Problem With the LSiC
Shannon W.
Shannon W. Posts: 568
edited November 2002 in Troubleshooting
I just installed my new LSiC and love it..... But......... when It is played at reference Levels it Makes the Tv Flicker And Distort Color... What is up with it??? When you turn it down the tv clears up.
thanks Shannon
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
Post edited by Shannon W. on
  • Steve@3dai
    Steve@3dai Posts: 983
    Call Polk Customer service, they fixed mine.
    LSi 9/C/FX
    Arcam AVR-200
  • Frank Z
    Frank Z Posts: 5,860
    Shannon,
    Welcome to the Forum, figured you'd end up here eventually!
    What kind of TV do you have the LsiC setup on?
  • Steve@3dai
    They send out a new crossover, just FYI. Takes about 10 min to switch out.
    LSi 9/C/FX
    Arcam AVR-200
  • Shannon W.
    Whats up Frank??? Mank I just spent 12 Hours braking-in my new LSi7! I did'nt think i would ever get them to sound right!.. But they came around.
    Sony 36" Wega "Flat Screen"
    Forgot the Part#
    Guys sorry about this post i did'nt look far enuff down to see the other post.. "Sorry" :(
    Thanks agian
    Shannon W.
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • mantis
    mantis Posts: 17,207
    Shannon W from the Home theater forum correct??I read in there alot, post harldy never.. welcome to the forum.....The crossover was modified as steve talked about ,Polk is awesome in these matters,they will go way out of there way to make sure your speakers are working fine......cll em they will send you the new crossover.
    Dan
  • Shannon W.
    "Home Teatrer Forum"<---- Yes! what a great palce. only wish there was a live chat site that I could chat with people in real time. (for those qustions needing quick answers) Im going get ahold of some monday...
    thanks Again
    Shannon W.
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • polkatese
    polkatese Posts: 6,767
    Steve@3dai,
    Just curious, I owned the LSiC also, had not notice the problem you were indicating, I have the Elite PRO-HD520 HDTV, and currently the LSiC doesn't sit on top of the monitor, but might be in the near future....Is this problem identified as affecting "most" monitor, or specific to a brand? Who did you talk to at Polk to get the replacement crossover? Thanks for your help...fh
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Steve@3dai
    Well, mine is a traditional tube TV, it sounds like your is a projection so more than likely it won't have the same problem.
    Check this thread for the fix and a message from Ken:
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=5629
    LSi 9/C/FX
    Arcam AVR-200
  • polkatese
    Thanks Steve! fh
  • Shannon W.
    Steve How long did it take to get the new Cross over? Thanks Shannon
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • Steve@3dai
    Couple days
    LSi 9/C/FX
    Arcam AVR-200
  • Xzuluns
    Xzuluns Posts: 8
    How close to the HDTV is the LSic ? It may be your speaker is causing magnetic interferance with the TV. I know this isn't supposed to happen but I can't think of anything else that matches your symptoms. When operating the speaker at high levels your are creating a pulsing magnetic field. Also make sure the speaker wire to the LSIC is as isolated from the TV as possible. Don't have it tangled up with the power cord, the antenna or the cable connection. The fact that the problem goes and comes with the volume is the key fact here. You may need a ground isolator. The First thing I woud do is move the the speaker away from the TV and test the results of increased volume again. If the problem disappears then relocate the speaker further from the TV.
    PolkLover
  • Steve@3dai
    It's already been solved. The crossover fixes it.
    LSi 9/C/FX
    Arcam AVR-200
