Monitor 7C - advice on next step
I have completed the crossover mod on my 7c pair with a Claritycap 12 uf, two Jantzen cps in parallel (33uf and 1uf) for the 35 uf. To replace the polyswitch and the resistor which are in series, I uses a 2.5 Ohm Mills wire wound resistor.
The change is astounding.
  • The speakers are more efficient, lower levels need from the amp.
  • Imaging is excellent. Some instruments seem like they are between the speakers and my listening position.
  • Mid bass is vastly improved.
On the other hand, I now understand what many say about SL2000. Even though my hearing is on the edge of the infamous resonance, the tweeters do seem brighter. For now I am EQing down at 13k to make the sound mellower. I called Polk but the RDO-194 is back-ordered. They asked me to call in a few weeks.
Meanwhile, I found out about the TL mod for use with the RDO-198. I understand how its implemented and that it needs a 5.8 uf cap in parallel with the 2 Ohm resistor. Since I replaced the 2 Ohm with a 2.5 Ohm resistor, will the mod still work, or should I not bother and be content with an RDO-194?
Thanks.
