Man, struggling getting wires outside...
jrlouie
jrlouie Posts: 462
So I moved in to a new apartment that has a private patio. I want to put my Atriums on the patio, but I am really struggling figuring out how to run my speaker wires outside to them. To get to the patio, there is only a sliding glass door.
Any great ideas that just haven't dawned on me yet? I can attach pics at lunch time if needed.
Post edited by jrlouie on
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    That's a tough one---short of finding a very inconspicous place to drill a hole in the slider's frame (near the bottom corner?)
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    Through the wall.
    There has to be a little wall room around the door.
    Go through the wall and sily-cone the wires in the hole.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2006
    If you don't care much about sound quality, there are some wireless speakers to be had out there. I have some Altec Lansings that work pretty well, that I got off the 'Bay, for simliar duties.
  • steveinaz
    edited June 2006
    Skynut wrote:
    Through the wall.
    Good point, there's got to be some wood framing around the slider frame.
  • jrlouie
    jrlouie Posts: 462
    edited June 2006
    Yeah, maybe drilling a hole and using silicone wouldn't cause too much damage. I just don't want to be screwed when I move out. I wish I could somehow cram a wire between the sliding pane and stationary panes of glass since there is a gap, that might be asking for trouble though because when closed there is some felt or something that makes a seal.
  • unc2701
    unc2701 Posts: 3,587
    edited June 2006
    Drill plus silicone. When you move out, cover it with spackling. IF the landlord asks, you don't know what they're talking about. I've done this on at least three apartments.
    Backburner:Krell KAV-300i
  • steveinaz
    edited June 2006
    There you go...spackle and paint silver, they won't see it. OR
    You might consider buying a used receiver dedicated for the patio--that's what I do. I think I paid 40 bucks for the receiver and I threw a $40 Tosh DVDP for my source.
  • SuperDave
    SuperDave Posts: 168
    edited June 2006
    Drill a hole bro:eek:
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • joeparaski
    joeparaski Posts: 1,865
    edited June 2006
    Screw the drill, takes too long....a high powered rifle aimed at the lower corner should give you just the right sized hole to pass the wire through.
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2006
    Just make sure the judge from your divorce trial isn't across the way in your line of sight.;)
    http://story.lasvegasherald.com/p.x/ct/9/id/3b61e90fb49a73b1/cid/665230c96a861075/
  • gidrah
    gidrah Posts: 3,049
    edited June 2006
    See if you can unscrew the frame to the sliding door and slide some flat wire underneath.
    Make it Funky! :)
  • jrlouie
    jrlouie Posts: 462
    edited June 2006
    I ended up sneaking a cable between the sliding door and the stationary door where there is this felt-like seal. The cable rubs just barely, but not too bad. They're relatively cheap cables anyway, so if they get damaged, I don't care. We'll see what happens. The frame is very thick, so I was trying to avoid drilling. Maybe I'll drill if my current setup fails. So far, so good.
    Thanks for the ideas.
  • Dennis Gardner
    edited June 2006
    Glad you got is figured..............remember, damaging the cables won't hurt as much as shorting out your amp.
  • jrlouie
    jrlouie Posts: 462
    edited June 2006
    Good point. But, again not worried too much. I'm using an old cheapo integrated that even has the power button glued to make it stay turned on :) It's a piece of work I tell ya. Don't know why it ended up in my hands.
