poor sounding rti8
kaku42
kaku42 Posts: 33
edited December 2007 in Troubleshooting
Hi,
I recently bought a pair of rti8. In order to test it out, I removed the speaker wires from the front left and right speakers of my rm7200 5.1 set up and attached it to the rti8s. I also changed the receiver setting (Onkyo 601) for the front speakers to "Large"
The resulting system sounded horrible. Firstly, I watched Oceans 13. The RM7200 center speaker had to carry most of the load. For some reason, even the surrounds became weak.
To get rid of any dependency on the 5.1 set up, I switched to stereo FM. The rti8 sounded pathetic compared to the smaller front speakers of RM7200
I am convinced that either I am doing something basically incorrect or I have got a couple of lemons (from Frys). I am sure these speakers are not that bad?
Another related question - I am going to set it up in a different room and so looking for surround speakers on a budget. Will RM101 work with the rti8? (assuming i dont return them)
Kaku
Post edited by kaku42 on
  • Jed Leland
    Jed Leland Posts: 183
    Hello,
    Can you elaborate on what is not sounding correct? Do the speakers sound dull, with no high frequency response? Do they sound tinny, no mid range sounds? Just listen to them in two-channel mode, no surround sound going on. Listen with a vocal CD playing. Each speaker has three components, a tweeter and two mid range/bass drivers. Are all of them working?
    Jed.
  • kaku42
    kaku42 Posts: 33
    I am currently listening to a vocal CD in a 2 channel mode.
    It does appear that all the components are working. However, the overall clarity and range of the voice is disappointing for a speaker of this size and reputation. It sounds just about "average" - much louder than than the RM7200 fronts but not better in terms of sound quality. Bass is definitely missing and cant really say that the instruments are sounding distinct.
    Will keep experimenting with different kinds of CD all day today
    And the moment i put it in a surround set up, almost all the sound is getting directed to the center speaker (front= LARGE).
  • kaku42
    kaku42 Posts: 33
    its an Onkyo TX SR601 - have been using that for 3 years with the RM7200
    to give a more concrete example of "poor" sound - the helicopter sound at the beginning of the "we dont need no education" song in the Wall album (Pink Floyd) was muffled and hardly "distinct" sounding
  • kaku42
    kaku42 Posts: 33
    As I have indicated, I just took out the wires from the existing front speakers and put it in the rti8 and changed the front speaker setting on Onkyo to "large"
    so connections should be ok
  • McLoki
    McLoki Posts: 5,231
    What happens if you change the setting back to small?
  • kaku42
    kaku42 Posts: 33
    Doesnt improve it.. similar kind of output
    btw, i am now listening to "The Wall" using the DIRECT mode on Onkyo that sends pure stereo sound to the front speakers without any filtering and without subwoofer output. Thats the best test for the speakers.
    they sound very ordinary while playing the Wall. No effects from the drum beats or the Pink Floyd guitaring
  • kaku42
    kaku42 Posts: 33
    Crossover didnt help. The reason is because in a stereo mode (purest form), the subwoofer doesnt come into play anyway. All the sound goes to the side speakers
    anyway, if the front speakers are "large", the crossover shouldnt matter for them
  • GSRBOB
    GSRBOB Posts: 172
    Have you tried raising the levels in the calibration menu? I have the RTi 10's and i really had to raise the levels to bring them up to my likes. What size speaker wire are u using?
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    Pwr- Monster HTS 3600
    LCD- KDL-40XBR2
  • mantis
    mantis Posts: 17,380
    If everything is correct then maybe you just don't like the speakers. It does sound like you have the plus and minus backwards. When this happens, bass is thin and the speakers run "out of phase".
    Your Onkyo receiver is extreme bright and not a good match for polk speakers in my opnion anyway. It's a poor match.
    Dan
    Dan
  • kaku42
    kaku42 Posts: 33
    I will try this again this weekend with a new Harman Kardon AVR147
    AVR147 also has auto calibration so that should take out the level doubts
  • GSRBOB
    GSRBOB Posts: 172
    Ya I'm tired of my Onkyo. What AVR r u runnin Dan?
