Lets give the young ones some advice...
steveinaz
steveinaz Posts: 19,537
edited August 2006 in 2 Channel Audio
For the benefit of those members who are young, and/or don't have deep pockets, put together the best system you can at/below $1500 (including cables). Use globally accepted new equipment street prices, OR realistic used prices. Let's see what you can scrape together...
Post edited by steveinaz on
  • ohskigod
    ohskigod Posts: 6,502
    edited July 2006
    tight budget?
    Toshiba 3960 CD player (do they still make it?) under 100 new
    Sonic Impact T amp (35-40 bucks shipped)
    rca to single mini jack to hook up cd to sonic impact (10 bucks, radio shack)
    Speakers (anything 89-90 db efficient and up, say Polk RT55) no more than 200 used
    total - 350 ish
    Add a tube pre into the mix to warm up the sound if you need it
    Dodd ELP used, with amperex bugleboys 400 ish ( I did this with good results)
    total 750 ish
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • ohskigod
    edited July 2006
    or with a little more to play with
    the system I helped put together for fireman32 would fit this category
    Radii mmp-01 tube pre <300 used
    Radii mpp-m8 tube amp <350 used
    Toshiba 3960 DVD plr <100 new/used
    good quality interconnects, 2pr, from the usual suspects like Signal Cable (or quality used. 150 ish MAX
    Polk RTA-12B speaks (used) <250 depending on condition
    speaker wire, I wouldnt go nuts here either figure 50 bucks ish
    total 1200.00 fair used price TOPS (Fireman didnt pay that :p)
    in his small livingroom, and after 20 minutes of warm up, this system sounds friggin sweet. far better than I anticipated. beef up the source with any extra money in the budget.
  • unc2701
    unc2701 Posts: 3,587
    edited July 2006
    Used prices everywhere:
    Musical Fidelity x-150 integrated: $650 (has phono stage)
    Pro-ject Debut III turntable w/ Ortofon cart: $200
    Polk Lsi 9's: $550
    Signal Cable IC's and speaker cables: $100
    Backburner:Krell KAV-300i
  • steveinaz
    edited July 2006
    Awesome. Good job.
    Keep them coming...
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited July 2006
    Nad 320BEE integrated -- $400
    Totem Acoustic Rainmaker -- $900
    Panasonic DVDS52S dvd player -- $90:o
    Signal Cable speaker cable -- $70
    Signal Cable Analog One IC's -- $36
    = $1496
    :) All spankin' New!!!
  • Fireman32
    Fireman32 Posts: 4,845
    edited July 2006
    Thanks Lou im very happy with my system. Sounds great and to think i wanted to do surrond sound.
  • jderdock
    jderdock Posts: 131
    edited July 2006
    how about a good integrated to match LSi15's?
    My C320BEE surely isn't enough
    Rega P3 > Parasound Zphono > NAD C320BEE > Polk LSi 15
  • unc2701
    edited July 2006
    Krell kav-300i can be had for $1000 & up, used... Same thing on the Musical Fidelity A3.5. I've been running that Krell for a week or two on my LSi25's and have no complaints at all. Well, the speaker posts suck, but I'll probably replace them anyhow. Both have a HT pass-thru so you can use the power section w/ your processor/AVR, but have your music sources use both the pre- and power sections of them.
  • jderdock
    jderdock Posts: 131
    edited July 2006
    How about compared to your Bryston and Adcom?
  • zombie boy 2000
    edited July 2006
    Looks like the party's spilled over to this room:D
  • organ
    organ Posts: 4,969
    edited July 2006
    Depending on the speakers being used, a Sonic Impact T amp can be all they need.
  • unc2701
    edited July 2006
    Kinda going off topic here... I'll PM you.
  • ohskigod
    edited July 2006
    another friend of mine is using my Sonic Impact amp with a pair of Pioneer CS-88a's. I like those speakers a little more than I care to admit. weak in the bass dept, but i think placement was an issue. he had them placed like a friggin f-tard!
    He got the speaks for free, so if he buys his own sonic impact, he can buy a cheap source and cables and be in a good place for well less than 200.00.
  • jderdock
    jderdock Posts: 131
    edited July 2006
    Not if you're a "young one" looking for system advice with regards to Polk speakers.
  • Joey_V
    Joey_V Posts: 8,592
    edited July 2006
    $1500?
    Hmm... I'll get back to you on that...
  • organ
    organ Posts: 4,969
    edited July 2006
    Cool. And you can skip the pre amp as well with the SI. Teac also have a cheap T amp that was talked about quite a bit.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited July 2006
    Great thread!!!
    Here's what I have so far, and $1500-$2000 is probably a realistic max for building my 2-channel system (help me fill in the blanks):
    B&K ST202 - $330
    B&K Pro10MC - $150
    IC's - $50 for 2 sets AQ Sidewinder
    Source - $400 Pioneer 59avi Universal player
    Speaker wires - ???
    Speakers - ???
    Stand - ???
    So right now I have $930 sunk cost with $570-$1070 for speaks, wires, and system stand.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • jderdock
    jderdock Posts: 131
    edited July 2006
    AndyGwis wrote:
    Speaker wires - ???
    I like the Canare 4S11 star quad stuff just fine.
    http://www.bluejeanscable.com/store/speaker/index.htm
    I think I ordered it from somewhere else, but Blue Jeans has a good reputation for builds. I put some techflex on mine, just to pretty it up a bit.
