Sound deadening has started
exalted512
exalted512 Posts: 10,735
before:
after, this is all i have done right now but i did put some foam in the crossmembers
why you want to spend money on a razor knife
the truck tore apart
picture of the mat under the drivers seat
picture of the mat on the roof
picture of the sludge under the drivers seat
picture of the sludge on the almost finished head liner
thats all i have right now, i was going to work on it tonite but i forgot my light at work so itll have be tomorrow. Hopefully tomorrow ill be able to lay mat across where the seats should be and sludge that, followed by the paint on stuff.
1 layer on the roof with the sludge 3-5mm thick. Even with 3kw, i dont think ill have any flexing at all out of the roof. fun times
-Cody
so much to do, so little time...
-Cody
Post edited by exalted512 on
«13
  • exalted512
    edited January 2006
    forget these, theyre pictures of my living room during this process. good thing my roommate is still at home for the christmas holidays
    -Cody
  • nadams
    nadams Posts: 5,877
    edited January 2006
    Nice purse.
    Ludicrous gibs!
  • swerve
    swerve Posts: 1,862
    edited January 2006
    lookin good my friend.
    cats.vans.bag...
  • cam5860
    cam5860 Posts: 632
    edited January 2006
    What is your setup going to be far as equiment goes?
  • swerve
    swerve Posts: 1,862
    edited January 2006
    he isn't getting a stereo in that thing... just deadening for road noise.
    cats.vans.bag...
  • exalted512
    edited January 2006
    word
    -Cody
  • cam5860
    cam5860 Posts: 632
    edited January 2006
    Damn that's a lot of work just to be killing road noise.
  • exalted512
    edited January 2006
    i have very sensitive ears, if i hear noises in excess of 80db's for an extended period of time(10 minutes or so) my ears start ringing
    -Cody
  • nadams
    nadams Posts: 5,877
    edited January 2006
    *cough* "Even with 3kw" *Ahem*
    s'cuse me.
    Ludicrous gibs!
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2006
    Damn bro, youve got way more patience than I do. There is no way I would undertake all that.
    The only big jobs I can tackle are the ones that I can walk away from for a day or so when I get really pissed off.
  • cam5860
    cam5860 Posts: 632
    edited January 2006
    Hell I thought you was putting a system in there. What is that 3000 watt punch power amp supposed to be going in?
  • exalted512
    edited January 2006
    probably by the end of the summer. I have to build the box first.
    -Cody
  • skydeaner
    skydeaner Posts: 187
    edited January 2006
    lol, do you have a connector tied to the top with speaker wire to keep it out of the goo? (pic9)
    Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
  • exalted512
    edited January 2006
    yea, i have some wires that go across the floor. I had some speaker wire laying around and i needed to get the wire out of the way so i tied it up:D
    i got mat layed across all where the front seats would be and got it all sludged. The head liner is done as well. Im going to put a couple layers of the spectrum spray and then put the seats back in. Hopefully get the layers done tomorrow and have the seats bolted in the day after.
    -Cody
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited January 2006
    All that hard work will definately pay off.
    Looks good exalted!
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • SportsFan
    SportsFan Posts: 93
    edited January 2006
    Wouldn't a better title for this thread be "Sound DEAFENING has started"??? :p:D
    '98 Honda Accord LX Sedan
    Alpine CDA-9847
    Alpine MRP-F240
    Polk Audio db1000
    Polk Audio db650
    Polk Audio db690
    Sirius Starmate 4 Satellite Radio
    Beltronics Vector 995 Radar Detector
  • brettw22
    brettw22 Posts: 7,623
    edited January 2006
    What's the point of putting stuff on the hood? How does that make a big enough difference to replace the typical hoodliner?
  • swerve
    swerve Posts: 1,862
    edited January 2006
    when you have that much power god only knows what is rattling....
    cats.vans.bag...
  • exalted512
    edited January 2006
    makes the cabin quieter. I had those two pieces on it and put expandable foam in the crossmembers and at 2500 rpms, there was a 3 dB drop inside the cab
    -Cody
  • exalted512
    edited January 2006
    head liner is done! so is where the seats go. Head liner has 1 layer of mat and 4-5mm thick of sludge. Floor is one layer of mat, 3-4mm thick of sludge, 4 coats of the liquid stuff which is a little thicker than paint.
    Tomorrow the seats go back in:D
    -Cody
  • exalted512
    edited January 2006
    yay, the truck is driveable again with all the seats in the front back in!!!! That should hold me over for a while. I'm going to try and put mat between the seats and the dash tomorrow. Sunday I want to put sludge over it since I'll have a lot of time to let it dry and put the head liner on. Thats the goal, hopefully ill be able to lay some mat down in the extended cab part as well. All is going well.
    -Cody
  • beardog03
    beardog03 Posts: 5,550
    edited January 2006
    great job..
    That is a lot of freakin work..
    any trouble getting the headliner back in ?
    I want to do this to my car, but I don`t think I can pull it off without screwin somethin up..!!
    I`m gonna try though...someday..!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • amulford
    amulford Posts: 5,020
    edited January 2006
    Cody, is it really needed to cover all of the surface like that? I was under the impression the vibration dampener absorbed vibration.
    Excellent job, BTW. Is that BLOOD I see on that razor??? :eek:
  • exalted512
    edited January 2006
    ill let you know sunday ;)
    amulford-
    if you just want to stop some vibrations or rattles, then no, it is not necessary to cover everything. But I'm going to have 3000 watts going through this truck so to stop vibrations, I gotta cover damn near everything:D Plus, it also helps in sound proofing the truck where as if you only put it in certain places, youd still be getting a lot of outside noise.
    -Cody
  • MacLeod
    edited January 2006
    It also helps in cutting down on things resonating that shouldnt be. The more sound proofing you have the better. Remeber the rooms at Polk HQ where they tested speakers? Its kinda the same principle. ;)
  • exalted512
    edited January 2006
    head liner fits back in fine! All I gotta do is screw in the overhead console and thats basically it. A-pillars are back up.
    On a side note, I think I'm going to pick up some q-forms. Throw my tweeters and midranges in there and have the midbass in the door still. This way I can have at least decent sq. Best of all, q-forms run me about 30 bucks shipped to my house. Gotta love accomadations.:D
    -Cody
  • MacLeod
    edited January 2006
    No shame in that at all! If the Almighty SR6500's would fit in them I wouldnt hesitate to grab a set. Firm em up with a ton of Dynamat and youre all set!
  • exalted512
    edited January 2006
    double post
  • exalted512
    edited January 2006
    the SRs are staying in the old lady's car. I was talking about my iridiums :D
    and I'm pretty sure the SRs would NOT fit. Most q-forms are for 6" speakers, not 6.5s
    -Cody
  • MacLeod
    edited January 2006
    Yeah, I know. That sucks. 90% of components out there are 6.5's. I dont understand why they wont come out with a set of kicks thatll hold some 6.5's.
