Interconnects and Speaker Wire
audiobliss
audiobliss Posts: 12,518
edited March 2006 in 2 Channel Audio
I was sitting here thinking about my system, how I'm soon to get a CDP, and then hopefully I'll be able to add an ELP to my system. Besides placement, I was trying to think of what's next. That would leave IC's and speaker wire.
I don't want to pay out the yazoo for connections, but I do want to have something a bit above Radio Shack quality. I think I could afford some of the Signal Cable stuff, and since he's affiliated with the forum, I'd like to buy some from him.
What's the more important? Speaker wire and jumpers or interconnects or power cables? In other words, what should I invest in first? Of course, I won't actually invest in either until I get my CDP and a preamp, but I got to wondering about this today.
Thanks!
EDIT - Added power cables to the mix. Completely forgot about them.
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • Shizelbs
    Shizelbs Posts: 7,433
    edited March 2006
    Based on my experience, I would say speaker wire has made more of a difference than ICs.
    Check out Raymond Cable too. Its a small setup out of Washington State. Dangerboy and I use them and we have both been pretty happy with the results.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2006
    To me ICs make the most difference in sound. YMMV
  • polkatese
    polkatese Posts: 6,767
    edited March 2006
    I would start with matching Speaker wire and IC from the same vendor, so you get the benefit of synergy. And then Power cable, next. again, from the same vendor. Signal Cable is a good vendor to start with.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    I would say the connect between the source and the pre would be a good place to start.
    RT1
    F1nut Posts: 51,770
    edited March 2006
    RT1
    Agreed
  • LuSh
    LuSh Posts: 887
    edited March 2006
    After a number of years tweaking with various cables, I think the answer is...where do you want to tweak? Do you want to hear your speaker wire or your interconnects or perhaps both? I think a good way to do it is to pick one. And with the other pick a very neutral cable, perhaps a Carda's, then play around with the other part. Both the speaker wire and interconnects can alter (not always for the better) the sound of your system. How much you want to change the tone of your system is entirely up to you. I would recommend taking the approach I've layed out.
  • reeltrouble1
    edited March 2006
    If you like I will put your name on some Signal Analog One I have around here someplace.
  • organ
    organ Posts: 4,969
    edited March 2006
    Upgrade your speaker wires to Audioquest type4. Very good sound. There are 4 conductors in each wire. One set is labeled "bass" and the other "treble". Bi-wire your RF's with them. After going with AQ, I don't think I can go back to stranded wires again. Those solid copper conductors sound so clean and accurate.
    The best part about AQ's Type4 is the low price! Anyone can enjoy it.
    For the IC's, there's too many to choose from. I'd recommend AQ again because I have great success with the "Diamondback" but it is a little pricey. I'm sure they have cheaper IC's. Keep in mind that if you feel your system is too bright, you may not enjoy the Diamonbacks. They're not bright. They're neutral, detailed and accurate. But I can see people not liking it if they're trying to get more warmth.
    heiney9 Posts: 25,432
    edited March 2006
    IC's between the source and pre; or between a dac, source and pre, as long as you have decent quality speaker wire. If you are using something like lamp cord for speaker wire, I'd say address both, IC's and speaker cable.
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2006
    Just buy single crystal copper insulated with human skin....they are the best.
  • organ
    organ Posts: 4,969
    edited March 2006
    No way! Snake skin is better. Less capacitance/inductance than human skin. The scales act as a shield too!
  • audiobliss
    edited March 2006
    I don't really care what it's wrapped in, just so long as it's floating in snake oil so it doesn't directly contact the insulation. :p
    Thanks for all the advice, guys. I'm thinking IC's will be first, followed closely by some speaker wire. I'm thinking about Signal Cable Classic Bi-Wire speaker cable with the AP Spades on both amp and speaker end termination. That should come up to be $157 for 12' for biwiring with the upgrade termination for both speakers. I must say, that's not too bad.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • organ
    organ Posts: 4,969
    edited March 2006
    If you don't plan to swap cables regularly, go bare. Spades/bananas are there to make your life easier when swapping.
  • audiobliss
    edited March 2006
    Oh, and isn't there some kind of a CP discount? What's that good for?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • organ
    organ Posts: 4,969
    edited March 2006
    I think the CP discount is expired now. Can somebody confirm this?
  • audiobliss
    edited March 2006
    Hmm. I'm not sure, but I'm thinking I wouldn't like going bare.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • organ
    organ Posts: 4,969
    edited March 2006
    Going bare gives you less stuff in the signal path. Easier to cut and strip new ends when the cables get oxydized.
    edited March 2006
    Alligator skin as insulation is not only fashionable, but it sounds good too! Copper wrapped in Alligator skin, can't go wrong with that combo.
  • dorokusai
    edited March 2006
    The SC discount has always been in effect.
  • danger boy
    danger boy Posts: 15,722
    edited March 2006
    RT1
    I most humbly disagree. Might be a good place to start.. but the place for the most difference is between the pre and the amp. to me.. all other replaced interconnects just offer minor improvements.
    that's my story and i'm sticking to it. :p
    PolkFest 2012, who's going>?
  • organ
    organ Posts: 4,969
    edited March 2006
    Cool! Gor for it, Bliss. Would be cool to save up and wait until you can get both IC's and speaker wire. The wait is going to kill you but the reward will be worth the time/money. It feels real good to wait and buy several pieces at once:) .
  • reeltrouble1
    edited March 2006
    Yes, my good man, but you live in the FOG.
    RT1
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2006
    Whatever you do, I'd recommend you don't replace speaker/IC's at the same time. Try whichever wire for a couple weeks before adding another varible into the synergy equation. Never a good idea to change out more than 1 thing at a time--it'll have you chasing your tail big time.
  • audiobliss
    edited March 2006
    Yeah, I would like to replace one thing at a time just so I can hear the difference each piece makes to the system.
    Thanks for all the suggestions, folks! I think I've decided to go with Signal Cable, and to start with IC's, then speaker wire, then maybe power cords at some point.
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • steveinaz
    edited March 2006
    I should have added, if you replacing IC's, make sure you replace all in the chain from source to power amp...
  • ohskigod
    ohskigod Posts: 6,505
    edited March 2006
    for kicks and giggles, I just orderred a pair of Anticables 7 ft pair speaker wires. 75.00 shipped, supposed to be giant killers to some extent. 75 bucks, eff it, worth a shot.
    I'll give a review after I get some time with them down the road.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ohskigod
    edited March 2006
    oh, and I gotta put interconnect between pre and amp before source and pre. not to diminish the connection between source and pre.
    at least to my ears.
  • shack
    shack Posts: 11,154
    edited March 2006
    You gotta use the same interconnects between the source, pre and amp AT THE SAME TIME. Any thing less is redundant and you are not reaping the full benefits of the cables.
  • ohskigod
    edited March 2006
    dude, that means I gotta buy another set of nordost solar winds, faaaaaaaaaaak!!!!
  • marvda1
    marvda1 Posts: 4,947
    edited March 2006
    it was put to me this way, either use the same interconnect between source/pre as between pre/amp or use the best interconnect between source/pre since if you are not getting the best signal from your source the best interconnect in the world cannot add it in at the pre/amp end.
    check out www.zebracable.com
    Puritan PSM156
