ohms to 4 ohms. The Onkyo does run fairly hot, but I never experienced any problems using its 6-ohm setting with my Revel Concerta speakers."
    What has to be understood is the loss of dynamic range and heat issues. Some receivers like a Integra or Onkyo or even a Yamaha will hold the load but at a cost. Separate amps and high current receivers don't have a problem with this.
    Buy good speakers, buy good electronics. Pretty simple to me.
    Dan
    tonyb Posts: 33,072
    Haven't we been down this path....oh,a million or so times over the years? If you don't want to power them right,get different speakers or suffer the consequences.Pretty basic stuff.
