Speaker Break-in Poll
rskarvan
rskarvan Posts: 2,374
edited November 2006 in The Clubhouse
Ok... here is a poll.
Do you think speaker break-in is mostly a myth and that, in fact, it is your ears/brain/memory/perception changing over the first 200 hours... or, is the majority of the change strictly a function of the speaker changing its acoustic output properties.
Please respond. Thank you.
Post edited by rskarvan on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    well when I got my sda's, they were already broke in. The only times I have heard changes was with placement, new speaker wire, interconnects, and the addition of an amp,the removal of my avr, and cheaning up the clutter around the speakers.
  • dudeinaroom
    oh and I have noticed differences over time with new speakers.
  • TheReaper
    TheReaper Posts: 636
    3) - new speakers break in quickly (within an hour or two), everything after that is deterioration.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • danger boy
    danger boy Posts: 15,722
    cars break down over time.. but speakers break in over time? :confused: I didn't vote, because i don't really know for sure.
    PolkFest 2012, who's going>?
  • PolkWannabie
    PolkWannabie Posts: 2,763
    an in between answer like ... break in is a good thing but don't expect DRAMATIC change ... might be an appropriate alternative ...
  • pearsall001
    pearsall001 Posts: 5,094
    Yep, the sound does change. I don't think it takes too long though. Once the woofers get some air moving thru them & the foam surrounds loosen up then it's home sweet home. I noticed a difference with the bass. I think it only took a few hours & everything settled in.
  • seo
    seo Posts: 305
    Didn't vote, because I don't know.
    It would seem the mechanical moving parts will change over time, but the question is if it is perceptible.
    Signature goes here
  • pearsall001
    Yes, it was without a doubt quite noticable. The difference I heard in the bass presentation was quite an ear opener. It settled down from being on the boomy side to tight & articulate. As far as the mids & highs I really don't think there was much change in sonic characteristics.
  • petrym
    petrym Posts: 1,912
    I bought some Atrium 45's and when I first hooked them up I was in shock... they sounded wooden and hollow. After 45 minutes they started to loosen up and after 2 hours sounded like the Polks I expected -- but that was a scary first hour!
  • Joey_V
    Joey_V Posts: 8,586
    You need a third option...
    3. Break in is physically possible, but I have not heard it yet.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    rskarvan wrote:
    No, speakers dramatically change their acoustic properties in the first 200 hours of operation.
    The change is not always dramatic. Sometimes it is subtle, but noticeable.
  • MacLeod
    MacLeod Posts: 14,358
    I actually think speakers do benefit from breaking in. I also believe they sound different when they warm up.
    Speakers are a mechanical device just like a motor. And a cars motor needs to break in and it runs differently once its warmed up.
    However I dont think the change is dramatic. I doubt the casual listener would even notice. Hell I dont notice the warming up effect unless Im tuning to my SQ disc and am paying special attention to imaging cues and the like.
  • hearingimpared
    hearingimpared Posts: 21,136
    Speakers are electro-mechanical devices so they do need a warm up period. I don't know how dramatic the sound change is after warm up but I always play some soft music for a little while before blasting.
    I think burn-in with electronic gear is necessary not so much to improve the sound but all electronics have an infancy mortality rate when first powered up and then the mortality rate levels off. After so much time (years) the mortality rate increases again.
  • unc2701
    unc2701 Posts: 3,587
    Having blown a driver & replaced it with a new one, I can say speaker break in does exist. I could definitely hear it at first, then after a day or two the difference was gone. Just to satisfy my curiosity, i had my roommate listen, too, with out knowing why & they could tell a difference as well.
    Backburner:Krell KAV-300i
  • cmy330go
    cmy330go Posts: 2,341
    I wouldn't say that it takes 200 hours, but I have certainly heard the effects of speakers break-in myself. I think I noticed it most with a pair of RTi6's that I owned for a short while. Everytime I hook up a brand new set of speakers I start them playing and walk away for at least 10 to 20 hours. When I first connected the 6's the sounded very thin and overly bright. About a day later when I finally sat down to listen to them they had a much different sound. Bass was much more pronounced and the top end had warmed up slightly.
    I've had very similar experience with a pair of RTi4's and a pair of Energy RC-10's.
    Later!
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Demiurge
    Demiurge Posts: 10,874
    It's definitely not a myth. It's like a pair of pants. They feel better after a few washes. This is no different. Material gets more range, etc.
