anybody know nething about onkyo
98thumpin
im considering all polk speakers monitor 70's and centers channels and bookshelfs and a velodyne subwoofer,
is this a good reciever to buy:Onkyo 7.1 Channel Home A/V Receiver (TXSR804)
ONK TXSR804
7.1-channel surround
105 watts per channel
XM Radio®-ready
THX Select2 Certified
High-def connections
iPod compatible
Power
Power per channel ?
105 watts
Surround power ?
105 x 7
Bandwidth @ rated power ?
20Hz - 20kHz
Frequency response ?
5Hz - 100kHz
THD @ rated power ?
0.08%
Inputs and outputs
Surround sound ?
Yes
S-video inputs ?
5
# of component video inputs ?
3
Phono input
Yes
# of digital optical inputs
5
# of digital coaxial inputs ?
2
Multi-channel input
7.1
HDMI
Yes
General features
# DSP modes
1
Satellite Radio-Ready
Yes
iPod compatible
Info unavailable
On-screen menu display
Info unavailable
Remote control type
Included
A+B speaker switching
Info unavailable
Multi-room capability
Info unavailable
Surround channels
7.1
Video switching
Info unavailable
Warranty Parts
24 Months
Warranty Labor
24 Months
ONK TXSR804
XM Radio®-ready
iPod compatible
Power
Power per channel ?
105 watts
Surround power ?
105 x 7
20Hz - 20kHz
5Hz - 100kHz
THD @ rated power ?
0.08%
Inputs and outputs
Surround sound ?
Yes
S-video inputs ?
5
3
Phono input
Yes
5
2
Multi-channel input
7.1
HDMI
Yes
General features
# DSP modes
1
Yes
iPod compatible
Info unavailable
Info unavailable
Remote control type
Included
Info unavailable
Info unavailable
Surround channels
7.1
Video switching
Info unavailable
Warranty Parts
24 Months
Warranty Labor
24 Months
John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Post edited by 98thumpin on
Yes, a nice start and wouldn't make a bad pre amp / processor if you wish in the future, if it has pre amp outputs which I think it does.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
There's an Onkyo 7.1 Channel Home A/V Receiver (TXSR804) running a mixed set of Polk/JBL speakers in the entertainment center at my second job, and it
coasts along quite nicely.
It does have pre-outs, which opens things up for you in the future if you choose the seperates route.
Here's a link for Onkyo's site that offers refurbished units. They don't have any refurbed TXSR804's, but keep an eye on it if that's the route you take:
http://www.shoponkyo.com/products.cfm?group_id=1&subcat=Receiver
For the listed MSRP of $999, though, others may have some suggestions on different manufacturers to look at.
Don't be in a hurry; new stuff is coming.Sal Palooza -
I see Crutchfield had it listed for $699 didn't sound to bad to me for that price.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
please explain to me the concept of using it as a preamp i mean isnt it an amp and preamp allready, and also can u make a suggestion on a amp to use with it?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
ok here goes.
a receiver.. or AVR as they are now called because they include video switching
a receiver has everything all in one unit.
it has a AM/FM tuner, a pre amp and an amp all in one unit. there are hundreds of brands of receivers on the market. all price ranges from about $80 on up to several thousand dollars.
a pre amp is just a one piece that lets you select what you want to listen to.. ie: tuner, CD's, turntable, tape deck, etc. that's all it does.. it does not amplify the signal and you can not hook up speakers to it.
a integrated amp is a pre amp AND an amp in one unit. it's like the pre amp above, PLUS is has built in amps.. so you CAN hook up speakers to an integrated amp.
finally, a power amp.. this can be mono, which is one channel only. Stereo which is two channels, tri amp.. 3 channels, 4 channel amp, 5, and 7 channel amp.
finally you have a stand alone AM/FM tuner. all it does it bring in radio stations. a stand alone tuner in most cases will be better than the tuner built into your recevier.
that should just about cover it..
*side note.. some stand alone pre amps. have tuners in them as well. I forgot that.
