So I think I may have to unload the Shanling...
VR3
Its skipping about twice per song... kind of ok - but I don't like skips in my music...
What would you guys recomend to replace it?
Post edited by VR3 on
Cambridge Audio Azur 840cSRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
How much of a loser would I be if I don't get another CDP and just use my Zune dock.
I was listening to it today, and I think running direct to the preamp, not through the TV and with better cables - it could kick some ****...
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
just get the Shanling fixed. if you like it enough, that's what I would do.
if it's skipping. it probably only needs it's laser lens cleanedPolkFest 2012, who's going>?
Something that works.Vr3MxStyler2k3 wrote: »Its skipping about twice per song... kind of ok - but I don't like skips in my music...
Did you try cleaning it yet? What did Shanling have to say?
This might be helpful. http://club.cdfreaks.com/f44/lens-cleaning-disc-good-bad-218094/"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
In the $1000-1500 range I'd keep an eye on audiogon for Meridians - specifically the 508, 508.20, 508.24, 507, or 588. Man, those things hold their value well.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
I actually emailed Frank from Signal about some Analog II cables for my Zune Dock...
Going to use the Shanling until its unbearable...
With the way the economy is going, Im not buying **** right now thats to expensive...
Once the Shanling gets to bad, Ill probally unload it for like 60% of the going rate on Agon and cut my losses
Pick up one of the higher end units when the economy picks back up.
Might try a Jolida JD100 or something in that 5-600 dollar price range.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Damn, well if unloading it for cheap and in a crunch for cash, then I'd just pick up a used Denon DVD-2900 or 3910 for $200-$400. They sound quite good and also play SACD if you ever run into any of those. Plus you get great DVD playback. The Jolida is certainly a nice sounding unit once you toss the Chinese 12ax7 - still, I'd probably save the change and just go for a cheap Denon universal.
Act now - it's not worth killing your music enjoyment for any length of time, just to see what happens. Any decent deck worth its weight in metal will kill any un-DAC'd portable.
That represents the two ends of my digital scale these days - a Meridian if I fall into plenty of surplus cash, and my Denon 3910 works just fine until then. Vinyl is the main source here.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010 -
Save your money and get a Music Hall CD25.2. I bought a brand new one for $375 shipped to check it out and then dumped my Jolida. Awesome CD player.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
danger boy wrote: »just get the Shanling fixed. if you like it enough, that's what I would do.
Sid, don't be impetuous. Just clean the damn thing and forget about it.
We'll ban you from the 2-Channel Forum forever if you go from a Shanling to a Zune.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
the time to buy is when the economy is down. dont be a dumb ****.
RT1 -
I'd get a Musical Fidelity A3.2, Denon DVD-5900, or Marantz SA-8260 if I were you.
Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I was playing a few CD's this morning and it wasnt skipping at all..
So I guess I will just wait it out.
Its by far the best player Ive heard in my system -
And I've had it up against a Rega Apollo, a Denon SACD player (playing a SACD), and a Wadia 3,500 dollar player...
I always preferred the Shanling...
I would say the Wadia was a better player, but was a little boring for my taste... The Shanling is very lively and clear. However, I know there is better out there...
Music Hall sounds interesting.
Anyone have experience with the Onix CDP that AV123 has now?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Andy, I'm biting my lip so hard on buying that MF, it's bleeding. I have been wanting that CDP for ages--but the time just isn't right.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
You could send the player to Underwood HiFi and have it refurbed and upgraded. That would be sweet. Otherwise, I would recommend my Raysonic.
Steve - Well, with any luck (for you, not for me), it will still be waiting for you when the timing is right.
Sidious - have you purchased a $10 laser lense cleaner and tried it? My PE 59avi refused to read the SACD layer of hybrids for months. I was sure it was malfunctioning and on its way out.
After popping in a 5 years old $10 laser lense cleaning disc from 3M / Scotch, it was back to playing everything like new. At least try one out if you haven't already. Might just be some dirt. Make sure your discs are clean, too, obviously.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
You mean cleaning didn't work? I'm shocked.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
...and you'd be willing to move a potentially busted unit to someone else? That's pretty ****, IMO.
Radio Shack sells or at least they used to sell a cd with small brushes on the bottom to clean the laser. I can't say it ever helped anything I tried it on but ya never know.
BDT
Thats what I was thinking.
C'mon Sid,how lazy can you be to just clean the damn thing?HT SYSTEM-
lsi 9's -
Raysonic CD 168!
If you decide to buy new....
Sound Quest is supposed to be introducing a tubed version of their SQ-12 that I would assume will fall into your price range. I think it's going to be called the SQ-12GT. It's being built in cooperation with Granite Audio.
Just a thought.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
If the lens is not dirty, then its likely that the laser diode is weak or one of the servo motors is failing. Either way, cleaning, or new laser transport, its much cheaper to fix than to replace the whole unit, especially if you sell it for 60% of its going value. I'd venture to say that replacing the laser transport assembly on that unit would probably run you less than $100. Heck, if it uses an off the shelf Philips transport, it may only be a $30 part.
EDIT: Yes, I checked, this Shanling uses the Philips VAM-1201 laser. Those are ultra cheap. -
Good advice.
engtazengtaz
Ive got my eye on a 308,thought you would too over the 3.2.
Now all I need is the bosses blessing....yeah,right.:rolleyes:HT SYSTEM-
lsi 9's -
That's awesome and hilarious at the same time. It looks like you can fix it fairly easily, depending on what's actually wrong, which is great.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
That Philips transport is used in some of the most expensive players on the planet. Most of the boutique companies do not have the engineering or manufacturing resources to develop a unique laser assembly and produce it. They just use off the shelf stuff from Sony, Philips, or Panasonic. -
I'm aware. Sometimes it's a simple part at the core of everything.
Shanling is represented stateside correct?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I dont like messing with sensitive parts of electronics I dont know much about...
I'll use it till its unbearable then send it off to get maintenced or unload it for a fraction of its worth.
I dont see how thats a bad thing, especially if it is noted in the sale.
Ill figure it out. Thanks for putting morals back into me, SIR. :rolleyes:
**** Sid, Clocking Out.
Thanks for the tip on the motor/laser replacement. Will keep in mind.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Just get a Squeezebox and use your PC.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I thought it was obvious our little duper was disclosing the problem when he discounted the unit.
RT1--damm I am getting to trusting, I better snap out of it.
