Man, struggling getting wires outside...
jrlouie
So I moved in to a new apartment that has a private patio. I want to put my Atriums on the patio, but I am really struggling figuring out how to run my speaker wires outside to them. To get to the patio, there is only a sliding glass door.
Any great ideas that just haven't dawned on me yet? I can attach pics at lunch time if needed.
Post edited by jrlouie on
That's a tough one---short of finding a very inconspicous place to drill a hole in the slider's frame (near the bottom corner?)Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Through the wall.
There has to be a little wall room around the door.
Go through the wall and sily-cone the wires in the hole.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
If you don't care much about sound quality, there are some wireless speakers to be had out there. I have some Altec Lansings that work pretty well, that I got off the 'Bay, for simliar duties.If you will it, dude, it is no dream.
Skynut wrote:Through the wall.
Good point, there's got to be some wood framing around the slider frame.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Yeah, maybe drilling a hole and using silicone wouldn't cause too much damage. I just don't want to be screwed when I move out. I wish I could somehow cram a wire between the sliding pane and stationary panes of glass since there is a gap, that might be asking for trouble though because when closed there is some felt or something that makes a seal.
Drill plus silicone. When you move out, cover it with spackling. IF the landlord asks, you don't know what they're talking about. I've done this on at least three apartments.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
There you go...spackle and paint silver, they won't see it. OR
You might consider buying a used receiver dedicated for the patio--that's what I do. I think I paid 40 bucks for the receiver and I threw a $40 Tosh DVDP for my source.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Drill a hole bro:eek:SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
Screw the drill, takes too long....a high powered rifle aimed at the lower corner should give you just the right sized hole to pass the wire through.Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
joeparaski wrote:Screw the drill, takes too long....a high powered rifle aimed at the lower corner should give you just the right sized hole to pass the wire through.
Just make sure the judge from your divorce trial isn't across the way in your line of sight.;)
http://story.lasvegasherald.com/p.x/ct/9/id/3b61e90fb49a73b1/cid/665230c96a861075/HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
See if you can unscrew the frame to the sliding door and slide some flat wire underneath.Make it Funky!
I ended up sneaking a cable between the sliding door and the stationary door where there is this felt-like seal. The cable rubs just barely, but not too bad. They're relatively cheap cables anyway, so if they get damaged, I don't care. We'll see what happens. The frame is very thick, so I was trying to avoid drilling. Maybe I'll drill if my current setup fails. So far, so good.
Thanks for the ideas. -
Glad you got is figured..............remember, damaging the cables won't hurt as much as shorting out your amp.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Good point. But, again not worried too much. I'm using an old cheapo integrated that even has the power button glued to make it stay turned on
It's a piece of work I tell ya. Don't know why it ended up in my hands.
