SDA SRS 1.2TL Sonicap Upgrade
  • chandler9a
    chandler9a Posts: 878
    edited February 2010
    I have a feeling I need to get this done for my father's 1.2TL's. Maybe after the RDOs break in nice and good.
    Has anybody done this with a pair of SDA SRS 2.3's? ( non TL)
  • Neskahi
    Neskahi Posts: 297
    Funny you ask. I am sending my 2.3 xovers to Ben on Monday for an upgrade.
    Will report later on my impressions.
    SDA 2.3/RDO's... xovers by Ben
    SDA 2.3TL/Stock..
    SDA 1C/Solens/RDO's [gave to my Uncle]
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    M91 x 2 Pioneers/C91 Pre
    Yaqin MC10l
    DCD-1520/1560/2560 Denon
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • chandler9a
    That would be awesome, please do.
  • BAD ASP
    BAD ASP Posts: 361
    There are some step-by-step threads here. Do a search. If you still find it too scary (which I did at first, it was my first time in years) PM ben62670, he does crossovers for people all the time here and will do ya right by the price.
    BTW welcome to Club Polk.
    +1, I too can solder and read directions but didn't want to take a risk with a difficult to replace XO if I screwed it up. I contacted Ben and he did mine for me. I can honestly tell you the improvement in all aspects to the SQ is dramatic to say the least. Great guy to deal with and he turned them around very quickly. The boards are very easy to take out and reinstall. Good luck and welcome to CP.
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
    F1nut Posts: 51,786
    If you can solder and follow directions, exactly what do you guys think you are going to screw up? It's not rocket science.
  • hearingimpared
    hearingimpared Posts: 21,136
    That is a great point but there is a fear factor involved. I know, after years of troubleshooting computer boards down to component level and having been away from it for quite some time, I was sweating bullets when you and I did my crossovers.
    Once one gets past the fear it really is very easy. Proof of that pudding is I helped Sal do his xovers.
  • PolkMaster1
    PolkMaster1 Posts: 847
    I just did this myself rebuidling the crossovers using SonicCaps and Mills Resistors. They make a VERY impressive difference! Spend the money on this upgrade if you can!
    The soundstage is improved, the level of detail is better, and your speakers will sound as good as new!
    If you need help rebuilding your crossovers or soldering, let me know. I will help as best as I can.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • howl
    howl Posts: 2
    Thanks very much for the info. As I read about adding extenders, shrink wrapping prior to solder.....and I love these speakers, I am thinking it is best left to someone else. I pulled the crossovers out of the speakers today to take a look. Not sure I have the confidence.
    Thanks again.