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • xandra
    xandra Posts: 291
    Kaku,
    Have you turned on 'Double Bass'? (you'll find under Speaker Config) This is only available after you've set speakers to large - you may need to back out of then return after making the switch. It's not an effect I care for, but for Movie dynamics, might be just what you're looking for.
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • Joe08867
    Joe08867 Posts: 3,919
    Sounds like they are out of phase to me. Check your speaker connections again. It is an easy mistake.
    Did you buy the RTI's new?? If they are used they may have some problems. Other then that aI say you just don't like them.
  • kaku42
    kaku42 Posts: 33
    Checked the wires - phase is correct. If the connections were loose, then I guess no sound would come from the speaker instead of poor sound
  • MSALLA
    MSALLA Posts: 1,602
    mantis wrote: »
    Dan
    Rti's are a bright speaker and so is the Onk. The 8's don't have alot of bass anyway. Most peolpe love them when backed up by a sub though.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • kaku42
    kaku42 Posts: 33
    ok thanks to all for your inputs. I agree that with playing around with Onkyo's calibration , the speakers sound much better now. Hopefully, the auto calibration in Harman Kardon will help further.
    In all, I am a bit disappointed with the speakers - looks like its not a great choice for playing music. They are good for movies.
    I won the battle with my wife to get these tall speakers instead of small cubes of bose and now I am losing the war:(
  • kaku42
    kaku42 Posts: 33
    also to add, its not a good idea to pair these speakers with a RM7200 set up.. though all polk speakers are apparently timbre matched, they dont mix well together
  • McLoki
    McLoki Posts: 5,231
    kaku42 wrote: »
    Nope each line is timber matched with itself, not each manufacturer....
    RM
    R
    Monitor
    RTi
    RTiA
    LSi
    All different voice matching. If you have fronts from any of these lines, you should check in the center channel options available from that line.
    Michael
  • ivansfo
    ivansfo Posts: 145
    I've experimented with the RTi8s driven by an Onkyo 701. The RTi8s are rear ported so you have be mindful of speaker placement or you will have poor bass. Generally, I believe they work best if positioned a feet or two away from the walls. I'm sure others can better advise you how best to position them in a room.
    This was the biggest problem for me and my room configuration did not allow for better placement. So I ended up returning the RTi8s. I really want to try out a pair of RTi10s if I can find a great deal on them. The RTi10s have front ports.
    I also felt the Onkyo 701 didn't provide enough power for the RTi8s to really come alive. So power might be a consideration too with your 601.
  • PolkWannabie
    PolkWannabie Posts: 2,763
    ... and just to be sure ... You do have the metal jumpers attached between the upper and lower speaker binding posts ... right ?
  • kaku42
    kaku42 Posts: 33
    1) Yes., I do have the metal jumpers attached. thats how they came out of the package and i didnt disturb them
    2) Do you guys think Harman AVR147 will be powerful enough to drive rti8
    3) Unfortunately i cant match the center since the csi3 is too huge..
    4) I have a bigger problem with my surrounds. I have ceiling mounts (and in-wall is not acceptable to my wife). => choice of rear speakers have narrowed down to rm8 or rm101
    Again that wont go well with rti8 though...
    anyway any recommendations on the surrounds (no, I cant hang rti4)
    again thanks to all who have replied so far.. have got some very useful tips
  • obieone
    obieone Posts: 5,077
    I may have missed something but, try wiring them thru the sub(if youcan), setting the
    8's to large, and the sub to off/no.
    Good luck
  • kaku42
    kaku42 Posts: 33
    actually, after setting it up from scratch with my new HK receiver, they are sounding great. HK drives these speakers much much better than onkyo. I am now much happier with the speakers
    my question on surround speakers is still open in case someone can help...
  • obieone
    Is there a 'space' issue? IF not, I'd go with RTi4's or Monitor 30's- closer matches.
    You might find a deal on RTi4's depending on where you live, and not a ton more $$$ than the RM101's
    good luck
  • kaku42
    kaku42 Posts: 33
    unfortunately space is an issue. I was also very tempted by the price of rti4- they are almost the same price as RM101 but the speakers will hang from a mount on the ceiling => have to be less than 8 lb