  • madmax
    madmax Posts: 12,434
    edited July 2006
    ohskigod wrote:
    tight budget?
    My thoughts exactly. I've seen 3960's on sale for $29, SI for $21 which could bring your total down to around $260. Do a DIY speaker with partsexpress drivers and you might even bring it down another $100. Imagine that, a decent sounding system for under $175. This hobby doesn't have to be expensive to be enjoyable. Add a $50 TV and watch some movies!
    Vinyl, the final frontier...
  • Ricardo
    Ricardo Posts: 10,636
    edited July 2006
    Cambridge Audio CD player; many models available $250 used
    Tube pre several options: $400 used
    Used Polk Monitor 10's or small SDA (1A, 1B, 2, etc) $300 used (a lot less for the Monitors...)
    200WPC Amp (Adcom, Carver, etc) $300 used
    Interconnects, Speaker Wire: $200 new
    Total: $1450
    SOPA
  • unc2701
    edited July 2006
    What interesting here (to me anyway) is the wide range we're seeing in speaker:pre/power. Mine is basically 1:1, but we've got a 2:1 and some 1:2's...
    You gonna throw one out there, Steve?
  • steveinaz
    edited July 2006
    Paradigm Studio 40's....$650 used
    Cambridge Audio D500SE...$289 (used, and sometimes new)
    Parasound PHP-850 preamp...$125 used
    Parasound HCA-1000 amp...$325 used
    Kimber 4pr speaker wire...$45 used
    Kimber PBJ 1mtr...$60 used
    = $1494.00
  • steveinaz
    edited July 2006
    here's one straight retail all new:
    Creek A50i Integrated...$699 (Audio advisor, right now!)
    Cam Audio Azur 540D...$269 (anywhere)
    Energy Connoisseur C-3 speakers...$189/pr (Ebay, NIB Reg $600)
    Kimber PBJ....$75 (anywhere)
    Kimber 4TC...$146 6ft pr (anywhere)
    =$1378.00 and you've got a $122 shipping budget remaining.
  • halo
    halo Posts: 5,616
    edited July 2006
    Portable CDP you already own (Discman or something similar) $0
    Sonic Impact amp $30
    16AWG Home Depot cables $10?
    RCA to single mini jack (to hook up cd to sonic impact) $10
    Vintage Polks - Monitor 7 and up $100 - $200? Even less if you find something at GW or a local garage / estate sale.
    This may not be the best thing in the world but it's waaaaaaaaay better than a HTIB or anything from Bose! $150 - $250.
  • unc2701
    edited July 2006
    Jolida 1501RC hybrid integrated $650
    DIY Jordan JX92s MLTL $400ish (Assumes you don't go crazy on the cabinet)
    So that leaves $450 for source & cables... Let's go with cambridge 640c used for $300 and $150 for whatever cables get you off.
  • AndyGwis
    edited July 2006
    If you're looking cheap-cheap, here's what I have running in my kitchen just out of some spare parts:
    T20ebs (Monitor 30's) - $80 NIB from Tweeter
    TFM 6CB amp - $150
    DIY 12awg speaker wire - $10
    MP3 player / iPod / CD player directly into amp - $0
    Making dinner never sounded so good. . . still usually tastes like crap though :)
  • Danny Tse
    Danny Tse Posts: 5,206
    edited July 2006
    My system....
    Cambridge Audio A500 stereo integrated amp $250.00 shipped (from Audio Advisor)
    Energy Connoisseur C-3 bookshelf monitors $300.00/pair (from the now defunct Good Guys chain)
    Sony SCD-CE595 CD/SACD changer $150.00 (from Best Buy when it was first introduced)
    Radio Shack AV Fusion 1M interconnect $12.99
    PS Audio 2M Prelude speaker cable $55.00 shipped (from Audio Advisor)
    Total: $767.99
    All item new and from authorized dealer w/ factory warranty. Substitute the Cambridge Audio integrated amp with the TEAC A-1D stereo integrated amp ($175.00 shipped from J&R) and the total lowers to $692.99.
    Refurbished Sony SCD-CE595 CD/SACD changer available direct from Sony for $79.95 w/ free shipping ending Thursday
    Buy music with rest of the money.
  • Poee7R
    Poee7R Posts: 904
    edited July 2006
    ya im a bit of a tube newb on a budget, but i would go new with this...
    Onix Sp3 integrated
    Onix Ref 1
    =$1199 + shipping
    (i believe you could probably get every dime back if you choose to sell in the future to upgrade)
    a Cd player of your choice for under a 100 or so, i have an Integra i managed to grab for 30 bucks and it sounds pretty decent. YMMV
    Then a couple bucks on a pair of Kimbers, audioquest, tara etc.
    (Used of course, thats where your deals are).
    Once again we meet at last.
  • Joey_V
    Joey_V Posts: 8,592
    edited July 2006
    Onix Sp3 integrated
    Onix Ref 1
    =$1199 + shipping
    I dont think so. Mark's products have taken a huge hit in the used market... particularly due to his sales.
    You can literaly buy the Ref1 for around $400 on the gon.
    Decent speaker still.
  • Poee7R
    Poee7R Posts: 904
    edited July 2006
    that is why i said probably, and mostly because of the integrated getting $600 or so on used sites. And even at 400 or so on the speakers, you only getting hit by depreciation for 200 or so.
    And from starting from new going to used thats maintaining a solid value.
    But im sure you could probably get a bit more out of the speakers on Ebay vs the gon.
