Yamaha R1100-U Receiver help request
John in Canada
Hi everyone, I have a Yamaha R1100-U receiver ( about 10-15 years old ).
It powers up with all lites on front panel, but NO audio out -- just a regular popping or clicking through the speakers - about three clicks per second.
Any ideas? Does anyone know where I can download a PDF Technical or Service Manual?
Thanx. John in Canada
Post edited by John in Canada on
First thing that comes to my mind is failure of the relay that prevents the initial power-on pop/surge from going to the speakers. A friend who experienced such a failure simply put a jumper wire around the relay. Not a proper fix, but it did get the receiver going again. (And a something you could try to see it this is the problem.)
Cheers, JimA day without music is like a day without food. -
Jim Shearer wrote:First thing that comes to my mind is failure of the relay that prevents the initial power-on pop/surge from going to the speakers. A friend who experienced such a failure simply put a jumper wire around the relay. Not a proper fix, but it did get the receiver going again. (And a something you could try to see it this is the problem.)
Cheers, Jim
Thanx very much, Jim. This sounds like it is an easy fix, if I can locate the relay. It might be tougher to actually find the replacement relay. Do you or anyone you know if there is a PDF version of the Yamaha RX1100-U receiver Technical/Service Manual with physical parts placement diagrams and part #'s and schematic? John in Canada -
John,
I don't know about finding manuals on-line, but it occurs to me that you could try to find that type of part on-line. Hopefully it would be accompanied by a picture, Then open up the box & look for something similar on the board. Otherwise, I'd just try to trace out the wiring & see what I could find.
Good Luck!
John in Canada wrote:Thanx very much, Jim. This sounds like it is an easy fix, if I can locate the relay. It might be tougher to actually find the replacement relay. Do you or anyone you know if there is a PDF version of the Yamaha RX1100-U receiver Technical/Service Manual with physical parts placement diagrams and part #'s and schematic? John in Canada
www.stereomanuals.com
www.vintagemanuals.comCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
