Gammers
I am not one but my youngest son is and question is , will a good router help to prevent him from getting knocked off the internet so much? Spectrum is our provider and I have their gear! Also looking for recommendations as to what to get if this index would help ! Thanks I’m advance and I’m not sure about this so someone with the knowledge and experience would be great!
Best Answers
    treitz3 Posts: 20,119
    Answer ✓
    NETGEAR Nighthawk Multi-Gig Cable Modem CM2000
    NETGEAR Nighthawk Tri-band Mesh (MK83) AX3600 Router
    If you get these two? No more buffering, no more waiting, no more BS. I have Spectrum as well. I returned their stuff and got these. They were both recommended by Trey (who had no issues in his house) and was also after blowing almost a grand trying other gear that ultimately did not work. FWIW.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Answer ✓
    I have a gamer friend whom swears by LAN connections for gaming. It’s all about a locked-on signal and speed. Wi-fi has to buffer and is slower than LAN.
Answers
  • Thanks both you guys and I will probably do what Tom suggested and yes hard wired as all my gear stays! When I get back home I will get this handled !
  • Wired connection is definitely the best for gaming if you can make it happen. I would also recommend running a speed test on a wired connection directly to your router; make sure you are getting what you are paying for and the ping isn't high. My router has a speed test built into the admin page.
    Also, if you are having issues with dropping on a wired connection you could call your provider and ask them to take a look at your connection.
