Cd Player Recommendation needed
PolkFan1
PolkFan1 Posts: 130
edited March 2007 in 2 Channel Audio
I am looking for a dedicated multi disk carousel player. my budget is around 200-300 dollars. I just need it for 2 channel music with my rti8's and hk3480 receiver
Post edited by PolkFan1 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    http://www.accessories4less.com/cgi-bin/item/MARCC4300A
    Five disc, digital outputs (try some d/a converters down the road), headphone output with volume control (for late night listening).....
    They are also selling the same model, refurb for $129.
    Solid player.
  • cmy330go
    cmy330go Posts: 2,341
    edited March 2007
    ^Same one I was going to recommend.^
    Great machine for the $$$.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • shack
    shack Posts: 11,154
    edited March 2007
    I normally don't do this, but I am going to recommend something above your price range. That and the fact it is not a dedicated CDP changer.
    http://www.northamptonaudio.com/nad/T572.asp
    A NAD T572 DVD Changer. NAD is a company that puts as much thought into the audio section of it's DVD players as it does the video. I have one of these and use ist strictly for audio. I've never even played a DVD with it. The Marantz is solid...this NAD is much better. If you are going with the $129 refurb Marantz....maybe this would not be worth it to you. I have heard both. Personally, I would spend the extra coin.
  • RuSsMaN
    edited March 2007
    Good point Shack.
    Interesting how I've yet to find a one sided coin, you know?
    Cheers,
    Russ
    *I have an NAD T-550 (single dvd) in my HT rig, and it's been bullet proof reliable for over 2 years - and it sounds wonderful to boot*
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    No SACD for that amount of coin:(
    Ben
  • RuSsMaN
    edited March 2007
    No, soon to be dead formats aren't supported. ;)
  • cmy330go
    edited March 2007
    OUCH!!!:D
    HT
    2 CH
  • shack
    shack Posts: 11,154
    edited March 2007
    $400 :confused: Cheap for a quality CDP.
    The Sony SCD CE595 is a well regarded budget SACD changer that can be had for less than $150. The SCD C2000ES is the step up ES version of the 595 for under $300. They are very good SACD changers (especially on a budget). The NAD I mentioned is a better redbook player than either one. If you want a SACD/CD only changer these are your only options new, unless you want to go with some of the older SCD C222ES, SCD C333ES, SCD C555ES...None of which have been built in the last 4 years.
    Yamaha makes the DVD-C750 and DVD-C950 multiformat (including SACD) changers, but I've never heard them.
  • ben62670
    edited March 2007
    NO NO NO NO I'm not listening LA LA LA LA **fingers in ears**
    Ben
  • ben62670
    edited March 2007
    I have this one and the sound is very very good. Not grainy, and dynamic. I paid $200 as a floor model :)
    Ben
  • shack
    shack Posts: 11,154
    edited March 2007
    Which one :confused: I mentioned 7 different players in that post.
  • halo
    halo Posts: 5,616
    edited March 2007
    My thoughts exactly ;):D
  • ben62670
    edited March 2007
    Ben
  • TroyD
    TroyD Posts: 13,124
    edited March 2007
    Me? I'd look at a Sony SCD-222ES/SCD-575 (?) and have it modded by Matt at sacdmods.com.
    Reasonable AND outstanding performance.
    BDT
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2007
    A Sony changer would be a great idea if you don't want to spend a ton. Sony's have always been solid, even their less than a 150 bones players. between 1997-2001, I ran a $129 Sony CD changer in my main system, it was a great player. I garage saled it for $85.
  • shack
    shack Posts: 11,154
    edited March 2007
    BDT
    I have no problem with this recommedation as well. The modded CE775 I bought from you is outstanding. However, If we are still talking about PolkFan1, he would be looking to spend his budget just to find a good used C222ES (slightly less for a CE775), and that's before the $400± in mods.
    Ben brought up the SACD, and if PolkFan1 isn't interested in SACD, the Marantz Russ mentioned, the NAD DVD player, the Sony SCD-C2000ES or maybe the Denon DCM-390 would all be good options as he could find them new or reconditioned.
    IF he could find a Sony SCD-C222ES in good condition, it is a very good redbook changer even if he never plays a SACD disc. But as I stated they haven't been made in quite some time and finding a decent one might be tough.
  • strider
    strider Posts: 2,568
    edited March 2007
    Another option for you in the FM
    http://www.polkaudio.com/forums/showthread.php?t=49872
    And I'll give another nod to the above mentioned Sony changers. I've had a 555ES for a few years and really like it.
    Wristwatch--->Crisco
  • Chicomoralessxm
    Chicomoralessxm Posts: 417
    edited March 2007
    Just a crazy idea but what about the denon??? dcm 390??? personally id say save some money and get the rotel or check out the marantz for a little less
    Chicomorales:)
  • dragon1952
    dragon1952 Posts: 4,907
    edited March 2007
    Get a good single disc player and get off your butt to change it :rolleyes: Jeez, when I was your age I had to get up and walk a whole 20 ft across the cold floor in just my sock feet just to change the TV channel :cool:
  • shack
    shack Posts: 11,154
    edited March 2007
    Ignore Dragon and get a changer if that is what you want. ;) I bet he had to make extra trips back and forth on that cold icy floor to adjust the rabbit ears as well.
    I currently own 3 changers and my single disc players are pretty much just gathering dust since I rarely use them. There is nothing better than picking out 4 or 5 CDs and loading up the machine for an evening of listening.
  • PolkFan1
    PolkFan1 Posts: 130
    edited March 2007
    Anyone have any info on the denon dcm 390?
    treitz3 Posts: 19,992
    edited March 2007
    No, I don't, but you might want to get off the internet for a while and go visit your local Circuit City, Best Buy, or Tweeter and see if they have any discontinued models of CDP's or Universals.
    I was able to pick up a Denon DVD-2910, which is a universal player for $202.00, including tax, just because it was a discontinued unit. Didn't affect the sound, so I don't care. Saved around seven hundred bucks though!:D
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited March 2007
    I looked at that 2910 before I bought the Marantz DV-8300. I got the Marantz for a killer price, so I took that instead. The Denon is a great player. I haven't found anything under $2000 so far that outdoes my Marantz. I had a few friends bring over a Pioneer DV-09, a Marantz 9000 series, and another Elite, the 79. My Marantz had an easier setup than all of them, and the picture quality was better, at least in my eyes. Couldn't be happier.
  • Chicomoralessxm
    edited March 2007
    hey polkfest where r u located??? if you are or near chicago check out a store call saturdayaudio or any dealor near you and go and do some listening with some material you know. i wish I had that luxury locally!!!!
    Chicomorales:)
  • dragon1952
    edited March 2007
    As a matter of fact I did :p ..... and we were lucky to get 3 channels, that you could barely see because of the interference BTW.....didn't have a color TV until I was 17.....and we had LP's that you actually had to flip over to listen to the other side :eek:
  • Deadof_knight
    Deadof_knight Posts: 980
    edited March 2007
    Buy a single disc Rega planet, !!!!!!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Bill Ayotte
    edited March 2007
    Someday............
  • shack
    shack Posts: 11,154
    edited March 2007
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2007
    anyone with takes on the denon 390 or the sony 2000es cdp. Which would be the better cdp running through 7100es? PLease advise
  • halo
    halo Posts: 5,616
    edited March 2007
    I've heard that the Denon changers were not so great. Between the two I'd go for the ES.
