Bi-Wire Worth the effort?
haveyouever
haveyouever Posts: 25
edited March 2006 in Speakers
Does anyone have experience with bi-wiring the Polk Lsi Series speakers?
I've finally finished my speaker wiring for my HT system. I took my time and completed the wiring last month. Not a single wire/cable is visible by the eye... all routed through the wall keeping 110V wiring at a distance! I have the following speaker array:
Front: Polk Lsi15s
Center: Polk LsiC
Surrounds: 2 X LsiFX
Denon 4806
Anthem Statement A5
The question is?.... Would I gain that much by bi-wiring these Polk Lsi series speakers??... which would equate to some extra work in regards to pulling wiring!! And this is not a walk in the park by any means... I have two outside walls to deal with??... your thoughts?
Post edited by haveyouever on
  • speakergeek
    speakergeek Posts: 555
    edited February 2006
    Search the forum. In general, some say you will hear a difference, and some say you won't. Not sure it would be worth the effort and expense in your case.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Not worth the effort unless you intend to bi-amp, then I would still think twice about it, in your case.
  • dorokusai
    dorokusai Posts: 25,576
    Nope.
  • Emlyn
    Emlyn Posts: 4,696
    I found no benefit to biwiring or biamplifying LSi15's. Even with 800 watts going to each speaker, they sounded no different than sending them 200 watts each.
  • haveyouever
    Thanks Guys!... I appreciate your prompt feedback!!... we really enjoy our current setup and with a little help from the polk knowledge base, plan on keeping it that way for the time being!!... have a great evening!!!... thomas
    F1nut Posts: 51,732
    Try changing the metal plate jumpers to the same wire as you're using for cables. I believe you will hear a difference.
  • MrNightly
    MrNightly Posts: 3,370
    Really? Why is this? i've never heard about this before... Do expound on the topic :)
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • BobMcG
    BobMcG Posts: 1,585
    What effort?:confused:
    Some extra money yeah, but what effort?;)
    F1nut Posts: 51,732
    The cables make better conductors than those cheap plated bars. Plenty of info here about jumpers.
  • Giuseppe
    Giuseppe Posts: 42
    Hey I am just wondering what the problem is with keeping 110V wiring at a distance? You said "all routed through the wall keeping 110V wiring at a distance!" It may be a stupid question. My guess is that A) Fire hazard or B) some kind of sound distortion???
    Harman Kardon AVR 7300
    Monster MK II Power Center
    Logitech Harmony 890
    HSU VTF-3 MK2 Sub
    Polk Audio RTi10
    Polk Audio RTi6
    Polk Audio FXi3
    Polk Audio CSi5
  • mantis
    mantis Posts: 17,342
    When I owned the Lsi's I perferred them Bi wired. I used a Double run Shotgun 8tc 8tc bi wires. I felt it made a noticable difference in overall sound quality and I never went back. I did however always wanted to try 1 level higher 2 conductor with replaced jumpers of that level wire vs the Bi wires. It was a question for me that went unanswered. I never got to do the demo.
    I actually got new speakers.
    Why not try it. You can sit in your home and listen to a pair of bi wires vs a single run. Try the same brand same quality and then try a higher end cable and see what it sounds like.
    Good luck,
    Dan
    Dan
  • haveyouever
    All your residential electric power generated in North America is 60-Hz alternating current (AC). This means both the voltage and current are sinusoidally varying (change polarity twice in each cycle or 120 times every second). OK!... stay with me now!!!... Any electric conductor, with voltage flowing through it, has what is called a magnetic field of flux surrounding it! Some more, some less...If your run your speaker wire next to any AC source - hence – 110Volt AC house wiring, you may/will induce what is called an EMF(Electro Magnetic Force) into your speaker wire. Your ear would pick it up as static and/or noise in your speaker! The cycling of this field of flux and induction of an EMF in another wire, is basically how a transformer steps up and steps down voltage based on the number of windings per stage.
    Now, what this all means toward your question is keeping your wiring out of this so called critical path(Field of Flux), so you reduce the chances of inducing an EMF in your speaker wiring. There are different schools of thought of how far this magnetic flux actually expands from any low or high voltage wire. Personally, I have found with 110AC that about 6 inches away with well shielded wire is enough to sustain a good signal to your speakers. If you need to cross any AC wiring in a wall of your house, cross at a 90 degree angle. This reduces the area proportional to the transfer.
    As Eddy Murphy would say!!... It’s as simple as that???
    I hope this helps!!
  • amulford
    amulford Posts: 5,020
    Good explanation.
    No to the original question.
    F1nut Posts: 51,732
    Of course, one could buy nice shielded cables and not worry about RF and EMI.
  • dragon1952
    dragon1952 Posts: 4,907
    I'm curious as to what the Lsi manual says about bi-wiring. Both my Paradigm Studio series and Vandersteen manuals highly recommend bi-wiring. I know some will say that's just the speaker companies coddling to the masses but I don't really buy that.
  • haveyouever
    Don't fool yourself?... it's not as simple as nice shielded cables???... unless you plan on connecting your shields to ground at the source?... and what audio cable company takes that into consideration?
  • haveyouever
    amulford wrote:
    Good explanation.
    Ya!... sorry!!.. I should know better... being that I started this thread... just trying to address a concerned polk member!!
    F1nut Posts: 51,732
    The ones with directional arrows on them.
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    hey...people....What's the principal advantage to use bi-wired speakers ????
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • dragon1952
    Basically you're bypassing the crossover network....or at least part of it depending on your speaker configuration.
  • fshan
    fshan Posts: 110
    edited March 2006
    I hope this helps!!
    Very, very good explanation. Except the part about grounding the shield at one end and one end only. Something you knew quite obviously. (but can't be left out.
  • FicmanS
    FicmanS Posts: 134
    edited March 2006
    I didn't notice any big difference in my setup...
    Rockin' In My House :D
    Pioneer 50 inch Plasma TV
    Denon AVR-3806
    Denon DVD-1930ci
    Polk Montor 70's
    Polk PSW-12
    Polk CS2
    Polk Monitor 40's
    Sirius Satellite Radio, Monster 3500MKII
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited March 2006
    Magnetic field strength can be measured quite accurately with a Gauss meter. There are different types of meters depending on what type of energy source (high voltage line, house AC wiring, etc.) is generating the field.
    Power companies have to accurately measure the magnetic field strength of high voltage lines because of the danger of high currents being induced in metallic surfaces (truck doors, uninsulated wire, etc.). There are quite a few cases of a power company employee or contractors being "electrocuted by induction" when they touched a conductive metal surface or object that was in the magnetic field of a nearby high voltage line.
    With regard to your bi-wiring question, I have found that any improvements heard depended on the amps more than the wire.
  • haveyouever
    edited March 2006
    Yes!... my man!!... very good point!!!
  • haveyouever
    edited March 2006
    [QUOTE=With regard to your bi-wiring question, I have found that any improvements heard depended on the amps more than the wire.[/QUOTE]
    Darqueknight!... Please elaborate a little more!!... with my a/v receiver, amp and speakers left constant... does the removal of the jumpers and replacement of biwire to say my fronts and center make a difference?...
    F1nut Posts: 51,732
    edited March 2006
    I'm curious, have you any experience with shielded cables? What speaker cables are you running thru the walls? Why not try replacing the jumpers first to see if that makes a difference?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    Yea, F1, I mean its not like you have any experience in bi-wiring now.:) Or using cables for that matter.;)
    I dont have a clue with regard to bi-wiring LSI. My guess is though that you should do it and be done with the issue or you will have to find another way to quiet the voices because we NEVER agree on this. It nots going to take much to try using wire instead of the flat little yellow metal colored plate.
    They are transmission lines of course they make a difference.
    RT1
  • DarqueKnight
    edited March 2006
    It depends on your ears, the amps, speakers, and wire used and on the synergy among the components. Here's are a couple of links:
    My bi-wire adventure:
    http://www.polkaudio.com/forums/showthread.php?s=&threadid=9914
    My bi-amp adventure:
    http://www.polkaudio.com/forums/showthread.php?t=10191
  • haveyouever
    edited March 2006
    Thanks big guy!... that really help... best regards!!... thomas
    F1nut Posts: 51,732
    edited March 2006
    So, what experience with shielded cables do you have and what speaker cables are you running thru the walls?
