Tube Amp or Solid State
jhermance
jhermance Posts: 214
edited August 2006 in Electronics
Ok starting this over for a set of bookshelf speakers which would be better. for something along the lines of Lsi9's.
Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza™ Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects
Post edited by jhermance on
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2006
    Raise shields Mr. Sulu.
  • jhermance
    edited August 2006
    Ok did i say something wrong in that post. Just looking for help. Trying to understand the difference between the 2 types of amps.
    Samsung UN46C7000
    Sony BDP-S570
    Magnepan MMG's
    Polk R15 Surrounds
    Audioquest Cables
  • Ern Dog
    Ern Dog Posts: 2,237
    edited August 2006
    Let the battle begin... this should be fun and hopefully educating to watch!
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    why is it a big deal to ask this question? Simple, solid state amps to power these type speakers.. to get a tube amp to properly power those speakers is gonna cost you alot.
    if you want to dabble in tubes.. get a tube pre and/or cdp
    common amps to think about is Parasound, Nad, adcom.. to name a few..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • DarqueKnight
    edited August 2006
    jhermance wrote:
    Ok did i say something wrong in that post. Just looking for help. Trying to understand the quality difference between the 2 types of amps.
    No, you didn't say anything wrong. The tube amp vs. solid state amp is a huge topic of debate in audio. There are tons of info on the web and lots of enthusiasts of both persuasions here on the forum. I like them both, for different reasons and musical applications.
    Set aside a couple of weeks for reading and then Google "tube amp vs. solid state amp". Enjoy.
  • jhermance
    edited August 2006
    Ok thanks. any suggestions for a tube cdp within a reasonable price range around $500 if possible.
    Samsung UN46C7000
    Sony BDP-S570
    Magnepan MMG's
    Polk R15 Surrounds
    Audioquest Cables
  • Early B.
    Early B. Posts: 7,900
    edited August 2006
    Faster is right. No fight here if you're gonna use Lsi9's. The only thing I'll add is that if you plan to play those speakers only at low to moderate levels, then consider a tube amp or tube int. amp. Otherwise, go SS for your amp.
    "God grooves with tubes."
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    Solid State.
  • halo
    halo Posts: 5,616
    edited August 2006
    Not true. I have two different tube amps that will drive LSi's with ease.
  • halo
    halo Posts: 5,616
    edited August 2006
    Under $1300 new each.
  • halo
    halo Posts: 5,616
    edited August 2006
    Sheng Ya CD-S10 or Kavent CD-731.
  • jhermance
    edited August 2006
    I will keep my eye's open for a used one.
    Samsung UN46C7000
    Sony BDP-S570
    Magnepan MMG's
    Polk R15 Surrounds
    Audioquest Cables
  • ohskigod
    ohskigod Posts: 6,505
    edited August 2006
    keep the Jolida JD100 on the list for tubed cd players, I love mine, and its possible to score one for 500 used if you look hard enough.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ohskigod
    edited August 2006
    eeeesh, thats a tough question to answer definitivly. for music I lean toward tube amplification, but for movies, and when I like to shake my house with music or movies, I go with solid state. Luckily I have access to both.
    ss in the theater, tubes in the 2 channel.
    ultimatly, your going to have to experience both and develope your own opinion. start saving the sheckles :p
  • dorokusai
    edited August 2006
    I've run a set of LSi7's on a couple 20wpc tube amps...for less than <$400.
  • faster100
    edited August 2006
    well the difference between listening to lsi's on small tubes and getting the most of is subjective..
    I used my 5 watt sonic impact on a set of sda 1B's and they sounded good, optimal ? NO
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • dorokusai
    edited August 2006
    It was near-field and it was plenty, sorry you're gear didn't cut it.
  • jhermance
    edited August 2006
    I have looked into these amps any thoughts on them
    Mcintosh mc7100
    Rotel 1080, 1075
    outlaw audio 220m
    any other's i should look into?
    Samsung UN46C7000
    Sony BDP-S570
    Magnepan MMG's
    Polk R15 Surrounds
    Audioquest Cables
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    Parasound Halo or Classic.
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2006
    I powered my Lsi9's with a 50WPC tube amp and it sounded fantastic.
  • faster100
    edited August 2006
    True mark, if you have **** Gear like me.. don't try tubes on lsi's.. :rolleyes:
    If ya want it loud, and your rigs not in a crawl space.. Get SS
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • ESavinon
    ESavinon Posts: 3,067
    edited August 2006
    Get both. biamp the lsi's. tube for tweeters,ss for woofers. that way you can retain the warm sound of tubes and still get the dynamic slam of ss.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • Emlyn
    Emlyn Posts: 4,708
    edited August 2006
    Mcintosh mc7100
    Rotel 1080, 1075
    outlaw audio 220m
    Parasound Halo A21 or A23. Probably wouldn't notice much of any difference between the two amps with the LSi9's. Used A21's are usually around somewhere for $1200 or less, but I think it's an overkill amp for the speakers.
  • jhermance
    edited August 2006
    Are sophia electric baby amps any good?
    Samsung UN46C7000
    Sony BDP-S570
    Magnepan MMG's
    Polk R15 Surrounds
    Audioquest Cables
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2006
    Not for the LSi line. Tube amps in the 50-100 watt range will be nice with the LSi 7. The 9s deserve even more.
    Personally, I like tube preamps with solid state amp for most Polks. You can crank until the wife or neighbors complain then.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2006
    6 months or so ago....
    Neighbors never complain yet, my wife has left the house.... I then crank until a blow something up (Polk Crossover) lessen learned a tad lower from now on :rolleyes:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • venomclan
    venomclan Posts: 2,467
    edited August 2006
    Mcintosh mc7100
    Rotel 1080, 1075
    outlaw audio 220m
    Based on your other post, I assume you will be using the bookshelves for 2 channel. If so, the Rotel would probably be your best price-performance ratio of those 3. I have the Outlaw, very good for theater use but too neutral(sterile) for music imho. The Mac would be heads and shoulders above everything else, but at those prices I would get better speakers in the first place. The Rotel would work well and they can be had used at Agon or Ebay affordably.
    Venom
  • jhermance
    edited August 2006
    actualy i have found the mcintosh mc7100 for less than the rotel 1080
    Samsung UN46C7000
    Sony BDP-S570
    Magnepan MMG's
    Polk R15 Surrounds
    Audioquest Cables
    F1nut Posts: 51,771
    edited August 2006
    Take a serious look at amps from Conrad-Johnson, BAT and Classe. They all make very nice gear.
  • madmax
    madmax Posts: 12,434
    edited August 2006
    The LSi's need lots of SS power. I tried my LSi9's and 7's with a 50 wpc tube amp and wasn't very impressed. Even though my typical play level is much less than many here I was totally unsatisfied with the output level. The LSi's really respond nicely to megawatt power.
    madmax
    Vinyl, the final frontier...