  • Joey_V
    Joey_V Posts: 8,586
    Later!
    That's exactly what I thought when I had the Axiom M22ti bookshelves... at first, they sounded thin and harsh, then with a few months use, I thought they got a lot better and a lot less harsh.
    Little did I know that when I got the replacement pair (brand new), the 2 pairs sounded exactly the same.
    I think it's mostly us adjusting to the sound. Break in may exist, and I've seen the studies they do with regards to warming up the drivers and what not, and they do show that break in exists... but it's usually very quick and very fast as the motor/magnet warms up from the cold (so to speak).
    Break in may exist, but in my opinion, it's probably not as much as most of us claim it to be.
    Manufacturers love to claim that break in exists because it gives them an excuse to have the owner keep the speaker for longer than they would otherwise. What? There's a 30 day return policy at Tweeter? Oh, we'll just make sure to add that it takes 100 hours to break in the speaker so by the time it "breaks in", the owner has no choice but to keep the speaker considering it probably went over the 30 days since purchase.
    Just my 2 cents.
    Break in may exist, but I think we give it more credit that it deserves. Constant room/speaker position tweaking, our brains, our ears probably have more to do with it, IMO.
    Joey
  • janmike
    janmike Posts: 6,146
    Some more than others. I found the LSi9's really opened up after about 100+ hours.
    Michael ;)
    NORTH of 60°
    F1nut Posts: 50,828
    I'm sorry, but that doesn't make sense. You can put 100 hours on in about 4 days. That leaves, on average, 26 days for demo time.
  • Joey_V
    Joey_V Posts: 8,586
    Jesse,
    I understand. But my point is that the normal person would probably not leave it on the entire day to break in, but instead go about the normal routine of playing music/movies for 2-3 hours a day and by the 30th day, barely even hit the 100hr mark.
    Besides, my comment of 100hours isnt even meant to be taken literally, it's just an example.
    I have read manufacturers claim on their instruction manual that the speaker sounds better after 200, 500, or 1000 hours. I just chose 100 for the sake of just choosing it. Whether or not someone can techinically "break in" the speaker in 4 or 5 days is irrelevant. My point was that the "break-in idea" can help out manufacturers by using the tangible idea of "break-in" to promote ownership by giving the customer something tangible to look forward to in case they dont like the sound upon opening the box.
    Joey
    F1nut Posts: 50,828
    Ok, I get where you're going.
    On the other hand the average person wouldn't know good sound if it bit them in the **** no matter how many hours a pair of speakers have on them.
  • Joey_V
    Joey_V Posts: 8,586
    Good point, Jesse.
  • MSALLA
    MSALLA Posts: 1,602
    Just look at the poll results. That pretty much says it all. Keep in mind, if someone only listens to music say 2 hours a day, 50 hours of break-in would take 25 days. Over such a long time they may not notice the change and may be the reason they don't buy into it.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Refefer
    Refefer Posts: 1,280
    Here are some tests done by audioholics, testing this exact questions with quantitative results.
    An interesting read: http://www.audioholics.com/techtips/audioprinciples/loudspeakers/SpeakerBreakIn.php
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • Joey_V
    Joey_V Posts: 8,586
    Like I said, many studies support the idea of break-in, but only in the initial sense. Driver compliance returns to pre-break in within a few seconds or minutes of turning the speaker off.
    Joey
  • cfrizz
    cfrizz Posts: 13,415
    Interesting article. So for the most part we are imagining that we hear changes in our speakers.
    So as I've always said, stop worrying about incidentals & just enjoy the music.
    If it sounds bad at the start, it will still sound bad after the supposed break in period. In which case find yourself a new pair of speakers that sound good from the get go.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Ms Frizz never met an exclamation point she didn't like:p
  • cfrizz
    Ooops. Is that better ZB?
  • zombie boy 2000
    Ha ha ha:D Nice edit
    I just think you're passionate about your hobby:p
  • rskarvan
    "Four years after the system had been installed in the theater, I had the opportunity to go back and take some measurements. I availed myself of the opportunity and found that the amplitude response plots made that day matched to within a fraction of a dB those made when the system was first installed. Four year’s worth of “breaking in” hadn’t affected the system to any significant degree."
    Conclusion... Breaking-in is a myth.