AND yes you can use a receiver as a pre amp IF it has pre outputs on the back of it. if not. you can not. periodPolkFest 2012, who's going>?
well put if i use it as a preamp what kind of amp should i use with it ill be driving two polk monitor 70s for my front left and right plus a polk monitor 40 bookshelfs for the rear and a Polk Monitor Series Center Channel Speaker (CS2CH)
and for the sub im going with aVelodyne 12" Subwoofer (DPS-12)John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
you have two options for amps.. get a 5 channel amp. say an Adcom or other brand to drive all your speakers.. OR get only a two channel amp of your choice like Adcom for only your front speakers.. then have your recevier power the center and rears. 5 channel amps are pricey.. well to me they are pricey. LOLPolkFest 2012, who's going>?
I have an Onkyo TXSR702 and like it. Like mine, the TXSR804 has a 5 band (3 on subwoofer) digital equalizer on each channel. Fun stuff, if you are in to it (autoset or none, if you are not).Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
Dude, its just like in car audio.
A receiver is like a head unit as in its a horrible power source. Itll work if all youre wanting is some tunes or you live in an apartment or something but in order to get the best sound out of your speakers, you need more power and that means a dedicated amp.
thanks mac and congrats on your new win awhile back good job. and ok now these are the specs on the monitor 70"s
Electrical
Overall Frequency Response 30Hz - 25kHz
Lower -3dB Limit 40Hz
Upper -3dB Limit 24kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20 - 275 w/channel
Efficiency 90 dB
Crossover 2.6kHz and 2.6kHz cascade tapered 2nd order
Inputs Dual (bi-amp) 5 way binding posts
what 2 channel amp wpuld be good to power these i love loud music, and i want to get the best sound out of these speakers i canJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Im a little out of my element on this but I have been seriously considering doing away with a 5.1 system once we get a house and instead spend all the money on a set of really good stereo speakers and then get a very stout amp to push them and thie Rotel is what I was looking at.
Rotel aint the most expensive or exotic brand in the HA market but from what I can tell thru reading and talking to people is that theyre still a good quality brand that makes solid products for a decent price.
This 200x2 amp is the one I was most considering along with a pair of RTi10's.
http://rotel.com/products/specs/rb1080.htmpolkaudio sound quality competitor since 2005
now mac do you know what the price is on that amp its a great looking amp, i looked at adcom but the 200 watt amp is massive, do you know if yamaha, or polk makes an amp good enough to power those monitor 70's? and anyone can answer this for me.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
nething or anything, hmmmmmmm, saving one letter, makes you a frugal sort I would say.
mac at least it has 200 wpc!!!! get some good wires.
RT1 -
Already got em picked out!!
Radio Shack, here I come!!
Just buy what you can afford look forward for the future for any upgrade you would like. What you asked about is FINE go with it, if you can afford something better now add an amp used or look about cables IMHO.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Nope-I know nothing.
MacLeod wrote:Already got em picked out!!
waaaaaaaaaaaaaaaaaaa..............I love CP humour.
RT1 -
That's understandable seeing how you think all the preamp does is switch sources.
98thumpin wrote:now mac do you know what the price is on that amp its a great looking amp, i looked at adcom but the 200 watt amp is massive, do you know if yamaha, or polk makes an amp good enough to power those monitor 70's? and anyone can answer this for me.
does ne one know of a good power amp to power these speakers with, monitor 70's what wattage do i need.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
all i want to know is what a good amp for the monitor 70 speakers would be and what wattage i should consider getting?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
If you got the Coin anything about 125w X 2 is a good place to start. But again what you stated is fine, if coin is a problem this hobby is not cheap so why are we scaring people away?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Read the manual. It will tell ya how much power you should be using. Then go out and find the best quality amp that you can afford that comes closest to matching those power ratings. Nuttin' to it.polkaudio sound quality competitor since 2005
ill start looking there in the 125watt range its just hard finding nething sometimes, know of ne brands that make a good 125 or 200watt amp that isnt over around 500 dollers maxJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Recommended Amplifier Power 20 - 275 w/channel this is what the speakers are rated atJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
what would a good amp beJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Audiogon.com is your friend look around see something in your price range post the link here to hear our option if you wish.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
ok sounds goodJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
another strange question; the reciever has a mic in jack on the front of it what is this for?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
98thumpin wrote:another strange question; the reciever has a mic in jack on the front of it what is this for?
a mic
to set up your speakers automatically using tones the receiver generates.PolkFest 2012, who's going>?
