Need help on Harmon Kardon avr 7200
SOUNDMASTER5158
SOUNDMASTER5158 Posts: 13
edited November 2012 in Troubleshooting
My HK went out no power what so ever.
I tried the regular reseting the unit and that did not work.
I also tried the hard reset where I press the surround mode button and the tuner button at the same time and still nothing this unit should be working great it is only about 2 years old and I have it protected by a surge protector threw monster and so on .
If anyone out their has any other suggestions like should it be left unpluged for longer or some other reset option anyone has would be greatly appreciated.
thanks in advance:cool:
:cool: :DEric Eck
Clinton Township Mi 48036
Hitachi HDTV 72 inches by 16:9
Harmon Kardon AVR 7200
Harmon Kardon (2) PA 2000
Harmon Kardon (2) PA 4000
Polk Audio (4)RTI 150
Polk Audio (2) LSIC
Polk Audio (4) LSFX
Xbox
Xbox 360
Playstation 1
Playstation 2
Playstation PSP
:D :cool:
Post edited by SOUNDMASTER5158 on
  • danger boy
    danger boy Posts: 15,722
    edited May 2006
    my suggestion.. contact HK.. it's theirs, they should know how to solve your problem.
    good luck
    PolkFest 2012, who's going>?
  • masanz1
    masanz1 Posts: 511
    edited May 2006
    probably a fuse inside. if it is under warranty take it in to have it fixed, if not check the fuses inside. I am not sure about HK however
    Matthew
    Sometimes the road less traveled is less traveled for a reason
    HT
    Yamaha RX-V2500
    CS400-Center
    SDA 1A-Mains
    RT20-Surround
    None right now-Rears
    SVS 20-39PCi
    Infocus IN72
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2006
    Just a shot in the dark, but there are 2 power buttons................standby and total power on/off.
  • Sami
    Sami Posts: 4,634
    edited May 2006
    Same thing happened to my 7200 recently, just barely outside warranty. I checked the fuses and everyone of them seemed to be ok. Took out multi-meter and started troubleshooting...turns out it's a fuse afterall. Couldn't see it but resistance showed 1 Ohm (should be 0) so the fuse was broken. Open it up and check the power board first (it's the small board in middle front top).
  • SOUNDMASTER5158
    edited May 2006
    So were you able to fix it on your own if so could you please tell me how you did it. is the fuse accesable to change or does it take a tech to fix it. how did you get the parts how much were the parts.:)
    tyia
    eric
    :cool: :DEric Eck
    Polk Audio (2) LSIC
    Polk Audio (4) LSFX
    Xbox
    Xbox 360
    Playstation 1
    Playstation 2
    Playstation PSP
    :D :cool:
  • SOUNDMASTER5158
    edited May 2006
    this is the picture of the inside of my HK 7200 I found three fuses first one I found is from left to right
    1st I found by my main power coupling
    2nd I found on top of my circuit board in the middle up front
    3rd I found in on the same board but closer to the front of the unit.
    the blurry picture is the one by my main coupling.
    Is this what SAMI was talking about I do not see any other fuses.
    thank you
    eric
    :cool: :DEric Eck
    Polk Audio (2) LSIC
    Polk Audio (4) LSFX
    Xbox
    Xbox 360
    Playstation 1
    Playstation 2
    Playstation PSP
    :D :cool:
  • Sami
    Sami Posts: 4,634
    edited May 2006
    The last picture, that's where I replaced a fuse and it's working great now.
    It was the 500mA/250V one which is at the bottom on the picture, the lone one. Got replacement from Home Depot, 500mA/250V fast acting fuse. Not the exact same fuse but as long as it is fast acting I don't see a danger to it.
    If you can't see if the fuses are broken, get a multimeter (won't cost much and will come handy) if you don't already own one. You can check the fuses by measuring resistance (ohms), if the fuse is ok it will have hardly any resistance and multimeter will display 0 but if it is broken it will not pass electricity and you get 1 on the display (same as air).
    http://www.bobvila.com/HowTo_Library/Testing_Appliance_Fuses-Miscellaneous-F2232.html
    If the fuses are ok you can still pinpoint the broken board/component by measuring voltage.
  • SOUNDMASTER5158
    edited May 2006
    Thank You very much Sami I took out five fuses and the one you said was bad so I went to radio shack and replaced all five fuses I just got home so I have no idea if this is going to work but the one you said that was bad on yours was bad on mine so I figured why not replace them all while I have this thing apart and open.
    Thank you again
    thank you to all the members out here if it was not for all your help and for polks website forum I probably never would have tried this.
    Eric
    :cool: :DEric Eck
    Polk Audio (2) LSIC
    Polk Audio (4) LSFX
    Xbox
    Xbox 360
    Playstation 1
    Playstation 2
    Playstation PSP
    :D :cool:
  • mrbigbluelight
    mrbigbluelight Posts: 9,828
    edited May 2006
    Take an extra $20 from the cash drawer before you lock up !! :)
    Looking at that last picture, I think I spot some pico fuses on the top left of that same board, too.
    Pico fuses look kind of like a 1/4 watt resistor.
    They won't be soldered to the board, the leads slip into mounts (to allow easy removal). Pico fuses are used to protect modules from overvoltage during a power supply failure.
    The picos I'm familiar with are used on communications lines to PLC's.
    They blow at milliamps, not infrequently, when lightning strikes nearby (at least around here they do).
    Now something I didn't know was that pico fuses come in large amperages, too. Looks like you can get them up to 10 amps !!!
    Any-who, the EXCELLENT assistance from Sami should solve your problem.
    If it doesn't, have a look-see at those (possible) pico fuses.
    NOTE: UNPLUG THE POWER CORD FROM THE OUTLET BEFORE MESSING WITH STUFF. ALWAYS.
  • SOUNDMASTER5158
    edited May 2006
    thank You All So Much Everything Is Up And Running And Disturbing My Neighbors As Normal. But I Am Glad They All Like The Music I Normally Play.
    Thanks Again Polkabies Your The Greatest.
    Eric
    :cool: :DEric Eck
    Polk Audio (2) LSIC
    Polk Audio (4) LSFX
    Xbox
    Xbox 360
    Playstation 1
    Playstation 2
    Playstation PSP
    :D :cool:
  • camajo
    camajo Posts: 2
    edited June 2007
    I dug up this old thread after coming home from a week long vacation only to find my HK AVR7200 dead. No power.. no lights... nothing.
    I replaced the same fuse you guys mentioned and presto! Its back in action! Decided to bring this post back from the dead just to say thanks if any of these guys are still around.
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    Good to hear your back up and running. That's one of the good things about this forum.
    engtaz
  • Sami
    Sami Posts: 4,634
    edited June 2007
    It seems to be the most common thing that goes bad with these receivers. It's a good feeling when you discover it's only a fuse you can replace yourself, isn't it!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2007
    Not sure just what that fuse does in the circuit, but if some people have an issue with it I wonder if 500ma is a bit small.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • AntiGravityHero
    AntiGravityHero Posts: 3
    edited July 2007
    I stumbled across this thread after finding my own 7200 dead one morning.
    My fuse "F453", the 500ma/250v one that seems to blow often, was in fact blown.
    However, I noticed another very important detail - capacitor C498 (the light blue 1000uf, 25v unit on the bottom right side of the board) had a bulging top and was leaking some electrolyte.
    The capacitor is made by "Lelon". These same capacitors have been an issue in many PC motherboards and other electronics. I am guessing that a gradual failure of this cap is causing the blown fuse and eventual total failure of the supply board.
    Check your capacitors, especially C498! I am going to replace mine before putting in a new fuse.
  • Shark
    Shark Posts: 2
    edited November 2007
    Exactly the same issue here.
    Came home last week & no lights, no power, just dead.
    Opened it up tonight & the same fuse is blown, as well as some black stuff at the bottom the same capacitor.
    Will replace the parts tomorrow & let you guys know if it fixes the issue.
    Good post though, without this info, I would have likely sent it away for a costly repair bill.
  • PSOVLSK
    PSOVLSK Posts: 5,216
    I wonder if this is all that was wrong with my 7200. I didn't come across this thread like some of you, but instead took it to Fry's for repairs. They kept it a couple of months but said they couldn't fix it and tried to replace it with a 625. After much discussion about the what would be an "equal" replacement, I finally walked out with a new 7300.
  • Shark
    Shark Posts: 2
    Update, good news!!
    I had 2 caps that were leaking on the power supply board, the one listed above, a 1000uF, and the larger one in the middle of the board, a 4700uF.
    Replaced them both, & the open fuse, & back in business!
    Thanks guys
  • sbenson
    sbenson Posts: 1
    edited April 2008
    looks like I'm in the same boat.
  • SpartanGA
    SpartanGA Posts: 4
    edited November 2008
    I love this thread!
    My 7200 did this same thing. I hope the fuse is the issue. The fuse in question is the only fuse that is covered with a white sticker/paper of some sort that doesnt allow me to see inside. The others were obviously intact, so I am leaving those.
    I also have the black electrolyte from those capicators. How did you replace them? I can buy the same at Radio Shack or Frys, but did you remove the board from the receiver and have to unsolder and resolder them? I havent removed the board to take a peek, so thought I would ask first.
    thx!
  • SpartanGA
    SpartanGA Posts: 4
    for some reason I cannot edit my above post. I was incorrect in that post. The fuse with the paper covering is the 240V 15A fuse...the longest fuse. I finally pulled all five fuses and one by one they were showing continuity. I was getting worried. Then the last was the 240V 500mA fuse, BAM...it is shorted.
    'dance dance dance'
  • ViperZ
    ViperZ Posts: 2,046
    SpartanGA wrote: »
    'dance dance dance'
    You mean opened, not shorted. "shorted" fuse is a good fuse, since it's just a "wire".
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • SpartanGA
    SpartanGA Posts: 4
    ViperZ wrote: »
    yes, correct. ZERO continuity.
  • ViperZ
    ViperZ Posts: 2,046
    SpartanGA wrote: »
    You mean zero resistance... sorry, being an electrical engineer, couldn't hold.
    Testing for continuity across that component (in your case) means checking that there is a connection present between your test probes.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • Sami
    Sami Posts: 4,634
    ViperZ wrote: »
    0 resistance on a fuse would mean it is good, no?
  • disneyjoe7
    Huh,?
    Zero Resistance on a fuse is good.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sami
    Sami Posts: 4,634
    disneyjoe7 wrote: »
    Huh,?
    Yes. 0 resistance = good. 0 continuity = bad. Maybe Viper thought he was talking about a good fuse, not a bad one?
  • SpartanGA
    SpartanGA Posts: 4
    Sami wrote: »
    No idea. But I checked the fuse for continuity...and since I didnt get any, the fuse was bad.
    Has anyone here replaced the capacitors that are leaking on the same top board as most of the fuses? There is a 1000uf little blue one and 4700uf taller black one. both have some black 'goo' (electrolyte?) leaking out the bottom...could this be causing the fuse to blow?
    If you did, how did you do it? e.g., did u remove the board and unsolder, then resolder replacements and where do u get the replacements etc. Radio shack didnt carry this exact voltage and capacitance.
    thx
  • ViperZ
    ViperZ Posts: 2,046
    SpartanGA wrote: »
    thx
    Yeah, sorry, I guess replying while sitting on the overnight shift sux :). No continuity means bad on a fuse :).
    Regarding leaking electrolytic caps, you definitely have to replace those.
    The replacement caps can be found on www.digikey.com or www.mouser.com or any other online parts shop. A few notes:
    - electrolytic caps are rated by capacitance and voltage. You can get higher voltage (but same capacitance) caps for better reliability, but make sure that those will physically fit on your board.
    - make sure to maintain correct polarity when installing the electrolytic caps. "-" is usually marked on the board. Otherwise, just check where "-" terminal of the old capacitor was (marked on the cap).
    - to remove the caps, check if you have clean access to the bottom of the board. If you don't, then you'll need to remove the board (usually you don't have to though). Desolder the caps. Clean the board from the electrolyte. Alcohol will do the trick. Then solder the new caps.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • camajo
    camajo Posts: 2
    edited February 2009
    Well, after a blown fuse a year and a half ago my HK is out of commission again. Doesn't appear to be the fuse this time.
    I get a new behaviour. Power on makes the lcd screen light up for a split second and then the unit shuts down.
    I arleady tried to reset to system defaults as mentioned in other posts and it does no good.
    I opened the receiver up for the heck of it and I notice some black "goo" which i'm assuming is the leaky electrolyte others have mentioned.
    Any chance replacing the capacitors where i find the electrolyte will likely do the trick or do I maybe have bigger problems?
