SL 6502 Tweeter replacement.
2003 road king
2003 road king Posts: 2
edited October 2007 in Troubleshooting
Can anyone advise if the SL6510 tweeter is a viable replacement for the SL6502 on my RT55 speakers?
Thank you.
Dan
Post edited by 2003 road king on
  • 2003 road king
    edited October 2007
    Sal,
    Thank you. I will contact them on Monday.
  • Kex
    Kex Posts: 5,219
    edited October 2007
    Thank you.
    Dan
    I ordered a 6502 replacement: a 6511 is what was shipped.
    It has a dark colored dome instead of the light silver color. I also noticed that you can twist the tweeter away from the clips in the plastic surround that houses the dome. I am not sure if it is a good idea to do this or if you are risking any damage, but it would mean that if you prefer the original silver appearance, you might be able to switch the old dome and plastic surround onto the new tweeter ...
    Alea jacta est!
