Experiencing unpleasant, overpowering bass on certain tracks with Polk R700 speakers
Hello, I bough new speakers Polk Reserve 700 this week and connected them to Marantz Model 30 amplifier and DAC Topping D70 Pro Sabre. I listen on "Source direct" - no bass or treble changes. In general I like the sound of the speakers but there are several songs where the bass is awful on middle or low volume. For example "Cocoon, Lola Marsh - I Got You" is an one of the tracks. I have listened the speakers for at least 40-50 hours. I connected them with my old amp Teac AX-3000 amp and the ifi DAC and the same problem with bass persists. I am wondering if I should return this speakers or the bass will became more accurate. Generally I like the sound of the speakers but I don't know what is the problem with bass for these songs. With my old Cerwin Vega MX250 speakers I didn't experience bass issues on the same songs. Can you help me?
Answers
  • mantis
    mantis Posts: 17,697
    edited February 14
    Hello and welcome to the forum,
    so first off placement of the speakers will greatly enhance or decrease the amount of bass they produce. Do the R700's come with port plugs? If so use them.
    This is a common issue with Polk speakers is to much bass. You have to get them out into the room to calm them down. Your room also might be too small to handle the amount of pressure these speakers create.
    You can return them if you think they are overbearing and you tried a few things to calm them down. The R600 or R500's might be a better fit for your situation.
    SO I don't recall the Amp 30 having bass management. If you had a AVR, you could apply Bass management and run 2 external subs or 1 if your room doesn't allow for 2. Then you can crossover the R700's and get rid of the bottom end clouding up your room.
    Something like the Yamaha R-N2000A which has bass management might also be a solution.
    Another thing you can do is room treatments. Bass traps could help your situation out when properly placed. Vicoustics is a good place to start looking.
    Dan
  • Emlyn
    Emlyn Posts: 4,920
    The bass on that track sounds overboosted in the mix even on Youtube...
    https://www.youtube.com/watch?v=p_GnJTl2HqI
    You may just be hearing the clean and prodigious bass the R700s are capable of and need to make some adjustments for speaker placement. They are bottom ported so not terribly sensitive to being placed close to the front wall but will be overboosted if too close to side walls as well.
    What are the room measurements?
  • vassil
    vassil Posts: 9
    Hello and thank you for the quick responses! The room is around 35 m2 and both speakers are around 1 m away from the side walls. Yes, I placed them only 25 cm from the back wall but I tried moving them 1,5 m away from the back wall and there is no much difference. I don't see port plugs but I think that the bass comes from both 8 inch low drivers, not from the bottom bass reflex. About the Marantz Model 30 amplifier - it has option to turn on bass, treble and balance modifications. I tried turning the bass to lowest and again I hear this strong bass on this song.
    But as you said that "The bass on that track sounds overboosted in the mix even on Youtube" do I understand correctly that the source of the track Youtube is not a good quality and this could cause the problem? I experience bass problems with this track either: https://www.youtube.com/watch?v=3dX9MKAuLrI and in some AI generated rock songs.
    I will try the FLAC version of the Roy Orbison - Go! Go! Go! song and will share the experience here.
  • Emlyn
    Emlyn Posts: 4,920
    The Roy Orbison track is very well recorded and balanced.
    I don't think the performance of the speakers will change much more given the hours you have on them now. Although your room is a good size the speakers may still be overpowering the room for the way you'd like to hear music.
  • vassil
    vassil Posts: 9
    I tried with FLAC version of the Roy Orbison - Go! Go! Go and it sounds better but still the bass is too strong. It's very interesting performance with DVD of Crossroads guitar festival 2010 where the track with Buddy Guy and Ronnie Wood sounds perfect and then the track with Eric Clapton and Jeff Beck sounds very overpowered.
