Tweeter SL6502
Stammi
Stammi Posts: 7
edited January 2008 in Troubleshooting
Hi Guys - I blew both tweeters in my RT600 - where can I find a replacement - if possible in Germany? How can I check if they are really dead?
Stammi
Post edited by Stammi on
  • jcaut
    jcaut Posts: 1,849
    edited January 2008
    Are the 600's bi-wire/bi-ampable, with two sets of posts? I don't think they are, but if there are two sets of binding posts on the back, make sure that the jumpers between them are there and that they're tight.
    Were you playing loud music when they quit? If so then, yes, you probably blew them.
    The best way to check to see if the tweeters are really dead is to remove them and connect your speaker wires directly to the terminals on the tweeters. You'll have to remove the raised plastic baffle that holds the midwoofer and the tweeter. The tweeters snap out of the bezel, though there may be no need to completely remove them. Disconnect the wires connected to the tweeter terminals and connect the speaker wire from one channel of your amp directly to the terminals on the tweeter. Some alligator clip leads might make it easier. Play some music very quietly and increase the volume slowly- it would be easy to ruin a functioning tweeter if you play a full range signal with too much volume - Listen carefully to see if the tweeter makes sound. If it does, then it might be okay. If not, it's dead. If they sound like they're working, then that would indicate to me that there's a problem either with your receiver/amp or the speaker's crossover (unlikely that both would be bad, however) It's also possible that the tweeters are damaged but still produce sound, but if that's the case they should produce sound when they're hooked up normally, too: They'll just sound bad.
    I don't believe that an exact replacement for that tweeter is available from Polk any longer, but they do have a silk dome "functional replacement" that should work fine, especially since you need to replace both tweeters anyway.
    Contact Polk customer service directly for directions as to how to obtain replacement parts. 1 800 377-7655 or you can email polkcs@polkaudio.com
  • Stammi
    Stammi Posts: 7
    edited January 2008
    Thanks - I have only one post - and I followed your advice - both tweeters are dead...
    Do you have the technical data on the tweeters so that I can look for a replacement here in Germany - it is a little difficult otherwise.
    Thanks a lot - Stammi
  • Stammi
    Stammi Posts: 7
    edited January 2008
    Thanks guys - just talked to customer service - they will help me to find out how to get a replacement shipped to Germany. Will be better than fixing them with parts which will not be perfect....
    Greetings from Munich - better go skiing tomorrow.....
  • nikolas812
    nikolas812 Posts: 2,915
    edited January 2008
    I posted in your wtb thread about haveing two of these for sale. If you want to look into seeing what it would take for me to ship them to you maybe I could work a deal out with you to save you some money. Let me know.
    Edit: I have shipped a processor to germany. The guy that bought my processor did it through ups and ups came right to my house and picked up the processor. If I am not mistaken if the purchase is under $1500.00 there is not that much to getting them shipped.
