power conditoners and surge protection
JimBRICK
JimBRICK Posts: 1,543
edited May 2007 in Electronics
I'm looking into something to clean the power coming to my HT. if you had 300 bucks to spend what would you be getting?
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • Willow
    Willow Posts: 11,233
    edited May 2007
    I've been very happy with my Panamax 1000+
  • venomclan
    venomclan Posts: 2,467
    edited May 2007
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    A PS Audio product...
    "God grooves with tubes."
  • read-alot
    read-alot Posts: 812
    edited May 2007
    venomclan wrote: »
    Belkin PF60
    I second that vote.
    venom, I think we bought ours at the same time but I don't remember what we paid but it was less than 300 wasn't it?
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited May 2007
    PF60, I got one, I like it. Cheap.
  • Polkitup2
    edited May 2007
    $246.45 shipped, www.chumbo.com, that's where I bought mine.
  • sickicw
    sickicw Posts: 456
    edited May 2007
    JimBRICK wrote: »
    Forget about the conditioners. Hire an electrician to install one or two 20 amp dedicated circuits.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
  • venomclan
    edited May 2007
    read-alot wrote: »
    I second that vote.
    I think I paid $225 shipped last year. I like it a lot. I saw more of an improvement than heard one. I second the recommendation of getting dedicated lines. The PF60 will only work off of a 15 amp circuit. I will get a few of those and then run everything off of it.
    I recently had a ground loop problem through my cable tv line. I ran it through the PF60 and problem solved. Right there paid its price for admission with me.
    V
  • McLoki
    McLoki Posts: 5,231
    edited May 2007
    They were running one of these at Polkfest and I was very impressed with the sound considering the amps and everything plugged into it. For the price, it seems like a very good deal.
    Michael
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    I say definitely get a dedicated outlet before you get a conditioner as well. After that, if you still want a conditioner check out the Shunyata products. You can hook up your amp and pre or AVR on 2 outlet Hydra or Guardian in your price range used.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • McLoki
    McLoki Posts: 5,231
    edited May 2007
    Has anyone used the Belkin PF60 and if so - what did you think of it? (any improvement? Did you use it with an amplifier and if so, did you notice any degridation of the sound?)
    Thanks,
    Michael
  • JimBRICK
    edited May 2007
    thanks for the ideas guys I think I have some researching to do
    2 CHANNEL
    Under construction
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2007
    What I find interesting about some of the products from Belkin, Monster, Trip Lite, etc. is that you can't upgrade the power cord to their unit. Many of them have **** 18 guage Chinese power cords. I would check out their power cords. Many units do not have remotes or 12 volt triggers.
    PS Audio units have IEC plugs so you can upgrade the power cords. The Shunyata Hydra looked like a cheap unit costing a lot of money. I posted information about a Shunyata dissection Here
    Carl
  • venomclan
    edited May 2007
    schwarcw wrote: »
    t=53180]Here[/url]
    I am not sure about the other products, but the power cord on the Belkin PF60 is a firehose. It is really thick. I cannot imagine what power cord would be an upgrade to it, as I have not seen any aftermarket cords as thick.
    V
  • venomclan
    edited May 2007
    McLoki wrote: »
    Thanks,
    Michael
    Yes, see my above posts. I use all my gear listed below + a 36" crt through it and have no problems. Video improvment was the biggest difference.
    V
  • schwarcw
    edited May 2007
    venomclan wrote: »
    V
    It's hard to tell from the pic's venomclan. The spec's show a 12 gauge wire, which is good. Many power cords form Signal, PS Audio, etc. are in the 10 gauge. I'm not saying the cord isn't any good, I'd just like manufacturer's to make upgrading the cord possible without removing the old and soldering in the new.
    The display shows a "Remote" status, does it have a remote. This thing looks like it's selling for $160!!!:eek: It could be a great buy!
    Carl
    Carl
  • schwarcw
    edited May 2007
    The PF30 is less than $90 at the Chumbo.com site:eek:
    Carl
    Carl
  • JimBRICK
    edited May 2007
    anything you say:cool:
    just dont shoot me
    2 CHANNEL
    Under construction
    SCompRacer Posts: 9,112
    edited May 2007
    Tripp Lite LCR2400
    I don't know about the others, but the LCR2400 has a fixed 12 gauge power cord and is rated at 20 amps. I have everthing plugged into it. My ESL speakers, both amps, source, pre amp, power supplies and turntable. The system can play at insane levels. I can crank the volume knob full clockwise on the pre amp with no music playing (including the 68dB gain MC phono stage) and the system is DEAD QUIET. No hum, no hiss, and no grounds lifted.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited May 2007
    schwarcw wrote: »
    Carl
    The PF30 is a decent step down from the PF60 though.
    That being said, I used to have the PF30 and liked it a lot. Then I got my DefTech towers and needed more outlets, so I got the monster.
    treitz3 Posts: 20,008
    edited May 2007
    I agree with getting a dedicated 20 amp line installed with audio grade outlets to start out with. I speak from experience. I purchased a Monster Power HTS1600 and yeilded severe degredation of sound from my PSW1000 sub and no difference other than that to audio. I also have purchased a Richard Grey Pro400 power supply/conditioner. I have tried them both daisy chained and separated and my original noise of an unwanted noise at a specific frequency still exists. So my point is......after blowing 1200 smackers to eliminate this noise caused by dirty A/C, I still need to go back to the drawing board and install a dedicated 20 amp line.
    I should have started there first. Hopefully you won't make the same mistake I did.
  • Early B.
    edited May 2007
    Do we have any electricians or contractors on the forum? What is the approximate cost of installing a dedicated 20 amp line? What benefits can be expected?
    Thanks.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2007
    Panamax, Belkin Tripplite are all good choices, I could not coment Monster. I personally like tripplite. If you are just looking to get rid of noise, Belkin makes a few good power bars with filtration inthe 50-80 dollar range, also Tripplite makes an "iso-bar that does really well.
  • schwarcw
    edited May 2007
    SCompRacer wrote: »
    Just watch out for the occasional flash!:eek: Don't touch those panels!:D
    Carl
  • McLoki
    McLoki Posts: 5,231
    edited May 2007
    schwarcw wrote: »
    For the record - that was with the Cinepro bridged.
    Also with my Cinepro I get a faint buzz from the speakers even with the ground lifted. (without the ground lifted, it is a loud buzz that cannot be ignored) At PolkFest plugged into the LCR2400 the Cinepro was cranking when bi-amped to very loud levels and with the ground engaged - was dead silent when the source was not playing (even at full volume). The difference was night and day.
    Michael
    edited May 2007
    I wish someone could have snapped a pic of that flash! Talk about turning lemons into lemonade. Roger (Sanders) said that we successfully demonstrated how durable his panel design is....:D
  • halo
    halo Posts: 5,616
    edited May 2007
    I have an APC H10 available & IIRC, it has a removable PC. If interested send me a pm.
    yup - power cord is removable but the supplied / stock cord is very thick
    I had everything connected to it but all my equipment is black (the APC is silver) so I'm no longer using it.
  • halo
    halo Posts: 5,616
    edited May 2007
    SCompRacer wrote: »
    That would've been too :cool:
    That arc went from the bottom to the top of the panel - like a backwards bolt of lightning :eek:
