LSI Series
tjweeks
tjweeks Posts: 6
edited May 2002 in Troubleshooting
I currently have a Polk CS400 for my center. It is matched up to an old pair of RTA12's. The timbre matching is fairly good between these two. If I got a set of the LSI Series speakers, would the CS400 still match up (timbre-wise).
Post edited by tjweeks on
  • TroyD
    TroyD Posts: 13,093
    edited May 2002
    yes
  • mantis
    mantis Posts: 17,206
    edited May 2002
    Are you sure there won't be any kind of timbre change between the cs400 and a member of the LSI family?
    If there isn't ,that would benifit alot of people who want to just change out there mains to a better pair of LSI.
    I think there would be, as for one its a different kind of tweeter,different series,not to mention Polk made a center channel to match.But if the cs00 matches,why buy the LSI center,no need for it.You can save your money and spend it somewhere else.
    Dan
  • Steve@3dai
    Steve@3dai Posts: 983
    edited May 2002
    The highs would be where you might have a difference. The LSi series has a "presence" that might not be there with the CS400. But I say try it!
    - Steve
    LSi 9/C/FX
    Arcam AVR-200
  • mantis
    edited May 2002
    Can't hurt to try.You can always upgrade down the road and start enjoying those LSI's for 2 channel now.
    Dan
  • TroyD
    TroyD Posts: 13,093
    edited May 2002
    Paul had posted earlier that he demoed the LSi9's with a CS400i and reported good results. Obviously it isn't a perfect match but one that produces good results. If it is good enough for Paul, it's good enough for me.
    I don't think using the LSi's with the CS400i would produce any more of a mismatch than using the RTA's
    Big Dumb Troy
  • joe logston
    joe logston Posts: 882
    edited May 2002
    yes, thats what i wanted to know is what kind of match the lsi-9 would have with the cs-400i and may be get the lsi center lateter on, or get one more lsi-9 , the only thing is that the lsi-9 are mirror paired. am i right about that.
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • johnnyamerika
    johnnyamerika Posts: 382
    edited May 2002
    May not be a perfect match, but you can always throw the cs400 into the back surround position in a 6.1 setup...that is after you buy a LSiC of course :D
    Let us know!
