Welding a metal spacer
eloplayspolo
eloplayspolo Posts: 1,117
edited June 2007 in Car Audio & Electronics
Would there be any negative to welding a metal spacer onto your door pannel for my momos, the door WILL be dynamated compeltly.
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    I can't see a problem with it if you've got the skills man...it's going to be dynamated anyway....
  • eloplayspolo
    edited June 2007
    would it be better than a regular spacer?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Bill Ayotte
    edited June 2007
    I see it this way man....It is a permanent solution to your problem, so take that into consideration...A spacer is a spacer really...Do it and call it done.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited June 2007
    if anything it'll simply be added structural integrity to what is likely a flimsy door panel inner.
    The Artist formerly known as PoweredByDodge
  • Unknown
  • BlueFox
    BlueFox Posts: 15,250
    Man I wish I could report this spammer, The report function is broke on both mobile and desktop for me...
    @CarlJacobson_POLK
    I noticed it was broke, but I assumed it was the fault of my old iPad. Whoever did this forum upgrade needs to be fired ASAP.
  • [Deleted User]
    @CarlJacobson_POLK
    Thank you, banned...a little late
  • Unknown
  • [Deleted User]
    [Deleted User] Posts: 0
    edited August 2021
    @pitdogg2 We have a full-time moderator assigned here now so I only check in periodically. I jumped in right after I started to get the forum back online because I thought it was super important for Polk and for our customers. I'm spending most of my time working on what I was hired to do: launching new products, and developing marketing for the brand.
    But thanks for the feedback :smile:
