Crossover melt down
jerryj12
jerryj12 Posts: 451
edited July 2008 in Troubleshooting
Anyone have their crossovers melt on Lsi15. Mine decided to go on strike on me today.:( This is the second time it has happened. Is there a hot rod version I could purchase? I do like to listen to my music a tad bit loud. The Lsi15's seem to handle it with no distortion but the crossovers don't like it. I just hate the thought of replacing them.
Post edited by jerryj12 on
«13
    treitz3 Posts: 19,274
    edited July 2008
    Hello Jerry and welcome to Club Polk. What kind of amplification are you powering them with?
    F1nut Posts: 50,837
    edited July 2008
    What are you driving them with?
    F1nut Posts: 50,837
    edited July 2008
    Come on Jerry, let's go.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    Sorry I was asleep at the wheel here.
    I am using a Emotiva XPA-2 to drive them.
    I was editing my sig.
    F1nut Posts: 50,837
    edited July 2008
    It's a slow night here, ya know.
    Ok, what's the power rating and how loud is loud? In other words, where on the volume dial is loud?
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    The power output is 500 watts per channel. The preamp was reading -23 i think. The bryston I was using was only 125 watts per channel. It happened on that one as well
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    What fried. The inductors?
    Ben
    edited July 2008
    One more thing. Are you running a flat signal?
    F1nut Posts: 50,837
    edited July 2008
    Yeah, I looked it up, 500wpc @ 4 ohms. -23, eh? I'm not good with those damn digital volume levels. Would you say that -23 is more or less than halfway?
    F1nut Posts: 50,837
    edited July 2008
    Good question, Tom.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    I would say more than half way. ( The Sound was incredible I might say )
    As far as what fried I just know its white and square and broke. Sorry I dont know exactly what it is.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    Flat signal...Do you mean Stereo. If so yes.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    Wow I cant believe this response. You guys rule.
    F1nut Posts: 50,837
    edited July 2008
    You're more than likely clipping the amp at that level. Try to keep it below halfway.
    White and square.......could be a resistor.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    I will try. They just sound so good, even at that level. What is my next step Should I send them back again?
    F1nut Posts: 50,837
    edited July 2008
    Flat means no gain with the treble or bass controls, if you have those.
  • Face
    Face Posts: 14,340
    edited July 2008
    Flat Signal=0 for tone and 0 for bass.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    Ok the treble is set to +6 , bass 0
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2008
    A resistor hmmm.... who has the schematic?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    F1nut Posts: 50,837
    edited July 2008
    Jerry, it's kinda like a car. Just because the pedal goes to the floor doesn't mean you can peg it there all the time. Everything has limits, ya know!?!
    I take it you had Polk repair them before. If so, I'm sure they'll do it again.
  • disneyjoe7
    edited July 2008
    jerryj12 wrote: »
    Jerry I smell trouble at that level.
    What's your feeling on cable / wire?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    F1nut Posts: 50,837
    edited July 2008
    Run those tone controls at ZERO.
    F1nut Posts: 50,837
    edited July 2008
    Can you snap a quick pic of the square white thing and post it here? We'd be able to tell you exactly what it is.
  • Face
    Face Posts: 14,340
    edited July 2008
    There's a 2 ohm in the tweeter circuit, 1 2 ohm for each mid woofer(2), and 1 3.5 ohm for the woofer.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    I see your point. So did I just waste allot of money on amplifiers? And yes they did fix them for me before. It makes me sad to see the poor things in this shape.
    edited July 2008
    Where is your bass manager set at on the pre?
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    Getting the camera out now I will have it in a few.
  • Face
    Face Posts: 14,340
    edited July 2008
    jerryj12 wrote: »
    No, with a receiver you could have taken out a driver, if not the receiver also.
    F1nut Posts: 50,837
    edited July 2008
    No, you just have to learn the limits and how to run your gear. No tone gain.
  • jerryj12
    jerryj12 Posts: 451
    edited July 2008
    trying to figure out how to insert image