  • gmcman
    gmcman Posts: 1,887
    edited February 15
    My first dive into making noticeable gains in my equipment setup after I bought my Polk RT800's and CS400 way back in the day, was after listening to the "Rush Hour" soundtrack and hearing muddy bass and some small amounts of cone bottoming out during louder playback.
    I was using the infamous Monster XP speaker cable, almost like lamp cord but obviously a bit better. I had a closeout deal on AQ Crystal which I later bi-wired and immediately all that sloppy bass was gone, I could crank it up with no distortion.
    My point is, while your room/speaker placement could be the issue, make sure you have clean power and delivery to the speakers. That being said, what cables are you using?
  • Emlyn
    Emlyn Posts: 4,920
    What other speakers do you have experience with in the room in similar positions? Are the Cerwin Vega MX250s the only ones?
  • vassil
    vassil Posts: 9
    Before that I had older speakers Sony APM-33W.
  • SeleniumFalcon
    That's really what equalizers are meant to cure, problems with program material:
  • vassil
    vassil Posts: 9
    I made some improvements: first of all I started to listen music on Tidal.com. The next thing is to improve the acoustics of the room. I bought a carpet and curtains. My question is should the carpet be placed below the speakers or it should stand in front of them?
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,405
    It's good that Tidal sounds better, but carpets are not going to do much to change bass characteristics. Bass sound wavelengths are very large, for example 60Hz has a wavelength near 19'. The thickness and pile density of carpet are going to be very ineffective at absorbing low frequency sounds. What acoustic changes do you want to achieve in your room?
  • skipshot12
    skipshot12 Posts: 2,177
    Sounds like you may have a room spike at a certain frequency.
    The first place to tame booming bass is the corners of the room.
    Some bass traps would be a good start.
    Do you have anything to do a frequency sweep?
    F1nut Posts: 52,406
    I'll answer that one. The carpet should be in front.
    Carpet, curtains and other upholstered pieces will address issues with slap echo. That is, make the room less lively.
    As suggested, bass traps in the corners should help with bass boom.
  • Emlyn
    Emlyn Posts: 4,920
    Also, what is the building construction like? High rise apartment with concrete floors and walls, slab floor with wood framed wall house, suspended wooden floor and wood framed wall house?
    That last one is the worst to have to contend with for bass if the room itself is acting like a drum.
  • vassil
    vassil Posts: 9
    Ok, I will put bass traps in the corners. Can you suggest me good ones?
    The room is the first floor of a house made with concrete and bricks. The floor is laminate, the ceiling is concrete with height of 2,60m. On both side walls there are windows but I ordered curtains for them.
    By the way when I put the carpet under the speakers the sound became calmer.
  • Emlyn
    Emlyn Posts: 4,920
    I don't have any suggestions on bass traps because I don't use them, but even putting a bookcase in a corner will help.
    Concrete and brick construction is much easier to address acoustically than a wood framed house.
  • vassil
    vassil Posts: 9
    This is the result of the frequency sweep:
    pitdogg2 Posts: 27,921
    Sounds like you have your work cut out for you. All those hard reflective surfaces will make it very lively.
    F1nut Posts: 52,406
    Speakers should not be on carpet unless you use spikes that pierce through to the solid floor.
  • Gardenstater
    Gardenstater Posts: 4,991
    "The floor is laminate".............what is the physical construction of the floor? Is it a concrete slab or is it typical wood framing over a basement?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • vassil
    vassil Posts: 9
    The physical construction of the floor is concrete.
    Yes, I use the spikes for speakers. Now I put the rubber caps and will check if it sounds better.
    billbillw Posts: 8,373
    edited March 13
    I'm guessing that with a fully concrete room, and the frequency response shown, you just have some very strong room effect that is boosting the bass. Corner traps could help, but you might consider if there is a way that you might be able to re-configure the system layout. If the room is a rectangle, there could be a different response if you had the speakers along the longer (or shorter) wall.
  • skipshot12
    This was why we used to use equalizer's, the answer is in the name.
